After the last IntolerantNodeNet, we’re looking more concretely at the client. One part of the last testnet was aiming to see how clients performed with the concurrency and batch-size arguments, but a bug in StoreCost retrieval largely scuppered that effort.
Here we want to:
- Confirm our fix is in place for that.
- Further explore how concurrency and batch size affect uploads.
- Start to look at how kad caching affects downloads of popular data.
In addition to some smaller fixes, we now have a new human readable client uploads file, which should make it clearer where your files live on the network
Network Details
Node version: 0.90.34
Client version: 0.82.3
Faucet url: 139.59.175.64:8000
SAFE_PEERS: /ip4/139.59.125.187/tcp/35163/p2p/12D3KooWE75czdXUnZJ59gtMDwNZCyBx24whf9WXbNTmEoCaiUrA
Alternatives:
"/ip4/142.93.232.219/tcp/38095/p2p/12D3KooWLAX6Z1m5gNxPGZQRV6VEzCtipNGcP1YhrAYNYT3yq5mv"
"/ip4/64.227.158.176/tcp/34893/p2p/12D3KooWG3cHz8aM9Zf2Gyar7NBb2BZ2wfcBf1zY7PHuUtn3EkvL"
"/ip4/147.182.237.224/tcp/46429/p2p/12D3KooWFCbRRe6GoyTvgbVqDK7VnD3TwEsM2876pBzuB1G3KHKj"
"/ip4/139.59.125.187/tcp/33641/p2p/12D3KooWNUNgbhC2zEUNVJzn72BxD4ooZ7kTE4NSa3pCmcGobGQj"
"/ip4/142.93.76.173/tcp/41717/p2p/12D3KooWJ51eYsdyksy87PazS3M7wRVdPNJWfH58u8fxBk2Y9hdp"
"/ip4/142.93.76.173/tcp/46229/p2p/12D3KooWQi1eeRbwtRWRvYTSQ2gSKt6M8QjseS65Hwzb7PDGKghE"
We have 101 droplets running a total of 2001 nodes. One droplet has 2vcpu and 4GB of memory.
Quickstart
safeup client --version 0.82.3
safeup node --version 0.90.34
Run a Node
Linux/macOS:
export SAFE_PEERS="/ip4/139.59.125.187/tcp/35163/p2p/12D3KooWE75czdXUnZJ59gtMDwNZCyBx24whf9WXbNTmEoCaiUrA"
SN_LOG=all safenode
Windows:
$env:SAFE_PEERS="/ip4/139.59.125.187/tcp/35163/p2p/12D3KooWE75czdXUnZJ59gtMDwNZCyBx24whf9WXbNTmEoCaiUrA"
$env:SN_LOG = "all"; safenode
Linux/macOS:
safe wallet get-faucet 139.59.175.64:8000
Windows:
[ In case of failure to connect to the network you may need to set the peers with:
$env:SAFE_PEERS = "/ip4/64.227.158.176/tcp/34893/p2p/12D3KooWG3cHz8aM9Zf2Gyar7NBb2BZ2wfcBf1zY7PHuUtn3EkvL" ]
To do this with non-default concurrency or batch-sizes (along with SAFE_PEERS set as above):
safe files upload -c 10 --batch-size 40 <directory-path>
10 and 40 being the integer values you want to set for each
Further Information
Obtaining Binaries
Installing Safeup
Installing Binaries
safeup client --version 0.82.3 # get a specific version
safeup node --version 0.90.33 # get a specific version
Running a Node
# Linux/macOS
SN_LOG=all safenode
# Windows
This will output all the logs in the terminal.
Sometimes it will be preferable to output the logs to file. You can do this by running the node like so:
# Linux/macOS
SN_LOG=all safenode --log-output-dest data-dir
# Windows
$env:SN_LOG = "all"; safenode --log-output-dest data-dir
The location of data-dir is platform specific:
# Linux
# macOS
# Windows
# Linux/macOS
# Windows
Connecting as a Client
To connect, you must provide another peer, in the form of a multi address. You can find one in the ‘Network Details’ section at the top.
It is recommended to set the peer using the environment variable SAFE_PEERS. You can set this variable once and it will apply for the duration of your shell session:
# Linux/macOS
# Windows
$env:SAFE_PEERS = "/ip4/139.59.125.187/tcp/35163/p2p/12D3KooWE75czdXUnZJ59gtMDwNZCyBx24whf9WXbNTmEoCaiUrA"
NOTE: If you close and/or start a new shell session, you will be required to redefine this environment variable in the new session.
As an alternative to the environment variable, it’s also possible to use the --peer argument:
safe --peer="/ip4/139.59.125.187/tcp/35163/p2p/12D3KooWE75czdXUnZJ59gtMDwNZCyBx24whf9WXbNTmEoCaiUrA" ...
However, this requires specifying the peer with each command.
Using the Client
safe files download
# Linux
# macOS
# Windows
safe file download [directory/filename] [XORURL]
Troubleshooting
Cleanup
# Linux
rm -rf ~/.local/share/safe
# macOS
# Windows
