PunchBowl [Testnet 09/05/2024] [Offline]
If you install the safenode-manager again and do a safenode-manager reset -f this might stop and destroy the services… I guess worth a try…
Ps: (chat gpt instructions for getting rid of the services on OSX… Sorry no OSX person myself)
To stop, disable, and remove all services that start with “safenode” on an OSX Apple device, follow these steps:
  1. Stop Services: Open the Terminal and use the launchctl command to stop all running services that start with “safenode”. You can list all services with launchctl list and then stop specific services using launchctl stop <service-name>.
  2. Disable Services: To prevent these services from loading automatically at startup, remove them from the launchd configuration. Use the command launchctl unload -w /path/to/<service>.plist. Replace /path/to/<service>.plist with the actual path to the service’s plist file.
  3. Remove Services from System: To completely remove the services, delete the corresponding .plist files from directories such as /Library/LaunchDaemons/, /Library/LaunchAgents/, ~/Library/LaunchAgents/, or other specific locations where they might be stored. Use the command rm /path/to/<service>.plist.
  4. Verification: Verify that all services have been removed by running launchctl list again to ensure no services starting with “safenode” are listed.
  5. System Restart: It’s often a good idea to restart the system to apply all changes and ensure that no remnants of the disabled services remain operational.
Note that most of these steps require administrative privileges. Also, be careful when deleting files and ensure you’re removing the correct ones to avoid system malfunctions.
BTW, how to install the node manager? I tried to find directions from other threads, but didn’t manage to find anything, though I know it gotta be there somewhere…
First you need safeup an then you just do a ‘safeup node-manager’
Not services with “safenode”, “safe”, “node”, “node-manager” or “node-launchpad”.
I fund this in LaunchDeamons:
I deleted the plists, rebooted, and finally got those processes removed.
It was driving me crazy…
BTW. Everything points to “node-launchpad” being responsible for this.
There will have to be a command to properly close these deamons.
no faucet no one uploading from my side this one is a test bed for start up and shut down scripts.
so try any experiments you want on this one and be a good boy on the next one :slight_smile:
im almost at set and forget now for my set up iv ended up with the magic number of 50 nodes a vps. I have around 50% cpu across the board and have scraped several vps so im pretty much good to go for the next test net :slight_smile:
Good idea - I guess I should be testing upgrades too :face_with_monocle: :sweat_smile:
Having squandered my allowance, I won’t do it again honest, any donations would be very helpful as I try to get the rest of something interesting uploaded…
953ad94acacb79f3925d42e5218f4b5cfe4360526090ae056ce265df667fc34e593c239489b86fe480f30cf9b809450d
:pray:
I’m broke to :frowning:
I’m sending you all I have, 0.443640458. I don’t have any more use for them. But the client seems stuck. Let’s hope it works… :pray:
I am too and it is stuck too. If it works he hit the jackpot.
You frozen at this point too?
Connecting to the network with 49 peers
🔗 Connected to the Network
Likewise…
willie@gagarin:~$ safe wallet send 2 953ad94acacb79f3925d42e5218f4b5cfe4360526090ae056ce265df667fc34e593c239489b86fe480f30cf9b809450d
Logging to directory: "/home/willie/.local/share/safe/client/logs/log_2024-05-22_20-50-29"
safe client built with git version: 16f3484 / stable / 16f3484 / 2024-05-09
I closed out and my balance is down
Is the PunchBowl empty and do we need to top it up with a bottle of Buckie and some IrnBru?
I’m heading to sleep. I’m going to leave the frozen transfer going for the night. Let’s see in the morning if @happybeing is going to get it or not. Good night!
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
Thanks so much. Received!
EDIT: @storage_guy that did the trick thank you. I can now work on making this public so long as this testnet persists (or on the next one when it happens). :+1:
Is there a way to move earned nanos from a node’s wallet to a client wallet? I wonder why safe wallet “send” does not support a --peer-id option like the balance command does? Is there a workaround?
haven’t tried it but it think if you copy the wallet folder from the node to the default client wallet location you can send the SNT out from it
This is how it ended, after 40 minutes:
Wallet has pre-unconfirmed transactions, can't progress further.
Failed to send NanoTokens(443640458) to 953ad94acacb79f3925d42e5218f4b5cfe4360526090ae056ce265df667fc34e593c239489b86fe480f30cf9b809450d due to Wallet(UnconfirmedTxAfterRetries).
Error:
   0: Wallet Error Unconfirmed transactions still persist even after retries.
   1: Unconfirmed transactions still persist even after retries
   sn_cli/src/bin/subcommands/wallet/hot_wallet.rs:265
real	40m28,189s
user	0m51,486s
sys	0m23,239s
Without further thinking I gave it another go, and it froze again. I regret for not checking my wallet balance first. I’d like to know if that failed transaction was deducted from my balance or not. But I don’t want to cancel the transaction now, because you never know how canceling affects things in these testnets. I’ll wait it out and check the balance later.
