We’ve another testnet hopeful to address some replication flows (or at least give us more insight into any issue) and to allow for sampling of node memory for debugging any memory leaks that may still persist (or at least identify if it is just the cost of connections thus far).
We’ve other improvements to logging around the same topic, removal of some tracing instrumentation (that could well have been a leak location), reinstated an older replication mechanism as the current one looks to be too frail, and some client tweaks too!
For examaple:
- More retries of failed chunks in the client
- Reduced metrics logging across the board
- Removal of failed records should write to disk fail (a potential source of wild incomes
) - More feedback when getting costs takes time (thanks @mav)
Network Details
Node version: 0.91.16
Client version: 0.83.17
Faucet url: 138.68.161.29:8000
We have 101 droplets running a total of 2001 nodes. One droplet has 2vcpu and 4GB of memory.
Quickstart
safeup client --version 0.83.17
safeup node --version 0.91.16
Run a Node
Linux/macOS:
safenode
Windows:
safenode
Linux/macOS:
safe wallet get-faucet 138.68.161.29:8000
Windows:
To do this with non-default concurrency or batch-sizes (along with SAFE_PEERS set as above):
safe files upload -c 10 --batch-size 40 <directory-path>
10 and 40 being the integer values you want to set for each
Further Information
Obtaining Binaries
Installing Safeup
Installing Binaries
safeup client --version 0.83.17 # get a specific version
safeup node --version 0.91.16 # get a specific version
Running a Node
# Linux/macOS
safenode
# Windows
safenode
This will output all the logs to the filesystem, with the location of logs being platform specific:
# Linux
# macOS
# Windows
# Linux/macOS
# Windows
Connecting as a Client
Using the Client
safe files download
# Linux
# macOS
# Windows
safe file download [directory/filename] [XORURL]
Troubleshooting
Cleanup
# Linux
rm -rf ~/.local/share/safe
# macOS
# Windows
