The last testnet was a certain improvement over the prior hiccups in the last month, but we’re looking to push things even further.
The main change here is aimed at reducing the connection load in nodes. We’ve two major strategies here:
- We reduce the number of nodes in the
royalty-transfertopic, which reduces the overall connections significantly - We have reworked how and when we try to redial nodes. This means we drop more connections more often, and increase the network knowledge to near idealised levels.
Local testing has shown quite drastically reduced memory, with heaptrack recorded “leaks” down from ~180mb a couple of weeks ago to ~18mb now (those leaks are ostensibly ongoing connectivity related memory).
Other changes:
- Reduced replication down to 2* CLOSE_GROUP
- Verification that replication messages come from a close node
- addition of a
wallet verifycommand to the CLI, to allow forCashNoteverification - use of
MsgPackinstead ofbincodefor serialisation. (This will allow nodes/clients in any language, whereasbincodewas rust specific). - more routing table / discovery tweaks
- reduced verification waits
- other chunk upload / payment fixes and tweaks
Network Details
Node version: 0.99.9
Client version: 0.86.44
Faucet url: 157.245.34.131:8000
We have 101 droplets running a total of 2001 nodes. One droplet has 2vcpu and 4GB of memory.
Quickstart
safeup client --version 0.86.44
safeup node --version 0.99.9
Run a Node
Linux/macOS:
safenode
Windows:
safenode
Linux/macOS:
safe wallet get-faucet 157.245.34.131:8000
Windows:
To do this with non-default batch-sizes (along with SAFE_PEERS set as above):
safe files upload --batch-size 40 <directory-path>
40 being the integer value you want to set
Further Information
Obtaining Binaries
Installing Safeup
Installing Binaries
safeup client --version 0.86.44 # get a specific version
safeup node --version 0.99.9 # get a specific version
Running a Node
# Linux/macOS
safenode
# Windows
safenode
This will output all the logs to the filesystem, with the location of logs being platform specific:
# Linux
# macOS
# Windows
# Linux/macOS
# Windows
Connecting as a Client
Using the Client
safe files download
# Linux
# macOS
# Windows
safe file download [directory/filename] [NetworkAddress]
Troubleshooting
Cleanup
# Linux
rm -rf ~/.local/share/safe
# macOS
# Windows
