After a successful DialNet we’re looking to test our reworked payment process. Now instead of badly guesstimating costs on the network, we ask each and every node how much they’d like and pay that. (This can be tweaked to avoid bad actors easily enough). As such, every node will receive rewards for PUTs directly!
(Note: you won’t get a reward for every chunk you’re expected to hold, they are only paid at PUT time, not replication, to keep things simple… but you can expect to be rewarded on an ongoing basis as you accept new chunks and the network grows.)
As well as this, we’ve a bit more logging around putting data, together with a new --concurrency option on the CLI which allows users to decide how much work to do concurrently when they upload data. The default -c value is 5, more will upload more chunks and payments at the same time. The same can be set for downloads. High values here will require more client resources.
eg: safe files -c 10 upload <dir> will set a concurrency value of 10 for the client.
Here we’re aiming to:
- Verify the stability of pay-each-holder approach
- Verify Node Rewards are being received and can be queried
- Shake out any bugs in this process
Network Details
Node version: 0.89.16
Client version: 0.81.16
Faucet url: 139.59.181.245:8000
SAFE_PEERS: /ip4/139.59.181.245/tcp/37569/p2p/12D3KooWPHE8qcKL4CB2n8QvPpE25TRsP9nmkfeM6Qa61aAsokib
Alternatives:
"/ip4/159.65.7.57/tcp/35367/p2p/12D3KooWL7A4j2PoZyXaiwhPxZaHcPvjNfejNgQL1BBeqV3S6bZW"
"/ip4/164.92.213.254/tcp/37491/p2p/12D3KooWJWvSH6cmg1HfskNB4PPkdfpnpqn9Z1MTtZ9ZvEEfx9pf"
"/ip4/146.190.136.181/tcp/35307/p2p/12D3KooWBWHFijhdKD2BmCqm3bn5oChXGJM1Xm2n8qw9GK6tvsD7"
"/ip4/68.183.84.0/tcp/41255/p2p/12D3KooWA1KDD7cyVzcwuPkCG4PjH4y9FzUf1qbd2mFeFK2BGJFU"
"/ip4/68.183.95.91/tcp/39401/p2p/12D3KooWMTDY3NdCB6TeQT3ZE3MHTjU9i9gJz552r7UUawi1wa96"
"/ip4/178.128.209.237/tcp/33447/p2p/12D3KooWJvW634Lfd7b5N4vRievDEXaxtnSR5msLm9WiHAKsVa34"
"/ip4/146.190.136.181/tcp/36513/p2p/12D3KooWCtPdWgn82hSVTqW7kYGhVx6SED75uEcziiWtTZtS9CiJ"
"/ip4/24.199.126.17/tcp/34181/p2p/12D3KooWMzWbX6oZtNidygRYwDwD2ykaosQsDk6m7GebrjWhDac3"
"/ip4/164.92.213.254/tcp/39861/p2p/12D3KooWGpXcWh7mhcKHXiSZRQE1cAkqpHMEB82SvqsJKF8VGdqP"
We have 101 droplets running a total of 2001 nodes. One droplet has 2vcpu and 4GB of memory.
Quickstart
safeup client --version 0.81.16
safeup node --version 0.89.16
Run a Node
Linux/macOS:
export SAFE_PEERS="/ip4/139.59.181.245/tcp/37569/p2p/12D3KooWPHE8qcKL4CB2n8QvPpE25TRsP9nmkfeM6Qa61aAsokib"
SN_LOG=all safenode
Windows:
$env:SAFE_PEERS="/ip4/139.59.181.245/tcp/37569/p2p/12D3KooWPHE8qcKL4CB2n8QvPpE25TRsP9nmkfeM6Qa61aAsokib"
$env:SN_LOG = "all"; safenode
Linux/macOS:
safe wallet get-faucet http://139.59.181.245:8000
Windows:
$env:SAFE_PEERS = "/ip4/139.59.181.245/tcp/37569/p2p/12D3KooWPHE8qcKL4CB2n8QvPpE25TRsP9nmkfeM6Qa61aAsokib"
Further Information
Obtaining Binaries
Installing Safeup
Installing Binaries
safeup client --version 0.81.16 # get a specific version
safeup node --version 0.89.16 # get a specific version
Running a Node
# Linux/macOS
SN_LOG=all safenode
# Windows
This will output all the logs in the terminal.
Sometimes it will be preferable to output the logs to file. You can do this by running the node like so:
# Linux/macOS
SN_LOG=all safenode --log-output-dest data-dir
# Windows
$env:SN_LOG = "all"; safenode --log-output-dest data-dir
The location of data-dir is platform specific:
# Linux
# macOS
# Windows
# Linux/macOS
# Windows
Connecting as a Client
To connect, you must provide another peer, in the form of a multi address. You can find one in the ‘Network Details’ section at the top.
It is recommended to set the peer using the environment variable SAFE_PEERS. You can set this variable once and it will apply for the duration of your shell session:
# Linux/macOS
# Windows
NOTE: If you close and/or start a new shell session, you will be required to redefine this environment variable in the new session.
As an alternative to the environment variable, it’s also possible to use the --peer argument:
safe --peer="/ip4/139.59.181.245/tcp/37569/p2p/12D3KooWPHE8qcKL4CB2n8QvPpE25TRsP9nmkfeM6Qa61aAsokib" ...
However, this requires specifying the peer with each command.
Using the Client
safe files download
# Linux
# macOS
# Windows
safe file download [directory/filename] [XORURL]
Troubleshooting
Cleanup
# Linux
rm -rf ~/.local/share/safe
# macOS
# Windows
