Another week, another wee testnet. We’re looking to verify various changes we’ve worked on since the last…
Most notably the pricing curve has changed, it’s now much more granular (a new price at each step) and stays cheaper for longer.
We also have various client improvements to reduce memory when working with larger files, and offer more control during uploads. As well as the total concurrency limit, which you can set with -c 10 (e.g., to allow for 10 concurrent uploads/queries), we have a --batch-size 10 argument, which defines how many chunks are paid for an uploaded together (this should have more impact on larger files… hopefully improving the success rate there). More examples of that below.
Our objectives:
- How does the client tolerance (currently 50% over the asking price) hold up?
- How are client up/download performing? (How do
concurrency, andbatch-sizeaffect errors here?) - Check register payments are working smoothly
It should be noted that while the client will currently repay if a PUT failed… it does not only pay the difference as yet. That’s still to come.
Network Details
Node version: 0.90.14
Client version: 0.81.44
Faucet url: 139.59.182.135:8000
SAFE_PEERS: /ip4/139.59.182.135/tcp/43953/p2p/12D3KooWFP9PfPoDeAtQU5Y9akqmciABu4AJqPsiA3WQTgDe5XHn
Alternatives:
"/ip4/174.138.95.28/tcp/42445/p2p/12D3KooWH9KeGXY6xYxp9aPy2WNR48XWo4ce17i4UdzmiR2nWi86"
"/ip4/64.227.157.116/tcp/35321/p2p/12D3KooWHo1u5VZ4KxMiHiVxy5xH2j5AgYvk18M5J5bJNZDKN4y6"
"/ip4/137.184.188.173/tcp/44513/p2p/12D3KooWBCEhQiahMb6zexVaJVquZZWyui1Dzz44uHLUXpx9uU3Q"
"/ip4/142.93.214.164/tcp/40253/p2p/12D3KooWB2sxFRaSV77jvmXiqwVFFF6bAXr1V7L3rmbVEkHGJq8c"
"/ip4/137.184.188.122/tcp/44133/p2p/12D3KooWKre2WdD2ScmJ1j4Cxh1dRFsTze1WYYkMqc8tQn6CtM7H"
"/ip4/64.227.132.205/tcp/37671/p2p/12D3KooWQVWBExLhXkmoQzARcGMv96fa7nj1tiFai4boQUKh5j8G"
"/ip4/139.59.120.201/tcp/39227/p2p/12D3KooWDppSnhhtZJdagspz6Vu7AmTR5Vc1zdN29eMu1vHS3azx"
"/ip4/159.223.229.32/tcp/37469/p2p/12D3KooWDN4sZAUuc4WqUj2LHo3i4mPWvTt22PWA4jXfQ1wmgkV4"
"/ip4/167.71.170.90/tcp/44331/p2p/12D3KooWDAAviAzBfSQBTRoXuQZw9ge1PLDY24ar8EsYFXuvjirV"
"/ip4/161.35.178.141/tcp/33119/p2p/12D3KooWRUd5BmFbqBBzRWb9uvwy1dWBdhzk2BGV7g5kN1sLjyzb"]
We have 2001 droplets running a total of 100 nodes. One droplet has 2vcpu and 4GB of memory.
Quickstart
safeup client --version 0.81.44
safeup node --version 0.90.14
Run a Node
Linux/macOS:
export SAFE_PEERS="/ip4/139.59.182.135/tcp/43953/p2p/12D3KooWFP9PfPoDeAtQU5Y9akqmciABu4AJqPsiA3WQTgDe5XHn"
SN_LOG=all safenode
Windows:
$env:SAFE_PEERS="/ip4/139.59.182.135/tcp/43953/p2p/12D3KooWFP9PfPoDeAtQU5Y9akqmciABu4AJqPsiA3WQTgDe5XHn"
$env:SN_LOG = "all"; safenode
Linux/macOS:
safe wallet get-faucet 139.59.182.135:8000
Windows:
$env:SAFE_PEERS = "/ip4/139.59.182.135/tcp/43953/p2p/12D3KooWFP9PfPoDeAtQU5Y9akqmciABu4AJqPsiA3WQTgDe5XHn"
To do this with non-default concurrency or batch-sizes (along with SAFE_PEERS set as above):
safe files upload -c 10 --batch-size 40 <directory-path>
10 and 40 being the integer values you want to set for each
Further Information
Obtaining Binaries
Installing Safeup
Installing Binaries
safeup client --version 0.81.44 # get a specific version
safeup node --version 0.90.14 # get a specific version
Running a Node
# Linux/macOS
SN_LOG=all safenode
# Windows
This will output all the logs in the terminal.
Sometimes it will be preferable to output the logs to file. You can do this by running the node like so:
# Linux/macOS
SN_LOG=all safenode --log-output-dest data-dir
# Windows
$env:SN_LOG = "all"; safenode --log-output-dest data-dir
The location of data-dir is platform specific:
# Linux
# macOS
# Windows
# Linux/macOS
# Windows
Connecting as a Client
To connect, you must provide another peer, in the form of a multi address. You can find one in the ‘Network Details’ section at the top.
It is recommended to set the peer using the environment variable SAFE_PEERS. You can set this variable once and it will apply for the duration of your shell session:
# Linux/macOS
# Windows
NOTE: If you close and/or start a new shell session, you will be required to redefine this environment variable in the new session.
As an alternative to the environment variable, it’s also possible to use the --peer argument:
safe --peer="/ip4/139.59.182.135/tcp/43953/p2p/12D3KooWFP9PfPoDeAtQU5Y9akqmciABu4AJqPsiA3WQTgDe5XHn" ...
However, this requires specifying the peer with each command.
Using the Client
safe files download
# Linux
# macOS
# Windows
safe file download [directory/filename] [XORURL]
Troubleshooting
Cleanup
# Linux
rm -rf ~/.local/share/safe
# macOS
# Windows
