It does indeed! ![]()
Here is a suggestion from something I’ve encountered: If you are trying to start up a lot of nodes on a machine bear in mind that there is a ‘hump’ in the amount of RAM that a safenode uses as it starts up.
I’d been running 50 nodes on a AWS t4g.medium which has 4GB RAM. There was plenty left after a whole day of running because the memory leak seems to be partially fixed. So when it crashed because it ran out of disk space (doh!) I thought I’d start up 100 this time. I thought it could accommodate that. I started the 100 and went to bed.
I found in the morning that there were only 61 nodes running. It looked like the cull of nodes had happened really soon after they were started. I started them again and watched what happens. As a node starts it’s RAM usage balloons from about 40MB to more than 100MB over a few minutes before falling back to a much more reasonable level after about 5 minutes.
I’d been starting them with a 5 sec delay using:-
#!/bin/bash
for i in {1..100}
do
SN_LOG=all $HOME/.local/bin/safenode --log-output-dest=$HOME/.local/share/safe/node/$i --root-dir=$HOME/.local/share/safe/node/$i &
sleep 5
done
to be kind to it because I thought that would be plenty of time for it to open the log file and deal with the initial flood of activity. But that didn’t take into account the ballooning of RAM usage. So I’m now starting up 100 with a whole 60 seconds delay between each. That seems to be enough to stop the machine running out of RAM and killing processes.
Here is the output of top showing safenodes ordered by Process ID. That shows this ballooning up and down as the safenode ages over the first few minutes because each safenode was started at a 1 min interval here. ‘RES’ is the column to look at.
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
13837 ubuntu 20 0 59244 43624 6528 S 87.0 1.1 0:05.78 safenode
13830 ubuntu 20 0 78544 66884 6528 S 0.0 1.7 0:18.17 safenode
13816 ubuntu 20 0 112452 100128 6528 S 0.0 2.5 0:42.10 safenode
13809 ubuntu 20 0 112492 100628 6528 S 0.0 2.6 0:38.65 safenode
12766 ubuntu 20 0 103424 91604 6400 S 0.3 2.3 0:28.22 safenode
11882 ubuntu 20 0 106312 94508 6400 S 7.7 2.4 0:26.45 safenode
6344 ubuntu 20 0 64932 53956 6528 S 0.7 1.4 0:20.39 safenode
6291 ubuntu 20 0 63276 51708 6528 S 0.3 1.3 0:36.89 safenode
6282 ubuntu 20 0 70672 59036 6400 S 1.0 1.5 0:49.90 safenode
6276 ubuntu 20 0 73744 62116 6528 S 1.0 1.6 0:45.07 safenode
6270 ubuntu 20 0 64040 52580 6400 S 0.7 1.3 0:35.59 safenode
6264 ubuntu 20 0 76448 65168 6528 S 0.3 1.7 0:52.16 safenode
6258 ubuntu 20 0 75416 64100 6528 S 1.0 1.6 0:39.72 safenode
6252 ubuntu 20 0 57748 46464 6400 S 0.0 1.2 0:24.11 safenode
6246 ubuntu 20 0 61132 50020 6528 S 0.0 1.3 0:34.66 safenode
6240 ubuntu 20 0 68976 57648 6400 S 1.0 1.5 0:40.03 safenode
6234 ubuntu 20 0 65084 53900 6528 S 3.0 1.4 0:35.32 safenode
6227 ubuntu 20 0 61732 50552 6400 S 3.3 1.3 0:32.65 safenode
6207 ubuntu 20 0 65612 53920 6400 S 0.3 1.4 0:43.39 safenode
6201 ubuntu 20 0 64272 52956 6528 S 0.3 1.3 0:44.75 safenode
6195 ubuntu 20 0 69116 57788 6400 S 0.3 1.5 0:47.00 safenode
6188 ubuntu 20 0 62420 51244 6400 S 0.7 1.3 0:37.43 safenode
6181 ubuntu 20 0 68720 57352 6400 S 0.3 1.5 0:43.04 safenode
6174 ubuntu 20 0 65032 53936 6528 S 1.0 1.4 0:45.15 safenode
6168 ubuntu 20 0 64776 53820 6528 S 0.0 1.4 0:37.86 safenode
6162 ubuntu 20 0 68604 56940 6528 S 0.3 1.4 0:50.35 safenode
EDIT:
I don’t know what I was thinking! How was 100 nodes using about 50MB each ever going to fit into 4GB RAM?! I’m no more alert than when I went to bed! I’ll start again with a lower number. Sorry for the churn!
But I think there is still value in a longer delay between starting nodes if RAM is in any way ‘tight’ because of this ballooning effect.
I think I’ve spotted a UX bug in ‘safe wallet send’.
safe wallet send -h
states it sends 1 nano:-
**Usage:** **safe wallet send** [OPTIONS] <amount> <to>
**Arguments:**
<amount> The number of nanos to send
<to> Hex-encoded public address of the recipient
But it seems to send a whole (toy money) 1 SNT:-
ubuntu@ip-172-30-1-42:~/scripts$ safe wallet balance
Built with git version: 26c3d70 / main / 26c3d70
97.997821493
ubuntu@ip-172-30-1-42:~/scripts$ safe wallet send 1 81d9fcd8f4bce7b8d30becc15d989f707f7dfb28aedc0d06145d90d8592ef854a15a0e9e8d832f6017feaa9b946f79fd
🔗 Connected to the Network Sent Token(1000000000) to PublicAddress(PublicKey(01d9..e0ca))
Successfully stored wallet with new balance 96.997821493.
Successfully stored new dbc to wallet dir. It can now be sent to the recipient, using any channel of choice.
96.997821493
Good spot.
Idk, I have a fairly decent connection 500/500 and it seems to me that I get the worst mileage here of all participants.
For instance, last test, I tried many times to upload buck bunny without any success but while I was trying @Aragorn succeeded.
This test I couldn’t get anything larger than 10MB up.
(Tried all kinds of concurrency/batch combos)
Not moaning, I know it is being worked on ![]()
Available CPU power and bandwidth can change drastically
in time, test on startup doesn’t do much (especially for mobile devices).
Packetloss, jitter, latency, antiviruses,… There are lot of factors, that can make “good” node perform badly.
That doesn’t make sense. Test on setup can inform a lot. Into the future as well as concurency and batch-size can be increased even further for greater performance. Ignoring this pre-test will lead to either having ultra-conservative settings for everyone or failures.
BTW, these tests are EASY to do.
I have to say, I’d rather opt for decent defaults, but give users the control to change things. Adding in tests/confirming/validating tests, applying those to settings is so many more steps to go wrong.
PRs are very welcome
Grandma can’t. KISS is great for engineers, but needs to apply to average users too.
After launch I will support this if it’s needed.
Grandma doesn’t need to would be the point here, I think?
Honestly I think it’s too early to worry about needing to do this. There will be reasonable defaults that work for the vast majority of users. We’re still dealing with bugs around storecost in this testnet. To try and fix anything that’s occurring because of that doesn’t make a heap of sense.
I imagine it should only be powerusers looking to eke out maximum speed etc that would need to tweak any settings.
The point I’m making is that average users need something that just works but is also competitively performant. Else they won’t use the product and so the network won’t grow.
I agree, who knows how things will develop between now and launch.
After launch we will see where things are and where we can add enhancements to bring in more users.
Indeed, me too.
I just downloaded everything I had uploaded. The files I had uploaded several times, also downloaded several times. The same file with same address repeatedly. Why is this? Is it just that it is mentioned several times in a list of files? Or is deduplication not working?
I started upload of a large file last night with -c 200 -batch-size 2 – which is what has been working for me consistently and it worked again with the large file.
So now I’ve uploaded a lot of small files, a few medium sized files and one large file all without any problems or need to retry (uploaded on first round).
First round of upload completed, verifying and repaying if required...
======= Verification: 1659 chunks to be checked and repayed if required =============
======= Verification Completed! All chunks have been paid and stored! =============
Uploaded all chunks in 832 minutes 8 seconds
Weird. I will try downloading now and see what happens.
I think that each time you upload it creates a file in the folder “uploaded files” that contains the info used to download. So I believe what is happening is that since you uploaded several times it’s created multiple copies of that file - and when you download it’s just downloading what is in those files - hence you are downloading multiple times.
None of this is related to deduplication though.
Yeah, I think that is the case. BTW, would be cool to have that list in a human readable form.
I think this. It’s not the network, but the how we’re storing what you write to the network on your local system. Each upload cmd writes a file atm.
There’s work in flight to improve this.
also this
I’m not sure if it’ll be today or tomorrow as i’m battling a broken release process just now,
but I intend to bring this down as soon as we can get another up to test fixes to the client upload / not enough storecost bug.
(We’ve a fix in which should make using updated clients smoother with future networks too; right now they are very strictly version locked which prevents us using a new one here so we’ll have to start fresh
I tried downloading all of my uploads and all went well except the one large file.
Chunks error Not all chunks were retrieved, expected 1658, retrieved 1514, missing ... (list of chunks omitted)
Given it took quite a long time to do the download I’m not going to try again.
There doesn’t seem to be any log for the download. So not sure what went wrong.
I found it too.
15 days ago…
