Unfortunately I get the same error as in the previous testnet:
PS C:\Users\gggg> safenode
Logging to directory: "C:\\Users\\gggg\\AppData\\Roaming\\safe\\node\\12D3KooWQMgwAMod3uGJvpHmUF27DawFgicA6HFpase2mT7JvHMN\\logs"
Node started
PeerId is 12D3KooWQMgwAMod3uGJvpHmUF27DawFgicA6HFpase2mT7JvHMN
You can check your reward balance by running:
`safe wallet balance --peer-id=12D3KooWQMgwAMod3uGJvpHmUF27DawFgicA6HFpase2mT7JvHMN`
After starting the node, I canât type any command, I canât do anything else in this session.
I used Windows Power Shell to launch my node, and while I also couldnât type a command in the tab I launched the node from, I opened another tab & requested balance & it worked fine.
May be worth trying another tab / window if itâs an option for you.
There actually isnât an error here. Itâs behaving as expected.
The language it uses when it says âTrying to fetchâŚâ could potentially be a bit confusing though, because it doesnât confirm that it did actually fetch the contacts file.
However, that said, your node is running. Itâs a blocking process, so if you want to do something else, you need to use another shell session.
Edit: I just wanted to say, my opinion is that the logging should go to stdout if no logging argument to file is specified. That way you would see the node doing something. Itâs not completely obvious that it would be logging to file in the background.
Anyway, I have two nodes running and earning. Uploads are really much much faster as was the faucet too.
I am most interested in seeing if the change to QUIC does anything to the problems my LAN had been having with the previous testnets - meaning my piece of a crap router just saying no.
I just started my first machine and rewards appear to be on steroids in comparison to the last network, has anything changed there? Rewards balance: 0.000000512 10 minutes in.
Another observation is cpu seems to be up a bit, not crazy or issue territory but notable, might settle.
CLI folders related to payments, cash_notes and payments have a very low size after a few uploads. Was this so already in the last testnet? Anyway, another reason to
However, in the new session I tried to connect as a client and download the tokens but here I get a strange error:
PS C:\Users\gggg> safe wallet get-faucet 157.245.40.226:8000
safe : The term 'safe' is not recognized as the name of a cmdlet, function, script file, or operable program. Check the
spelling of the name, or if a path was included, verify that the path is correct and try again.
At line:1 char:1
+ safe wallet get-faucet 157.245.40.226:8000
+ CategoryInfo : ObjectNotFound: (safe:String) [], CommandNotFoundException
+ FullyQualifiedErrorId : CommandNotFoundException
It looks like you donât have an installation of the safe client. Remember, you can use safeup to get that.
Also, remember you will need to specify a peer to connect to when running safe. You can do that either by using the --peer argument (which you will need for each command you run), or you can set the SAFE_PEERS variable once and it will persist for the remainder of the shell session.
Well, when I used GPT to translate that error message into English, it looks like this is some kind of warning from the operating system that itâs blocking the use of safe.exe because it considers it to be potentially harmful.
PS C:\Users\gggg> safe --version
At line:1 char:2
+ safe --version
I hit the faucet a âfairly fairâ 20 times in anticipation of it throwing itâs toys and others perhaps needing some dough.
1 out of the 20 requests resulted in.
josh@pc1:~$ safe wallet get-faucet 157.245.40.226:8000
Logging to directory: "/home/josh/.local/share/safe/client/logs/log_2024-01-30_15-10-13"
Built with git version: a15b141 / main / a15b141
Connecting to the network with 43 peers
đ Connected to the Network Requesting token for wallet address: b4daa87647f9010766ede59ec3a13dc3214d09838da5a9a14a2f003ae6d5c9fd78543e9b6394fde25f4677a666638885
Successfully parsed transfer.
Failed to verify and redeem transfer: CouldNotReceiveMoney("InvalidTransfer(\"GetRecord Query Error NotEnoughCopies { record_key: 88c4bd(1c19166b10f56b2cb229655ec25bb3a89976a0e25502fdc80663dd212b793a88), expected: 5, got: 3 }\")")
Error:
0: Failed to receive transfer due to InvalidTransfer("GetRecord Query Error NotEnoughCopies { record_key: 88c4bd(1c19166b10f56b2cb229655ec25bb3a89976a0e25502fdc80663dd212b793a88), expected: 5, got: 3 }")
/rustc/82e1608dfa6e0b5569232559e3d385fea5a93112/library/core/src/convert/mod.rs:757
Upload progress: Uploaded 35.7GB file in 271 minutes and 12 seconds. Around 2.2 MB/s. Fantastic speed!
Unfortunately 66 chunks failed, so no address / filename is given in CLI, and the file canât be downloaded. Iâll try to re-upload a few times and see how it goes, but initial re-attempts have failed.
Upload / download worked perfectly with an 11mb JPG.
C:\Users\ggg\safe\safenode.exe and C:\Users\ggg\safe\safeup.exe
Whereas safe.exe I donât have.
You are right, I restarted the safeup client --version 0.89.29
then the safe.exe file appeared in the safe folder, but after running the safe wallet get-faucet 157.245.40.226:8000
command, an error appears and the operating system removed again from the safe.exe folder.
Hmm, thatâs annoying that itâs marking safe as some kind of malicious file. You might need to look at the Windows firewall or anti-virus settings to add an exception for it. I donât believe anyone else has ever hit that issue. I was wondering if you were using Windows 11, but youâve already mentioned youâre on 10.
