For our next trick, we’ve added basic bad node detection, as well as fixed some issues from node startups in the previous testnet.
On top of this, we’ve tweaked the storage pricing algorithm to increase more over time to see what impact this has on node storage/hypothetical demand.
We’re really aiming to check out if there’s any major issues with these changes (and while the underlying bug that was causing bad nodes to surface should have been fixed, it’ll be interesting to see if we get any under normal use).
Network Details
Node version: 0.104.41
Client version: 0.89.85
Faucet url: 178.128.175.208:8000
We have 101 droplets running a total of 2001 nodes. One droplet has 2vcpu and 4GB of memory.
Quickstart
safeup client --version 0.89.85
safeup node --version 0.104.41
Run a Node
Linux/macOS:
safenode
Windows:
safenode
Linux/macOS:
safe wallet get-faucet 178.128.175.208:8000
Windows:
To do this with non-default batch-sizes (along with SAFE_PEERS set as above):
safe files upload --batch-size 40 <directory-path>
40 being the integer value you want to set
Further Information
Obtaining Binaries
Installing Safeup
Installing Binaries
safeup client --version 0.89.85 # get a specific version
safeup node --version 0.104.41 # get a specific version
Running a Node
# Linux/macOS
safenode
# Windows
safenode
This will output all the logs to the filesystem, with the location of logs being platform specific:
# Linux
# macOS
# Windows
# Linux/macOS
# Windows
Connecting as a Client
Using the Client
safe files download
# Linux
# macOS
# Windows
safe file download [directory/filename] [NetworkAddress]
Troubleshooting
Cleanup
# Linux
rm -rf ~/.local/share/safe
# macOS
# Windows
