ReduceConnectionsNet [ 06/12/23 Testnet] [Offline]
Yes, this did indeed work for me! Looks like the node stays up and is getting rewards, TY!
Logging to directory: "/home/tom/.local/share/safe/client/logs/log_2023-12-06_09-14-16"
Built with git version: 93a9010 / main / 93a9010
Node's rewards wallet balance (PeerId: 12D3KooWFWUQAtEPLDkerQ6wa9CyaP5Tgd8eE2J4haYCSJSWxnzj): 0.000000013
I’m not sure if there is some kind of difficulty between where you are and that S3 server, but that seems unlikely. The eu-west-2 region is located in London, as far as I’m aware.
To be quite honest with you, I’m not really sure what we could do about it. Other than perhaps considering replicating to other S3 buckets or providing an alternate download location, maybe on DO or something.
Edit: is it possible there could be an old version of OpenSSL on your machine or something? I’m not sure.
I’d recommend a range of ports so you can run multiple nodes
12000 and up has been kinda standard.
Personally when I could get NAT to work I had 12000-12050 assigned to one machine and 12051-12091 assigned to a second box.
If this is over-complicating it for you, ignore me and 9999 should do fine for a single instance
EDIT - just seen your earlier message - Welcome to the nodes from home party!! :confetti_ball: :laughing: :beers:
Thx super ants
Now test :beer: :beers: :partying_face:
“Ourwealth.mp4” 3c9a2c1f5ebaac543cd916241d2ada24888696fbd5a30da36f6bf2f49254cd1f
“The busy persons intro to LLMs.webm” 6c673b825760e616e2d41315216d1aeaecb8bc0011375987bd18718e73a1adf8
892e8923bce234fbfb069f1c647170b2 500m
Unlikely, I keep this Ubuntu updated and nothing else using ssh has shown problems.
Visiting this github link in the browser I have downloaded it but again it seems to be truncated very near the end (fails md5 and to unzip). I first tried curl with the same link and that ended instantly with a zero sized file. I don’t know why there’s a difference between the browser curl :man_shrugging:
I’ll try via my VPN as well…
With my VPN which runs on my cloud node I have it with safeup right away :crazy_face:
It may be that I normally had my VPN running when using safeup, I’m not sure.
Suggestion:
  • Hide non-essential CLI output (such as the long list of peers) behind a --verbose option.
Typo I expect but latest is 0.86.44
Well spotted. It wasn’t a typo but I don’t understand how I got that version as I’ve only been copying and pasting from the OP but my history suggests otherwise. :confused: That explains why the faucet is failing so I’ll delete that post pending getting the client installed.
Nodes running with nice and small memory footprint.
Uploading seems to have improved.
Downloading maybe a bit limited by the 16 batch size? I’ll try with different values.
Wow, well done Team!
Still probs with the faucet after removing the client directory and a successful install of the client $ safe -V / sn_cli 0.86.44:
$ safe wallet get-faucet 157.245.34.131:8000
Logging to directory: "/home/mrh/.local/share/safe/client/logs/log_2023-12-06_16-49-40"
Connecting to the network w/peers:
[snip]
🔗 Connected to the Network        Error:
   0: MsgPack deserialisation error:: invalid type: integer `0`, expected struct KeyLessWallet
   1: invalid type: integer `0`, expected struct KeyLessWallet
   sn_cli/src/subcommands/wallet.rs:229
I’m getting the same error from my home client. Fine with my cloud instance.
such error happens mostly when there is existing wallet, from previous runs.
better check the client folder and ensure there is no existing wallet folder inside.
Yes I just had another clearout and it’s working now.
I’ve been uploading for a couple of hours now. All seems to be going well. Started a big one just now so will check out and count sheep for a bit.
Good job team! :beers:
Yep, I mistyped my rm -rf path :blush:
download completed in 158s with the default 16 batch size.
video is playable with the file type set to rm
Ran a node for an up and down of a jpg. It works.
Two Neuromancers
"Neuromancer.mp4" 5c7d879e05592eeb6c0e80205159c75fbe6b5f7fe42f7c3504721639fa1efe12
"Neuromancer.pdf"
5bcf1e6877e11496ca8b1286819df50e66a95867767f3cdc4e198a9293d4d47d
I would definitely go for ye olde worlde text version as it’s hard enough to follow as it is without having half of the descriptive passages missing as they are in the audio.
