Autonomi Glossary and Acronyms
I know I can’t be the only one who forgets what some of the abbreviations are here and that’s the reason I made this. It’s a Wiki so anybody can update or comment with what to add, then I will. :wink: I started off with a couple, but know there are tons more to be added. Thanks.
ABFT - Asynchronous Byzantine Fault Tolerance - A cornerstone of the SAFE Network
Actor - A node or group of nodes performing an action
Adult - A node that can store and route data.
AE - Anti-Entropy - AE forces all nodes that want to perform data operations on the network to prove they are up to date.
AT2 - Asynchronous Trustworthy Transfers
BFT - Byzantine Fault Tolerance - Byzantine fault tolerance is the dependability of a fault-tolerant computer system, particularly distributed computing systems, where components may fail and there is imperfect information on whether a component is failed.
BLOB - Binary Large OBject
BRB - Byzantine Reliable Broadcast
Chunk - A piece of immutable data of limited size. Typically a file is made up of multiple chunks.
CLI - Command Line Interface
Close Group Consensus- Using Close Group Consensus, small groups are able to make statements on behalf of the entire Network which means that the Network does not need to communicate directly with every single node each time.
CRDT - Conflict-free Replicated Data Type
CRDT-tree - Basis of the Safe Network file system
DAG Directed Acyclic Graph
DevOps CI/CD - Software development (Dev) and information-technology operations (Ops) Continuous Integration / Continuous Delivery
DBC - Digital Bearer Certificate - Digital Money first described by Nick Szabo in 1997
DLT - Distributed Ledger Technology
DKG - Distributed Key Generation
droplet - similar to an AWS instance, provided by Digital Ocean, preferrd by many for hosting nodes in the cloud.
DSB - Deterministically Secure Broadcast
Elder - An adult node with voting rights in its section
E2E - End-to-end
GET - To read data from the network (free, no account needed).
GUI - Graphical User Interface
IDA - information dispersal algorithm. Used to split data into k-of-n parts which reduces bandwidth when fetching data.
IDN - Internationalized Domain Name
IGD - Internet Gateway Device
Infant - A node that has not yet proved its worth to the Network.
I/O - input/output is any software or hardware device designed to send and receive data to and from a computer hardware component
MAID - Massive Array of Internet Disks
MaidSafer - An employee of the MaidSafe Company - not in common use.
Map - Data type, a kind of key-value store
MVE - Minimum Viable Experience
MVP - Minimum Viable Product
Node - A device running software that performs networking tasks such as allowing another node to join the Network, storing and routing data and communicating with other nodes. (Formerly Vault)
NRS - Name Resolution System
PARSEC - Protocol for Asynchronous, Reliable, Secure and Efficient Consensus. A protocol that was developed some years ago but is now superseded, PARSEC allowed the team to develop other more efficient methods of achieving the seemingly impossible.
Proof of Authority - Cryptographic proof that a node or group of nodes is permitted to perform a requested action
PUT - To add/amend data on the network (costs SNT)
PR - Pull Request
quic-p2p - A software library allowing secure and reliable connection between nodes.
RDF - Resource Description Framework
Replica - a CRDT term. In a Safe context it’s another word for Elder
RFC - Request for Comments
RMD - Reliable Message Delivery
Safer - Any user or developer of the SAFE Network.
Safester - An early adopter that helped or contributed in some way towards the launch of the Safe Network.
Safe - Secure Access For Everyone
SAP - Section Authority Provider is a set of Elders signed by the current section chain elders. So you can traverse the section chain from genesis and confirm the nodes you are speaking to are valid Safe Elders in a valid Safe section. When speaking to Elders with a section key they may say you are out of date, give you part of the section chain from your key to the new key plus the new SAP (set of Elders to connect to)
SCL - SAFE Client Libs
SectionChain (or SectionProofChain) - A sequence of public keys, each signed by the previous one, that’s updated every time an Elder is changed and acts as proof that the Section is valid
Self-encryption - Files uploaded to the Network are broken up into chunks. These chunks are then hashed and encrypted locally using hashes of neighbouring chunks from the same file
Sequence Data type, an append-only data type in which the data is not associated with keys
SLD - Service Level Design
SMD - Secure Message Delivery
SNT - Safe Network Token
UI - User Interface, closely related to
UX - User Experience
Vault - see Node
WP - White Paper
XorName - a representation of an XOR address
Safe Network Dev Update - December 17, 2020
Testnet Changelog - December 24th, 2020
Safe Network Dev Update - March 4, 2021
Update February 16th, 2023
Update 15 December, 2022
Update 25 November, 2021
Update 20 October, 2022
Update 18 August, 2022
Update 27 January, 2022
Update 15 September, 2022
Update 09 February, 2023
Update 01 December, 2022
Update 28 September, 2023
Update 5 October, 2023
Update 12 October, 2023
[Offline] Update 08 December, 2022: A wild testnet appears!
Update 22 December, 2022
Update 11 January, 2024
Update 27 October, 2022
Update 3 November, 2022
Safe Network Dev Update - September 17, 2020
Update 27 April, 2023
Update 30 March, 2023
SAFE Network Dev Update - May 21, 2020
Update 07 April, 2022
Update 26th August, 2021
Update 02 September, 2021
Update 23 February, 2023
Update 04 May, 2023
Update 06 April, 2023
Update 13 April, 2023
Update 10 November, 2022
Update 25 August, 2022
Update 17 November, 2022
Safe Network Dev Update - August 27, 2020
Update 24 November, 2022
Update 02 March, 2023
Update 09 September, 2021
Update 16 September, 2021
Update 25 May, 2023
Update 05 January, 2023
Update 12 January, 2023
Update 20 April, 2023
SAFE Network Dev Update - May 14, 2020
Update 23rd March, 2023
Update 28 July, 2022
SAFE Network Dev Update - May 28, 2020
Update 19 January, 2023
Update 26 January, 2023
SAFE Network Dev Update - July 9, 2020
Update 01 June, 2023
Update 18 January, 2024
What’s up today? (Part 1)
Update 14 October, 2021
Update 02 February, 2023 [The feb2 testnet - Offline]
Update 30 September, 2021
SAFE Network Dev Update - July 16, 2020
SAFE Network Dev Update - June 4, 2020
SAFE Network Dev Update - August 13, 2020
Update 11 May, 2023
SAFE Network Dev Update - May 7, 2020
Update 8 June, 2023
SAFE Network Dev Update - June 11, 2020
Update 09 March, 2023
Update 22 February, 2024
Update 16th March, 2023
Update 18 May, 2023
Safe Network Dev Update - February 11, 2021
Update 15 June, 2023
SAFE Network Dev Update - June 18, 2020
Update June 2nd, 2022
Update June 22, 2023
SAFE Network Dev Update - July 30, 2020
Safe Network Dev Update - October 29, 2020
SAFE Network Dev Update - June 25, 2020
SAFE Network Dev Update - July 23, 2020
SAFE Network Dev Update - August 6, 2020
Safe Network Dev Update - March 18, 2021
SAFE Network Dev Update - July 2, 2020
Safe Network Dev Update - October 8, 2020
Safe Network Dev Update - November 5, 2020
Safe Network Dev Update - December 10, 2020
Safe Network Dev Update - September 3, 2020
Safe Network Dev Update - October 1, 2020
Safe Network Dev Update - October 15, 2020
Safe Network Dev Update - September 10, 2020
Safe Network Dev Update - October 22, 2020
Safe Network Dev Update - January 21, 2021
Safe Network Dev Update - January 14, 2021
Safe Network Dev Update - November 12, 2020
12月17日2020年のセーフ・ネットワーク開発アップデート Safe Network Dev Update - December 17, 2020
Safe Network Dev Update - November 19, 2020
Update 02 November, 2023
Thursdays are back! [Update - July 15th, 2021]
Safe Network Dev Update - November 26, 2020
Safe Network Dev Update - February 4, 2021
Safe Network Dev Update - December 3, 2020
Safe Network Dev Update - January 28, 2021
Safe Network Dev Update - January 7, 2021
Safe Network Dev Update - February 25, 2021
Safe Network Dev Update - February 18, 2021
Safe Network Dev Update - March 11, 2021
Safe Network Dev Update - March 25, 2021
Update 7 July, 2022
Update 17 August, 2023
Update 29 June, 2023
Update 19th August, 2021
Update 24 August, 2023
Update 22nd July, 2021
Update 4 November 2021
Update 02 December, 2021
Update July, 29th, 2021
Update August 5th, 2021
Update 18 November, 2021
Update 21 October, 2021
Update 28 October , 2021
Update 31 August, 2023
Update 11 November, 2021
Update 10 March, 2022
Update 10 February, 2022
Update 17 March, 2022
Update February 17, 2022
Update 24 February, 2022
Update 24 March, 2022
Update 3 March 2022
Update 09 December, 2021
Update 16 December, 2021
Update 06 January, 2022
Update January 13, 2022
Update January 20, 2022
Update 03 February, 2022
Update 09 June, 2022
Update 21 April, 2022
Update 29th February, 2024
Update 07 March, 2024
Update 4th August, 2022
Update 16 June, 2022
Update 23 June, 2022
Update 14 July, 2022
Update 28 April, 2022
Update 5 May, 2022
Update May 12, 2022
Update 19 May, 2022
Update 21 July, 2022
Update 11 August, 2022
Update May 26, 2022
Update 30 June, 2022
Update 01 September, 2022
Update 08 September, 2022
Update 22 September, 2022
Update 06 July, 2023
Update 29 September, 2022
Update 20 July, 2023
Update 13 July, 2023
Update 06 October, 2022
Update 27 July, 2023
Update 13 October, 2022
Update 03 August, 2023
Update 10 August, 2023
Update 14 September, 2023
Update 21 September, 2023
Update 09 November, 2023
Update 16 November, 2023
Update 23 November, 2023
Update 19 October, 2023
Update 26 October, 2023
Update 30 November, 2023
Update 14 December, 2023
Update 07 December, 2023
Update 07 September, 2023
ReadMeFirst for new users and long lost friends
All about Autonomi's new Internet - key documents and links
Update 23 September, 2021
Update 14 April, 2022
Update 07 October, 2021
Update 25 January, 2024
Update 1 February, 2024
SAFE Network Dev Update - August 20, 2020
Safe Network Dev Update - September 24, 2020
Update 31 March, 2022
Great idea!
This’ll surely help a lot of people, including me…
MAID - Massive Array of Internetworked Disks :wink:
SAFE - Secure access for everyone :slight_smile:
From yesterday’s update:
RFC - Request For Comments
PR - Pull Request
UX - User experience
SAFE - Secure Access for Everyone
I’m really enjoying the ant-like vibe of collaboration here. :slight_smile:
SMD - secure message delivery
They seemed to have changed or been added to?
So SMD and RMD then I guess.
@upstate
I’ll mention as it may matter to those in the future searching for a document like this; the correct word is acronym and not abbreviation.
The word “Consensus” is missing.
Devops CI/CD - software Development and information-technology operations Continuous Integration/Continuous Delivery
Fixed it. Thanks.
Fixed. :slight_smile:
@upstate
Future thought, it’s possible that abbreviations will also be present and if so the title could use the word Terms and the topic’s description could contain both acronym and abbreviation.
I just need to know the exact wording and I’ll update it.
EDIT: I attempted, but gibberish is my native tongue and if it needs to be changed, let me know.
Don’t forget PUT and GET.
What do those stand for?
