IntolerantNodeNet [18/09/23 Testnet] [ Offline ]
and with that its
pkill -e safenode on my cloud instance, shutdown, snapshot and terminate - ready to get dusted off for the next one.
Thanks to everyone who made this testnet possible, those who tested it and those who will implement what has been learned.
Avanti!!!
When network can’t adapt to nodes with varying capabilities it looks like a bug to me (or at least something close to it).
But even in such case node can detect such problems on its own and stop operation if it have no chances to be useful for network.
This is a PowerShell script I’ve developed to generate, upload, and then delete a directory of three random files of sizes between 100kB and 5MB. Once complete, it’ll loop indefinitely until stopped. Since yesterday, I’ve allowed this to run intermittently and I’ve experienced zero issues uploading. All uploads have eventually been successful. All attempts at downloading a random sampling of uploaded files has proven successful, as well.
The only issue I’ve had with this testnet is when I’ve attempted to start another separate upload instance while this script is running. Any attempt to access the same wallet the script is using causes all instances to halt without error. Any other future attempts to upload fail with the same errors @Toivo witnessed earlier.
Is it possible to “lock” the wallet while in use to prevent corruption of the wallet? The only way I’ve been able to get past this issue is to delete the wallet, access the faucet generating a new wallet, and restarting either the script or a separate single upload.
vdash update ready for the next testnet: Vdash - Node dashboard for Safe Network - #103 by happybeing
Going to be bringing this down now. Thanks all! :bowing_man:
Super effort this week @joshuef - thanks!
Best Testnet ever?
  • Yes!
  • Another one was better (please specify)
  • Until the next one…
0 voters
I’m on the others have been better but only relating to speed of upload and download.
As in I enjoyed playing with them more and not having a sharable address after upload took the shine off this one for me.
Bad form to comment and vote on one’s own poll but anyway - I voted ‘Until the next one…’ but thinking about it maybe ReplicationNet from the start of June 2023 was my favourite. A lot of things seemed to come together in that one and it also ran for quite a while.
I have two more errors, the first of which also appeared on the previous test:
PS C:\Users\gggg> safe files upload <directory-E:\gggg\Pictures\VID_20210505_113014.mp4>
At line:1 char:19
+ safe files upload <directory-E:\gggg\Pictures\VID_20210505_113014.mp4 ...
The '<' operator is reserved for future use.
    + CategoryInfo          : ParserError: (:) [], ParentContainsErrorRecordException
    + FullyQualifiedErrorId : RedirectionNotSupported
After deleting the ‘<’ a message appears that the path does not exist, and I copied it from the file properties so it cannot be a mistake, I checked.
What can I do?
PS C:\Users\gggg> safe files upload directory-E:\gggg\Pictures\VID_20210505_113014.mp4>
Built with git version: 2c47455 / main / 2c47455
🔗 Connected to the Network
Error:
   0: The provided path does not contain any file. Please check your path!
      Exiting...
“Ah that would be a Microsoftumenical matter…”
The < and > are intended to indicate you substitute them and everything inside them with your path. So delete the trailing > as well.
EDIT: @Profess we’re on the wrong topic here!!!
Unfortunately, removing the second “>” character did not help, and the message that the specified path does not contain a file still appears.
I have selected another file and it is the same.
What could be the problem?
🔗 Connected to the Network        Error:
      Exiting...
   sn_cli\src\subcommands\files.rs:148
PS C:\Users\gggg> safe files upload directory-E:\gggg\Pictures\IMG_20221202_155147.jpg
Error:
      Exiting...
You only want to specify the path so you also need to remove directory-. Sorry, I didn’t spot that.
The easy way is write "safe files upload " and drag the file o the directory to the PowerShell window.
Thanks, it works now.
But if I remember correctly, in previous tests
I typed the command e.g.
and everything was fine.
I will check this, but if something has changed, it is worth mentioning in the instructions for the next TestNet.
I managed to upload the file (after overcoming many obstacles :slight_smile: ). The file size was 94.2 MB.
And I got messages like this:
PS C:\Users\gggg> safe files upload E:\gggg\Pictures\VID_20210505_113014.mp4
Total number of chunks to be stored: 190
Transfers applied locally
All transfers completed in 19.3811539s
Total payment: NanoTokens(10170) nano tokens for 20 chunks
Made payment of 0.000010170 for 20 chunks
Stored wallet with cached payment proofs. New balance: 199.999989830
Uploaded chunk #41ad71.. in 0 seconds
Uploaded chunk #eca2df.. in 0 seconds
Uploaded chunk #26bad9.. in 0 seconds
Uploaded chunk #0c0c02.. in 1 seconds
Uploaded chunk #3c6370.. in 0 seconds
Uploaded chunk #7a8c2c.. in 0 seconds
Uploaded chunk #6f9f18.. in 3 seconds
Uploaded chunk #4e1d0a.. in 2 seconds
Uploaded chunk #dc0ddf.. in 1 seconds
Uploaded chunk #f9852c.. in 0 seconds
Uploaded chunk #ba7786.. in 3 seconds
Uploaded chunk #a930c6.. in 2 seconds
Uploaded chunk #681b43.. in 3 seconds
Uploaded chunk #0ca297.. in 1 seconds
Uploaded chunk #6535f0.. in 3 seconds
Uploaded chunk #5a4112.. in 1 seconds
Uploaded chunk #dd38e6.. in 1 seconds
Uploaded chunk #ed6e20.. in 0 seconds
Uploaded chunk #9822fb.. in 0 seconds
Uploaded chunk #ebe3d2.. in 0 seconds
Uploaded 20 chunks in 65.0402037s. Current progress is 20/190.
Cannot get store cost for NetworkAddress::ChunkAddress(316ad0(00110001).. -  - 316ad0fdcdb2558e46bec29db69f82bc15c29b7e9b957e5c9b50ddcca94984de) with error CouldNotSendMoney("Network Error Not enough store cost prices returned from the network to ensure a valid fee is paid.")
All transfers completed in 14.7191887s
Total payment: NanoTokens(9415) nano tokens for 19 chunks
Made payment of 0.000009415 for 20 chunks
Stored wallet with cached payment proofs. New balance: 199.999980415
Uploaded chunk #e74708.. in 1 seconds
Uploaded chunk #2c5814.. in 1 seconds
Uploaded chunk #ab646c.. in 1 seconds
Uploaded chunk #d3642d.. in 2 seconds
Uploaded chunk #8689ff.. in 1 seconds
Uploaded chunk #bd6a36.. in 1 seconds
Uploaded chunk #383f2d.. in 4 seconds
Uploaded chunk #0f6c26.. in 3 seconds
Uploaded chunk #376b98.. in 1 seconds
Uploaded chunk #2557e3.. in 4 seconds
Uploaded chunk #32d020.. in 1 seconds
Uploaded chunk #581d52.. in 4 seconds
Uploaded chunk #1d26f2.. in 3 seconds
Uploaded chunk #e7fc0d.. in 1 seconds
Uploaded chunk #bc0f60.. in 3 seconds
Uploaded chunk #21fbd5.. in 4 seconds
Uploaded chunk #fb3556.. in 1 seconds
Uploaded chunk #fb9468.. in 1 seconds
Uploaded chunk #82e7ce.. in 1 seconds
Uploaded 20 chunks in 74.6152754s. Current progress is 40/190.
Cannot get store cost for NetworkAddress::ChunkAddress(76a7fd(01110110).. -  - 76a7fd078a1e9079fe39915de0dac3281b339e97aea8f89295e94f1dd0764532) with error CouldNotSendMoney("Network Error Not enough store cost prices returned from the network to ensure a valid fee is paid.")
All transfers completed in 20.1354505s
Total payment: NanoTokens(9365) nano tokens for 19 chunks
Made payment of 0.000009365 for 20 chunks
Stored wallet with cached payment proofs. New balance: 199.999971050
Uploaded chunk #98c790.. in 1 seconds
Uploaded chunk #98ad7b.. in 1 seconds
Uploaded chunk #dafc18.. in 4 seconds
Uploaded chunk #70ff9b.. in 3 seconds
Uploaded chunk #06834b.. in 1 seconds
Uploaded chunk #44c529.. in 4 seconds
Uploaded chunk #7c5ac9.. in 1 seconds
Uploaded chunk #1c1b39.. in 5 seconds
Uploaded chunk #d4f03b.. in 4 seconds
Uploaded chunk #8b6ec3.. in 2 seconds
Uploaded chunk #27827e.. in 1 seconds
Uploaded chunk #1b2b12.. in 1 seconds
Uploaded chunk #a3e428.. in 1 seconds
Uploaded chunk #3736e8.. in 6 seconds
Uploaded chunk #279853.. in 4 seconds
Uploaded chunk #292dcc.. in 3 seconds
Uploaded chunk #9efbad.. in 1 seconds
Uploaded chunk #2449bc.. in 1 seconds
Uploaded chunk #7a2964.. in 1 seconds
Uploaded 20 chunks in 80.0398194s. Current progress is 60/190.
Cannot get store cost for NetworkAddress::ChunkAddress(5d1821(01011101).. -  - 5d1821651768ec27df1bbfe6fc51ed0b0c706f878cc229264ca2110b26fb20af) with error CouldNotSendMoney("Network Error Not enough store cost prices returned from the network to ensure a valid fee is paid.")
All transfers completed in 23.037736s
Total payment: NanoTokens(8151) nano tokens for 19 chunks
Made payment of 0.000008151 for 20 chunks
Stored wallet with cached payment proofs. New balance: 199.999962899
Uploaded chunk #39a946.. in 1 seconds
Uploaded chunk #84d8e5.. in 1 seconds
Uploaded chunk #3959d9.. in 1 seconds
Uploaded chunk #f49535.. in 1 seconds
Uploaded chunk #a096f1.. in 2 seconds
Uploaded chunk #351e1f.. in 1 seconds
Uploaded chunk #ecc19c.. in 1 seconds
Uploaded chunk #e14ff2.. in 1 seconds
Uploaded chunk #9abd12.. in 3 seconds
Uploaded chunk #26bdc8.. in 1 seconds
Uploaded chunk #9c30d0.. in 4 seconds
Uploaded chunk #680018.. in 3 seconds
Uploaded chunk #458ae6.. in 4 seconds
Uploaded chunk #17f145.. in 3 seconds
Uploaded chunk #c17622.. in 1 seconds
Uploaded chunk #311739.. in 3 seconds
Uploaded chunk #69ee86.. in 1 seconds
Uploaded chunk #ca480d.. in 1 seconds
Uploaded chunk #797979.. in 1 seconds
Uploaded 20 chunks in 83.8070909s. Current progress is 80/190.
All transfers completed in 25.071268s
Total payment: NanoTokens(11318) nano tokens for 20 chunks
Made payment of 0.000011318 for 20 chunks
Stored wallet with cached payment proofs. New balance: 199.999951581
Uploaded chunk #311080.. in 2 seconds
Uploaded chunk #733830.. in 2 seconds
Uploaded chunk #33286b.. in 4 seconds
Uploaded chunk #5782c6.. in 2 seconds
Uploaded chunk #46dc77.. in 2 seconds
Uploaded chunk #81ce9e.. in 3 seconds
Uploaded chunk #f1ee73.. in 4 seconds
Uploaded chunk #a5ef1b.. in 2 seconds
Uploaded chunk #33d6f0.. in 3 seconds
Uploaded chunk #a16066.. in 2 seconds
Uploaded chunk #46c99e.. in 5 seconds
Uploaded chunk #6bc3f1.. in 1 seconds
Uploaded chunk #094edf.. in 8 seconds
Uploaded chunk #9c81cc.. in 1 seconds
Uploaded chunk #85f112.. in 1 seconds
Uploaded chunk #b75d8b.. in 1 seconds
Uploaded chunk #99ad08.. in 3 seconds
Uploaded chunk #d5d770.. in 1 seconds
Uploaded chunk #91a017.. in 1 seconds
Uploaded chunk #99edf4.. in 1 seconds
Uploaded 20 chunks in 88.7863129s. Current progress is 100/190.
All transfers completed in 20.9833682s
Total payment: NanoTokens(9834) nano tokens for 20 chunks
Made payment of 0.000009834 for 20 chunks
Stored wallet with cached payment proofs. New balance: 199.999941747
Uploaded chunk #2ee493.. in 1 seconds
Uploaded chunk #62b30c.. in 1 seconds
Uploaded chunk #be88d9.. in 2 seconds
Uploaded chunk #a1fa1d.. in 4 seconds
Uploaded chunk #156663.. in 2 seconds
Uploaded chunk #04037b.. in 2 seconds
Uploaded chunk #50f5f2.. in 4 seconds
Uploaded chunk #1720b1.. in 2 seconds
Uploaded chunk #8d7369.. in 8 seconds
Uploaded chunk #4bdd29.. in 4 seconds
Uploaded chunk #421c01.. in 2 seconds
Uploaded chunk #40e2a6.. in 3 seconds
Uploaded chunk #34aece.. in 6 seconds
Uploaded chunk #e8fce6.. in 8 seconds
Uploaded chunk #f6aadf.. in 8 seconds
Uploaded chunk #8ce49a.. in 6 seconds
Uploaded chunk #6d0d42.. in 4 seconds
Uploaded chunk #572786.. in 2 seconds
Uploaded chunk #94269c.. in 2 seconds
Uploaded chunk #43c469.. in 2 seconds
Uploaded 20 chunks in 87.4451001s. Current progress is 120/190.
Cannot get store cost for NetworkAddress::ChunkAddress(dd81e7(11011101).. -  - dd81e7576610eed5244961e8446627aa97c92f9b41c330d1a34874458574e91c) with error CouldNotSendMoney("Network Error Not enough store cost prices returned from the network to ensure a valid fee is paid.")
All transfers completed in 19.0626273s
Total payment: NanoTokens(12654) nano tokens for 19 chunks
Made payment of 0.000012654 for 20 chunks
Stored wallet with cached payment proofs. New balance: 199.999929093
Uploaded chunk #6b93cf.. in 1 seconds
Uploaded chunk #d14218.. in 1 seconds
Uploaded chunk #1e7093.. in 4 seconds
Uploaded chunk #eb81f1.. in 12 seconds
Uploaded chunk #c2e835.. in 5 seconds
Uploaded chunk #e268d5.. in 12 seconds
Uploaded chunk #275cb1.. in 9 seconds
Uploaded chunk #99697e.. in 5 seconds
Uploaded chunk #ef026d.. in 12 seconds
Uploaded chunk #a6179d.. in 10 seconds
Uploaded chunk #164ef3.. in 12 seconds
Uploaded chunk #40537c.. in 10 seconds
Uploaded chunk #3c1f95.. in 7 seconds
Uploaded chunk #b9ccb6.. in 7 seconds
Uploaded chunk #bcee0c.. in 12 seconds
Uploaded chunk #0cccfe.. in 10 seconds
Uploaded chunk #bb919c.. in 4 seconds
Uploaded chunk #bccc45.. in 4 seconds
Uploaded chunk #6afaab.. in 4 seconds
Uploaded 20 chunks in 90.8947775s. Current progress is 140/190.
All transfers completed in 22.6261576s
Total payment: NanoTokens(10662) nano tokens for 20 chunks
Made payment of 0.000010662 for 20 chunks
Stored wallet with cached payment proofs. New balance: 199.999918431
Uploaded chunk #20cae1.. in 2 seconds
Uploaded chunk #ff078d.. in 2 seconds
Uploaded chunk #771c44.. in 6 seconds
Uploaded chunk #dd00f7.. in 6 seconds
Uploaded chunk #330fc7.. in 6 seconds
Uploaded chunk #8d73dc.. in 6 seconds
Uploaded chunk #364f38.. in 19 seconds
Uploaded chunk #ee0837.. in 12 seconds
Uploaded chunk #99839c.. in 6 seconds
Uploaded chunk #984527.. in 13 seconds
Uploaded chunk #ceb15d.. in 21 seconds
Uploaded chunk #a6e451.. in 19 seconds
Uploaded chunk #858947.. in 6 seconds
Uploaded chunk #09dc94.. in 19 seconds
Uploaded chunk #062f32.. in 6 seconds
Uploaded chunk #603694.. in 6 seconds
Uploaded chunk #fb34a0.. in 6 seconds
Uploaded chunk #e30ecf.. in 28 seconds
Uploaded chunk #93e6a6.. in 7 seconds
Uploaded chunk #465ef6.. in 6 seconds
Uploaded 20 chunks in 109.7439673s. Current progress is 160/190.
All transfers completed in 25.027802s
Total payment: NanoTokens(10319) nano tokens for 20 chunks
Made payment of 0.000010319 for 20 chunks
Stored wallet with cached payment proofs. New balance: 199.999908112
Uploaded chunk #65a2e4.. in 2 seconds
Uploaded chunk #e44428.. in 2 seconds
Uploaded chunk #dd0ea2.. in 4 seconds
Uploaded chunk #446fe3.. in 2 seconds
Uploaded chunk #09379f.. in 2 seconds
Uploaded chunk #287f82.. in 2 seconds
Uploaded chunk #b9d6e5.. in 2 seconds
Uploaded chunk #fdb823.. in 3 seconds
Uploaded chunk #6c8039.. in 3 seconds
Uploaded chunk #f1cd7d.. in 10 seconds
Uploaded chunk #3192ec.. in 10 seconds
Uploaded chunk #08574d.. in 8 seconds
Uploaded chunk #f4e20a.. in 2 seconds
Uploaded chunk #6eabc9.. in 10 seconds
Uploaded chunk #1a04f2.. in 8 seconds
Uploaded chunk #0dae9a.. in 5 seconds
Uploaded chunk #e28cc1.. in 8 seconds
Uploaded chunk #8d9edd.. in 2 seconds
Uploaded chunk #4e73bb.. in 2 seconds
Uploaded chunk #c13863.. in 2 seconds
Uploaded 20 chunks in 93.1705451s. Current progress is 180/190.
Cannot get store cost for NetworkAddress::ChunkAddress(6a5010(01101010).. -  - 6a50109cb14c0a93821b4b56a8db0dd2f1d6741f757ebcb56c1974ed21bfc984) with error CouldNotSendMoney("Network Error Not enough store cost prices returned from the network to ensure a valid fee is paid.")
Cannot get store cost for NetworkAddress::ChunkAddress(e7f2ca(11100111).. -  - e7f2cab8787fab9e6beccb3952d347cbd29d06c7b6d49c5ffdee545916fc91f7) with error CouldNotSendMoney("Network Error Not enough store cost prices returned from the network to ensure a valid fee is paid.")
All transfers completed in 45.2143524s
Total payment: NanoTokens(3780) nano tokens for 8 chunks
Made payment of 0.000003780 for 10 chunks
Stored wallet with cached payment proofs. New balance: 199.999904332
Uploaded chunk #7ce6e5.. in 2 seconds
Uploaded chunk #1fc4a3.. in 2 seconds
Uploaded chunk #53843d.. in 2 seconds
Uploaded chunk #103c31.. in 3 seconds
Uploaded chunk #03653b.. in 2 seconds
Uploaded chunk #c07a80.. in 2 seconds
Uploaded chunk #40ccdb.. in 2 seconds
Uploaded chunk #9c1eb9.. in 1 seconds
Uploaded 10 chunks in 121.9084937s. Current progress is 190/190.
First round of upload complete. Verifying and repaying if required...
======= Verification: 190 chunks to be checked and repaid if required =============
Failed to fetch a chunk ChunkAddress(ebe3d2(11101011)..)
Failed to fetch a chunk ChunkAddress(316ad0(00110001)..)
Failed to fetch a chunk ChunkAddress(76a7fd(01110110)..)
Failed to fetch a chunk ChunkAddress(5d1821(01011101)..)
Failed to fetch a chunk ChunkAddress(dd81e7(11011101)..)
Failed to fetch a chunk ChunkAddress(e7f2ca(11100111)..)
Failed to fetch a chunk ChunkAddress(6a5010(01101010)..)
After 926.2734551s, verified 190 chunks
======= Verification: 7 chunks were not stored. Repaying them in batches. =============
Failed to fetch 7 chunks. Attempting to repay them.
All transfers completed in 19.5774926s
Total payment: NanoTokens(4446) nano tokens for 7 chunks
Uploaded chunk #5d1821.. in 1 seconds
Uploaded chunk #76a7fd.. in 1 seconds
Uploaded chunk #316ad0.. in 1 seconds
Uploaded chunk #ebe3d2.. in 1 seconds
Uploaded chunk #e7f2ca.. in 0 seconds
Uploaded chunk #dd81e7.. in 1 seconds
Uploaded chunk #6a5010.. in 1 seconds
Repaid and re-uploaded 7 chunks in 36.733534s
======= Verification: 7 chunks to be checked and repaid if required =============
After 75.7989916s, verified 7 chunks
All transfers completed in 22.3200193s
Total payment: NanoTokens(2481) nano tokens for 5 chunks
Uploaded chunk #e7f2ca.. in 1 seconds
Repaid and re-uploaded 7 chunks in 81.5281167s
After 82.066495s, verified 7 chunks
======= Verification: 5 chunks were not stored. Repaying them in batches. =============
Failed to fetch 5 chunks. Attempting to repay them.
Cannot get store cost for NetworkAddress::ChunkAddress(ebe3d2(11101011).. -  - ebe3d2d73027559a8f60c47cfdbd79d38f9447b76160e54058e51564a1f6a3f2) with error CouldNotSendMoney("Network Error Not enough store cost prices returned from the network to ensure a valid fee is paid.")
All transfers completed in 19.5590971s
Total payment: NanoTokens(1327) nano tokens for 3 chunks
Uploaded chunk #5d1821.. in 0 seconds
Repaid and re-uploaded 5 chunks in 56.2865481s
======= Verification: 5 chunks to be checked and repaid if required =============
After 13.0135812s, verified 5 chunks
======= Verification complete: all chunks paid and stored =============
Uploaded all chunks in 36 minutes 27 seconds
Uploaded VID_20210505_113014.mp4 to 9c1eb9226ab2bb720a3f79eeaa9adc76476eedc81cf82a7410296b9b7d0c113c
This is definitely wrong.
Glad you have it working. :clap:
@josh @Southside
This is great! Got it running. Just waiting for a good number of record entries to try the plotting.
I think this piece of work deserves it’s own Topic like Happybeing’s vDash.
Github is quite far behind at the moment, my apologies. (It will still work though)
I have been doing lots of yoyoing and feels silly pushing in that state.
Glad you got it working.
I will try to do better about keeping Github up to date. Hopefully today errr soon.
