BasicEconomyTweaks [Early Technical Beta] [OFFLINE - see new beta test - part deux]
With Bbbadnet highlighting some of our bad node detection as… overzealous, and also tipping up an issue with the faucet (and restarting the faucet), we’ve made tweaks to improve pricing economics too.
Nodes will now start ramping up pricing earlier, hopefully to better push up rewards when we need new nodes.
The faucet now also will only output 1SNT as a gift. This might help prevent giant influxes of data for now. (We’ve also added some stiffer rate limiting there, discarding requests if the wallet is busy instead of enqueuing them in an effort to remove potential faucet-land issues.)
Network Details
Node version: 0.105.2
Client version: 0.90.2
Faucet url: 188.166.171.13:8000
We have 50 droplets running a total of 2001 nodes. One droplet has 2vcpu and 4GB of memory.
Quickstart
safeup client --version 0.90.2
safeup node --version 0.105.2
Run a Node
Linux/macOS:
safenode
Windows:
safenode
Linux/macOS:
safe wallet get-faucet 188.166.171.13:8000
Windows:
To do this with non-default batch-sizes (along with SAFE_PEERS set as above):
safe files upload --batch-size 40 <directory-path>
40 being the integer value you want to set
Further Information
Obtaining Binaries
Installing Safeup
Installing Binaries
safeup client --version 0.90.2 # get a specific version
safeup node --version 0.105.2 # get a specific version
Running a Node
# Linux/macOS
safenode
# Windows
safenode
This will output all the logs to the filesystem, with the location of logs being platform specific:
# Linux
# macOS
# Windows
# Linux/macOS
# Windows
Connecting as a Client
Using the Client
safe files download
# Linux
# macOS
# Windows
safe file download [directory/filename] [NetworkAddress]
Troubleshooting
Cleanup
# Linux
rm -rf ~/.local/share/safe
# macOS
# Windows
Pack the wind surfing equipment away @anon26713768 :stuck_out_tongue_winking_eye:
Time to test how much data can be sent to SN for 1 SNT :wink:
No Safe, no wave.
can we get a peer added to the OP for using safenode-manager ?
I milked 5 tokens from the faucet, and will be using barely 1 myself. So if we get faucet problems, you can ask some play money from me.
Actually, I’d like to send some to someone just to see again how it goes. So someone, give me your address!
I uploaded a folder of photos. It seemed to me like stalling after successful upload and in the end gave error:
Error:
   0: The local path "C:\\Users\\topia\\Karjalanruusu_kuvia" is already being tracked with Folder address: a2fcd89ad8fc55adcc8a34b8e6b8792676471494c02637d6dbc52894eb79ef3c87fdbdfa1c8937d6e7fa7c71adae55e9f918f5407a5d08fc34b40be328fbfd619956791e96fb9e25b111abf561fb2e8b
On a repeated upload the same error happens. I’m on a Windows machine.
:white_check_mark:
Solved myself: I guess the upload was succesfull and I just screwed something. Also, the folder cannot be uploaded again. If you want to update a folder, use the command:
 safe folders sync
b2081ffd3612084c0ae171035b72667cbd36ca84be805af724ce9da149773f0ea3e92eda01c7b1fab8059a9368c6e9e6
Please send 1 nan0 it’s enough for my full course meal
I get a virus warning on Windows 11, using PowerShell:
Program ‘safe.exe’ failed to run: Operation did not complete successfully because the file contains a virus or
potentially unwanted softwareAt line:1 char:1
  • safe wallet get-faucet 188.166.171.13:8000
At line:1 char:1
  •   + CategoryInfo          : ResourceUnavailable: (:) [], ApplicationFailedException
      + FullyQualifiedErrorId : NativeCommandFailed
Here you go:
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
Was this the first nano transaction on the network?
EDIT: of course not, the data itself has been that cheap…
You can always grab them here.
https://sn-testnet.s3.eu-west-2.amazonaws.com/network-contacts
Can a Node Manager nerd Please post a quickstart for using it on a cloud node before I get to my laptop. :pray:
Including where to get it!
For anyone wanting to get safenode manager (thanks @anon26713768 for the release link)…
UPDATE
First find the release you want from the release directory and get the link to the gzip archive. Then use curl to get it and extract as follows.
curl -OL https://github.com/maidsafe/safe_network/releases/download/sn-node-manager-v0.7.2/safenode-manager--x86_64-unknown-linux-musl.tar.gz
tar -xvf curl -OL safenode-manager--x86_64-unknown-linux-musl.tar
That should give you a file safenode-manager.
I’ll update this if I figure out how to do the rest but don’t want to spend time on this… ACTUALLY I’m gonna leave it and get back to code. If anyone wants to fill in the rest I’ll add it here for others.
About cheap, food got so cheap, because the alternative is us running our AIs with the task to create a replicator…
Thx 4 the meal
This is a known bug that has happened to me before, the interesting thing is that in the morning the safe.exe file was considered by Windows to be a Trojan and by the evening of the same day it was already an executable.
I see that again Win recognises it as a virus.
No Safe, no wave.
To simplify secure path I edited my sudoers
sudo safenode-manager add --count --peer --node-port <range>
sudo safenode-manager start
I’m now seriously considering upgrading to 8 Gbit/s so that my client/node can be useful for the Network. Funny part is my isp bill vs buying eMAID/MAID the latter seems most logic
This upload went super ant quick
“TheNetworkState.mp4” 85113e201e839c11c711eb4f681e51d3232657e06314ab94bba2d69bbedbe3c4
More logical but not as much fun :joy:
Are you talking about sudoers? the typing was driving me up the wall, that or searching command history which is never as short as you think it would be, then it becomes a case of it must be near may as well keep going :laughing: 350 keystrokes later…
Don’t want to be picky, but he said he wanted to go kitesurfing.
There is nothing that would stop be from a day‘s windsurfing. Kitesurfing? Meh…
The boss dragged me to the shops and out for lunch :sob:
