alpha-punch went well until it didn’t. It did largely prove that the current hole-punching implementation can work. But, it may also be causing issues.
We suspect this is related to reuse of banned nodes for relay’s or overwhelming a subset of nodes as they are repeatedly (perhaps exclusively) used as relays for all incoming traffic.
Both of these things should be mitigated in this next testnet.
You should also be able to use the node launchpad to start nodes for this network too. (Though the binaries are still yet to be published… soon).
This might be one of the last networks to have a pre-filled faucet by default.
We’ll hopefully be moving to a more realistic approach soon, whereby the foundation is getting data uploaded, and users must earn money via uploads, (or indeed via transferring their OMNI balances to the new network).
In the meanwhile, it may be of interest that the wallets now create their keys via deriving from a mnemonic phrase. This means you’ll eventually be able recover your wallet from a seed phrase. You can find this in the client’s wallet/account_secret file.
This is as yet unencrypted, but we’ll be working to improve security around this in the future.
Network Details
Node version: 0.106.2
Client version: 0.91.2
Faucet url: 165.232.45.224:8000
We have 50 droplets running a total of 2001 nodes. One droplet has 2vcpu and 4GB of memory.
Quickstart
safeup client --version 0.91.2
safeup node --version 0.106.2
Run a Node
Linux/macOS:
safenode
Windows:
safenode
Linux/macOS:
safe wallet get-faucet 165.232.45.224:8000
Windows:
To do this with non-default batch-sizes (along with SAFE_PEERS set as above):
safe files upload --batch-size 40 <directory-path>
40 being the integer value you want to set
Further Information
Obtaining Binaries
Installing Safeup
Installing Binaries
safeup client --version 0.91.2 # get a specific version
safeup node --version 0.106.2 # get a specific version
Running a Node
# Linux/macOS
safenode
# Windows
safenode
This will output all the logs to the filesystem, with the location of logs being platform specific:
# Linux
# macOS
# Windows
# Linux/macOS
# Windows
Connecting as a Client
Using the Client
safe files download
# Linux
# macOS
# Windows
safe file download [directory/filename] [NetworkAddress]
Troubleshooting
Cleanup
# Linux
rm -rf ~/.local/share/safe
# macOS
# Windows
