NoClientGossipDiscovery [24/11/23 Testnet] [Offline]
BUG! => I get the same error but uploading also fails because the client reports it was successful :man_facepalming: => BUG!
$ safe files upload safe-files/safenetwork2.mp4
[snip]
All files were already uploaded and verified
*          Uploaded Files            *
"safenetwork2.mp4" aab1360f225288179348d5aec3d44bf253025e967784a7c16c77cae1a3492bbf
failed here, too, on a 122nd of 124 chunks.
Josh is travelling so cc @chriso @qi_ma
This one is going great for me.
700 Mb upload:
safe files download "Eraserhead.avi" 2e769065063642a5d7cafe04d13e149a14aa11956b3ed2d7bb4eacaa17bd5df0
Nodes also doing well;
Timestamp: Fri Nov 24 09:15:09 EST 2023
Number: 0
Node: 12D3KooWEyrbXa5ozoumKcwkkMiSn159mEWfRiPvpCvrcknfEHvS
PID: 145576
Memory used: 41.4961MB
CPU usage: 0.4%
File descriptors: 513
Records: 0
Disk usage: 4.0K
Rewards balance: 0.000000000
Number: 1
Node: 12D3KooWLyPxBhYvPts6zBNZVdWF11dSAvehPqQHbXEAEvs2vx7G
PID: 145594
Memory used: 94.5898MB
CPU usage: 1.3%
File descriptors: 928
Records: 715
Disk usage: 347MB
Rewards balance: 0.000000057
Number: 2
Node: 12D3KooWBApM8uS3JgVZj9wCSjmpLvBnzYrXS7X3QkFvzBskiYXE
PID: 145614
Memory used: 79.7891MB
CPU usage: 1.8%
File descriptors: 850
Records: 866
Disk usage: 424MB
Number: 3
Node: 12D3KooWQXdz3dWNzeu8qPaADtseDZJYYHtNPJGTAM9diL3kLnet
PID: 145585
Memory used: 93.7148MB
CPU usage: 1.6%
File descriptors: 921
Records: 611
Disk usage: 297MB
Rewards balance: 0.000000131
Number: 4
Node: 12D3KooWS879yUtmknWn3AvHx2daMVgGqvk78uukXjKhonjWGkZD
PID: 145605
Memory used: 115.59MB
CPU usage: 1.6%
File descriptors: 1166
Records: 642
Disk usage: 313MB
Rewards balance: 0.000000265
Very encouraging :clap: :clap:
10 5 & 3 dont download the rest came down fine
Error downloading "10.mp3": Chunks error Chunk could not be retrieved from the network: 8482d1(10000100)...
Error downloading "05.mp3": Network Error Record was not found locally.
Error downloading "03.mp3": Chunks error Chunk could not be retrieved from the network: 243113(00100100)...
Thanks to all for checking the Bowie files. I’ll try uploading the offending tracks again later.
Tracks 1-4 are fine here, 5 and 7 definite fails.
RL is intervening again - Cloud nodes later, promise
try your sound track @Southside
safe files download Anarchy_in_the_Southside.mp3 eaa0b39813183323b491e6715a0b4ea9f3cfdeede6f04a73c5b849b5210ad20d
willie@gagarin:~$ mpg123 /home/willie/.local/share/safe/client/Anarchy_in_the_Southside.mp3
High Performance MPEG 1.0/2.0/2.5 Audio Player for Layers 1, 2 and 3
	version 1.29.3; written and copyright by Michael Hipp and others
	free software (LGPL) without any warranty but with best wishes
Directory: /home/willie/.local/share/safe/client/
Terminal control enabled, press 'h' for listing of keys and functions.
Playing MPEG stream 1 of 1: Anarchy_in_the_Southside.mp3 ...
MPEG 1.0 L III cbr128 44100 j-s
Title:   2 manky DJ's                                                      Artist: 2 manky DJ's
Comment:        Album:  Anarchy in the Southside !!
Year:        Genre:  GlasVagas
#WorksForMe
:man_facepalming:
Im sure i cleaned that out of the boilerplate. Just done that again now.
I’m not against it. It’s just remembering to get it in. I know you’ve an issue about some logs that’s been hanging about too. :expressionless: We’ll get there at some point.
I’m on the road atm, so will dig into this mayyybe over the weekend but most likely monday. (It’s a bit of a faff still, some more automation around this will be needed).
@happybeing can you confirm your client v? Some new tweaks to better use the quote setup went in, I’m not sure if it’ll be related. cc @Anselme
Same error:
Error downloading “L.Effondrement.S01E01.FRENCH.720p.WEBRip.x264-BRiNK.mkv”: Chunks error Chunk could not be retrieved from the network: 1bac99(00011011)…
On the other hand, the ubuntu.iso has downloaded correctly and at the maximum speed of my connection.
imagen
By the way, are there any plans to modify the algorithm to avoid, at least for large files, downloading the 5 copies?
who want some coins ?
or to send me some coins
b12adaf29732571912a07a0455128be2ca8421e2940b30f1e5e964eac360c12c27280e49f1372c4136fb723da325a3f0
I asked similar question already. There was no response.
One more thing that worked fine is canceling and re-starting uploads. I did several times CTRL+C on one upload, and in the end it finished fine. :+1:
Second and third upload, error…
Error downloading “prueba.mkv”: Chunks error Chunk could not be retrieved from the network: 311577(00110001)…
Error downloading “prueba2.mkv”: Chunks error Chunk could not be retrieved from the network: 20d967(00100000)…
Workaround in case you want to retry:
Delete the corresponding folder from safe/client/chunk_artifacts/paid directory. Then the upload starts again. I also deleted the file name from the uploaded files file, but I doubt that’s necessary.
Download error in most of the uploaded files. Only some of small size and few chunks has worked for me.
A pity…
Something happened.
Did anyone was able to figure out why node consumes such large amount of network traffic?
Looks like it is not chunk reads / writes. If not chunks, then what? Gossip?
Right now my node consumes ~3MB/s of receive bandwidth.
I saw jump in mem usage.
But usage stablized for my node afterwards.
~300 MB now.
