Here we’re looking to further test out some client fixes to various timeouts and other issues we’ve applied in the course of the prior testnet.
We’ll also be keeping an eye out for “lost nodes” (nodes that start but do not appear to join the network successfully). We’ve removed code to this end, that seems to have been contributing to memory issues… So here we’re looking to see if that’s a) still needed with the network-contacts file, and b) at least in part a source of the memory issues.
Network Details
Node version: 0.93.1
Client version: 0.83.45
Faucet url: 178.128.34.165:8000
We have 101 droplets running a total of 2001 nodes. One droplet has 2vcpu and 4GB of memory.
Quickstart
safeup client --version 0.83.45
safeup node --version 0.93.1
Run a Node
Linux/macOS:
safenode
Windows:
safenode
Linux/macOS:
safe wallet get-faucet 178.128.34.165:8000
Windows:
To do this with non-default concurrency or batch-sizes (along with SAFE_PEERS set as above):
safe files upload -c 10 --batch-size 40 <directory-path>
10 and 40 being the integer values you want to set for each
Further Information
Obtaining Binaries
Installing Safeup
Installing Binaries
safeup client --version 0.83.45 # get a specific version
safeup node --version 0.93.1 # get a specific version
Running a Node
# Linux/macOS
safenode
# Windows
safenode
This will output all the logs to the filesystem, with the location of logs being platform specific:
# Linux
# macOS
# Windows
# Linux/macOS
# Windows
Connecting as a Client
Using the Client
safe files download
# Linux
# macOS
# Windows
safe files download [directory/filename] [XORURL]
Troubleshooting
Cleanup
# Linux
rm -rf ~/.local/share/safe
# macOS
# Windows
or
rmdir C:\Users\<username>\AppData\Roaming\safe -r -Force
