After QuicNet blazed itself to the ground, we’re back with a network that
- Does not encrypt data at nodes. (In order to see how much that contributed to mem-spikes we saw).
- Derives payment keys from the
PeerIdkey, so restarted nodes should be able to accept payments now. - Has more logs
Here we’re looking to see
- How this lack of encryption impacts performance
- Can we upgrade this network (in theory we can, but we’ll see how that goes when we’ve new versions out…)
- Are memory leaks still afoot? What can we see with our increased logging here.
For those running nodes: please enable a good amount of log files to be kept (~50), this will take up more space, but we’re not anticipating a long testnet here ![]()
Network Details
Node version: 0.103.45
Client version: 0.89.49
Faucet url: 178.128.166.148:8000
We have 101 droplets running a total of 1001 nodes. One droplet has 2vcpu and 4GB of memory and 10 nodes (down from 40 to allow for more detailed logging this run!).
Quickstart
safeup client --version 0.89.49
safeup node --version 0.103.45
Run a Node
Linux/macOS:
safenode
Windows:
safenode
Linux/macOS:
safe wallet get-faucet 178.128.166.148:8000
Windows:
To do this with non-default batch-sizes (along with SAFE_PEERS set as above):
safe files upload --batch-size 40 <directory-path>
40 being the integer value you want to set
Further Information
Obtaining Binaries
Installing Safeup
Installing Binaries
safeup client --version 0.89.49 # get a specific version
safeup node --version 0.103.45 # get a specific version
Running a Node
# Linux/macOS
safenode
# Windows
safenode
This will output all the logs to the filesystem, with the location of logs being platform specific:
# Linux
# macOS
# Windows
# Linux/macOS
# Windows
Connecting as a Client
Using the Client
safe files download
# Linux
# macOS
# Windows
safe file download [directory/filename] [NetworkAddress]
Troubleshooting
Cleanup
# Linux
rm -rf ~/.local/share/safe
# macOS
# Windows
