Right now we have a suspicion from our log-diving that the high-mem nodes are those that subscribed to gossip for royalties. This testnet is aiming to probe that hypothesis by removing gossip royalties!
(Note: we have another approach to this lined up via DAG nodes, so it may well be we’d be doing this down the line anyway; at least now we can confirm something).
The aim here is largely to see if we have avoided such high memory nodes. We’ll also be trying to keep this up as new nodes are released once more! (Internal upgrade tests found some more errors in the last week, but it appears to be on the go). More will be reported on that front as/when we’ll be doing that.
Network Details
Node version: 0.104.18
Client version: 0.89.65
Faucet url: 64.227.32.230:8000
We have 51 droplets running a total of 2001 nodes. One droplet has 2vcpu and 4GB of memory.
Quickstart
safeup client --version 0.89.65
safeup node --version 0.104.18
Run a Node
Linux/macOS:
safenode
Windows:
safenode
Linux/macOS:
safe wallet get-faucet 64.227.32.230:8000
Windows:
To do this with non-default batch-sizes (along with SAFE_PEERS set as above):
safe files upload --batch-size 40 <directory-path>
40 being the integer value you want to set
Further Information
Obtaining Binaries
Installing Safeup
Installing Binaries
safeup client --version 0.89.65 # get a specific version
safeup node --version 0.104.18 # get a specific version
Running a Node
# Linux/macOS
safenode
# Windows
safenode
This will output all the logs to the filesystem, with the location of logs being platform specific:
# Linux
# macOS
# Windows
# Linux/macOS
# Windows
Connecting as a Client
Using the Client
safe files download
# Linux
# macOS
# Windows
safe file download [directory/filename] [NetworkAddress]
Troubleshooting
Cleanup
# Linux
rm -rf ~/.local/share/safe
# macOS
# Windows
