Hot on the heals of NoClientGossip, we’ve a tweaked version of the code which aims to improve the network discovery setup.
As mentioned in the update, it looks like some nodes did not know enough of the network, leading to assumptions of responsibility over more and more data, and so filling up and failing to store new data.
So here we want to keep testing uploads, royalties, and will be keeping an eye on how the kademlia network kbuckets fill up over time.
If you’re running a node, memory still looks to be in the 200-300 range.
And we’ve a sample 5gb file uploaded:
safe files download ubuntu.iso 3911604a5798de6e7f591a6c9e44097e9f4979c0a1ef439d02d17494d7f41886
Network Details
Node version: 0.98.32
Client version: 0.86.20
Faucet url: 167.71.141.88:8000
We have 101 droplets running a total of 2001 nodes. One droplet has 4vcpu and 8GB of memory.
Quickstart
safeup client --version 0.86.20
safeup node --version 0.98.32
Run a Node
Linux/macOS:
safenode
Windows:
safenode
Linux/macOS:
safe wallet get-faucet 167.71.141.88:8000
Windows:
To do this with non-default concurrency or batch-sizes (along with SAFE_PEERS set as above):
safe files upload -c 10 --batch-size 40 <directory-path>
10 and 40 being the integer values you want to set for each
Further Information
Obtaining Binaries
Installing Safeup
Installing Binaries
safeup client --version 0.86.20 # get a specific version
safeup node --version 0.98.32 # get a specific version
Running a Node
# Linux/macOS
safenode
# Windows
safenode
This will output all the logs to the filesystem, with the location of logs being platform specific:
# Linux
# macOS
# Windows
# Linux/macOS
# Windows
Connecting as a Client
Using the Client
safe files download
# Linux
# macOS
# Windows
safe file download [directory/filename] [NetworkAddress]
Troubleshooting
Cleanup
# Linux
rm -rf ~/.local/share/safe
# macOS
# Windows
