Progress Reports
15/08/23
- All maidsafe nodes alive (2001) w/ healthy mem/cpu (40-70mb)
- Averaging ~200 records each. We have some 0 record nodes and are debugging based upon those logs. Some more ideas there.
- Payment/verification is quite buggy. This could be clients not getting a solid enough price eg. (We’re looking at different approaches here to solve this)
- Reuploading uses old, likely invalid/underpaying proofs. We’ll just disable reusing proofs to allow reuploads to work soon.
- Connecting is slow, we’ve a PR that helps a good bit here and will release a new client once that’s in.
- Store cost is being updated as expected
Original Post
When last we testnetted, we were checking that we could pay a default price for data. Now we have some rudimentary price discovery in place, nodes can report a price based upon how much relevant data they have stored, and clients will choose the lowest price that should ensure a majority of nodes will accept the data.
There’s also a few other minor tweaks in:
- fix to data distance calculations (which may have led to data loss)
- improvements to client (we now need only 8 nodes to connect)
- a no verify flag has been added to the CLI if folk want to test out not verifying data storage for speed, you can do so by adding
-nto your cli command.
Here though we’re testing:
- Data storage prices are paid and validated (
Verification fee:is the relevant log there.) - Data storage cost increases as the network fills
- Data which has been paid for remains on the network
We have not made any attempt to id rising mem reported in the past testnet, but we’ll appreciate more data there if folk are still seeing this.
Network Details
Node version: 0.88.30
Client version: 0.80.41
Faucet url: 134.122.106.147:8000
SAFE_PEERS: /ip4/134.122.106.147/tcp/41587/p2p/12D3KooWDSeWaBgxMiwboN8jktSaJLg4n8ETx9BuD3f1HiQFk3ka
Alternatives:
"/ip4/188.166.10.55/tcp/42223/p2p/12D3KooWNidFK1hSFpgqYsq7d4eY4iPGDUoZf12ipHz7v3gNFh4f"
"/ip4/165.22.38.231/tcp/43501/p2p/12D3KooWLSeE9TyK3BdzEaV3y6vdsprpC3jzT13gN5QjhCXCqSqc"
"/ip4/159.223.94.109/tcp/38537/p2p/12D3KooWBtxVrsyf3xqAGVGhVR5Qzp3pSnDw145uGFwF6V4yBxVd"
"/ip4/157.245.8.1/tcp/43763/p2p/12D3KooWFhPKWWQTcHnDf8R92xw3XwxTFmKqeMHo18SJuqNKrayM"
"/ip4/146.190.167.115/tcp/46673/p2p/12D3KooWLQkJM1Sh7zxiSwrrFeMZY44JfuDx1D7Dxcd5S4TsQp2V"
"/ip4/146.190.21.72/tcp/46145/p2p/12D3KooWSg7UtrgYgSaggD6eLJhGAtdKfmph6G1EoN4qomGhhS6R"
"/ip4/159.223.94.109/tcp/38893/p2p/12D3KooWH9KzdCR5ywyvzFsRCLgncxEBaFy71Euy8BXHqRTdFtpJ"
"/ip4/24.199.115.129/tcp/42629/p2p/12D3KooWLBit7Gkhxg9YmrBs6xs4pkgXrUae1Hn66YgbGpZDfFXQ"
"/ip4/164.92.101.248/tcp/40653/p2p/12D3KooWNP8YSq1EjACv9Rfad6Cuho9BZWHE1KfCFbBe9PU86Liw"
We have 100 droplets running a total of 2001 nodes. One droplet has 2vcpu and 4GB of memory.
Quickstart
safeup client --version 0.80.41
safeup node --version 0.88.30
Run a Node
Linux/macOS:
export SAFE_PEERS="/ip4/134.122.106.147/tcp/41587/p2p/12D3KooWDSeWaBgxMiwboN8jktSaJLg4n8ETx9BuD3f1HiQFk3ka"
SN_LOG=all safenode
Windows:
$env:SAFE_PEERS = "/ip4/134.122.106.147/tcp/41587/p2p/12D3KooWDSeWaBgxMiwboN8jktSaJLg4n8ETx9BuD3f1HiQFk3ka"
$env:SN_LOG = "all"; safenode
Connect to the Network
Linux/macOS:
safe wallet get-faucet 134.122.106.147:8000
Windows:
Further Information
Obtaining Binaries
Installing Safeup
Installing Binaries
safeup client --version 0.80.41 # get a specific version
safeup node --version 0.88.30 # get a specific version
Running a Node
# Linux/macOS
SN_LOG=all safenode
# Windows
This will output all the logs in the terminal.
Sometimes it will be preferable to output the logs to file. You can do this by running the node like so:
# Linux/macOS
SN_LOG=all safenode --log-output-dest data-dir
# Windows
$env:SN_LOG = "all"; safenode --log-output-dest data-dir
The location of data-dir is platform specific:
# Linux
# macOS
# Windows
# Linux/macOS
# Windows
Connecting as a Client
To connect, you must provide another peer, in the form of a multi address. You can find one in the ‘Network Details’ section at the top.
It is recommended to set the peer using the environment variable SAFE_PEERS. You can set this variable once and it will apply for the duration of your shell session:
# Linux/macOS
# Windows
NOTE: If you close and/or start a new shell session, you will be required to redefine this environment variable in the new session.
As an alternative to the environment variable, it’s also possible to use the --peer argument:
safe --peer="/ip4/134.122.106.147/tcp/41587/p2p/12D3KooWDSeWaBgxMiwboN8jktSaJLg4n8ETx9BuD3f1HiQFk3ka" ...
However, this requires specifying the peer with each command.
Using the Client
safe files download
# Linux
# macOS
# Windows
safe file download [directory/filename] [XORURL]
Troubleshooting
Cleanup
# Linux
rm -rf ~/.local/share/safe
# macOS
# Windows
