ClientImprovementNet highlighted a few areas we’ll be looking at here.
Firstly we want to be sure if removing the attempted kad-caching has helped with data-put reliability (as described in the dev update. This is our main point to dig in on for this testnet, hopefully gaining a bit more clarity via…
The new client and node builds will all automatically be logging to disk by default now. So should any issues arise during upload etc, we’ll hopefully be able to coordinate some log exchange and get a clearer picture of what’s going on.
Downloads should also be clearer/faster when they fail (as opposed to reporting at the end of the download, which could be a paiiin for large files.).
And finally, we’re also heaptracking all nodes to try and get a read on the increasing memory we’ve been seeing in the testnets.
Network Details
Node version: 0.91.3
Client version: 0.83.4
Faucet url: 139.59.189.128:8000
We have 101 droplets running a total of 2001 nodes. One droplet has 2vcpu and 4GB of memory.
Quickstart
safeup client --version 0.83.4
safeup node --version 0.91.3
Run a Node
Linux/macOS:
safenode
Windows:
safenode
Linux/macOS:
safe wallet get-faucet 139.59.189.128:8000
Windows:
To do this with non-default concurrency or batch-sizes (along with SAFE_PEERS set as above):
safe files upload -c 10 --batch-size 40 <directory-path>
10 and 40 being the integer values you want to set for each
Further Information
Obtaining Binaries
Installing Safeup
Installing Binaries
safeup client --version 0.83.4 # get a specific version
safeup node --version 0.91.3 # get a specific version
Running a Node
# Linux/macOS
safenode
# Windows
safenode
This will output all the logs to the filesystem, with the location of logs being platform specific:
# Linux
# macOS
# Windows
# Linux/macOS
# Windows
Connecting as a Client
Using the Client
safe files download
# Linux
# macOS
# Windows
safe file download [directory/filename] [XORURL]
Troubleshooting
Cleanup
# Linux
rm -rf ~/.local/share/safe
# macOS
# Windows
