After a couple of weeks of looking to improve the how we utilise gossip and surrounding memory use, we’re back with another testnet.
Again, we’re primarily looking to verify that royalty payments are getting back to maidsafe nodes.
Other interesting updates since the last testnet was launched:
- We now only pay one node (the cheapest of 3 contacted)
- Nodes replicate on uploads
- Clients verify at least two nodes have data.
- Clients can resume/reuse chunking from cancelled/unsuccessful uploads
Node runners, please note: nodes now will be running with higher memory requirements than in non-gossip testnets, possibly reaching ~200mb/node
Network Details
Node version: 0.98.4
Client version: 0.85.13
Faucet url: 206.189.125.36:8000
We have 101 droplets running a total of 2001 nodes. One droplet has 4vcpu and 8GB of memory.
Quickstart
safeup client --version 0.85.13
safeup node --version 0.98.4
Run a Node
Linux/macOS:
safenode
Windows:
safenode
Linux/macOS:
safe wallet get-faucet 206.189.125.36:8000
Windows:
To do this with non-default batch-sizes (along with SAFE_PEERS set as above):
safe files upload --batch-size 40 <directory-path>
40 being the integer value you want to set
Further Information
Obtaining Binaries
Installing Safeup
Installing Binaries
safeup client --version 0.85.13 # get a specific version
safeup node --version 0.98.4 # get a specific version
Running a Node
# Linux/macOS
safenode
# Windows
safenode
This will output all the logs to the filesystem, with the location of logs being platform specific:
# Linux
# macOS
# Windows
# Linux/macOS
# Windows
Connecting as a Client
Using the Client
safe files download
# Linux
# macOS
# Windows
safe file download [directory/filename] [XORURL]
Troubleshooting
Cleanup
# Linux
rm -rf ~/.local/share/safe
# macOS
# Windows
or
rmdir C:\Users\<username>\AppData\Roaming\safe -r -Force
