NewYearNet was probably our longest testnet yet. Although we started hitting the limits of diskspace as our log levels were still quite high (and no log compression was set), which necesitated us killing it off.
So in this testnet, we’ll be logging less and archiving those logs more frequently on our nodes. Which could well keep us going longer (barring any need to upgrade the nodes themselves).
The major change here though, is the switch from tcp to quic as the default communication layer. This means that AutoNat wont be working for us, so if your node does not manage to connect, the automatic exit on the node side of things will not be working.
We’re looking to assess the quic performance, both in terms of files up/down, but also in terms of resource usage of nodes. So please keep an eye on any changes in performance or utility you’re perceiving here compared to the last network ![]()
The only other change of note here is that nodes will now be encrypting and decrypting records before they’re written to disk (regardless of what the client is doing). So now no data at all should be exposed to normal node operators.
Network Details
Node version: 0.103.25
Client version: 0.89.29
Faucet url: 157.245.40.226:8000
We have 51 droplets running a total of 2001 nodes. One droplet has 2vcpu and 4GB of memory.
Quickstart
safeup client --version 0.89.29
safeup node --version 0.103.25
Run a Node
Linux/macOS:
safenode
Windows:
safenode
Linux/macOS:
safe wallet get-faucet 157.245.40.226:8000
Windows:
To do this with non-default batch-sizes (along with SAFE_PEERS set as above):
safe files upload --batch-size 40 <directory-path>
40 being the integer value you want to set
Further Information
Obtaining Binaries
Installing Safeup
Installing Binaries
safeup client --version 0.89.29 # get a specific version
safeup node --version 0.103.25 # get a specific version
Running a Node
# Linux/macOS
safenode
# Windows
safenode
This will output all the logs to the filesystem, with the location of logs being platform specific:
# Linux
# macOS
# Windows
# Linux/macOS
# Windows
Connecting as a Client
Using the Client
safe files download
# Linux
# macOS
# Windows
safe file download [directory/filename] [NetworkAddress]
Troubleshooting
Cleanup
# Linux
rm -rf ~/.local/share/safe
# macOS
# Windows
