Our next testnet, MoreStabilityNet, is looking to see how node stability has been affected by recent fixes.
The NodeDiscoveryNet has done well, surfacing data all the way through, even though we lost 12/20 nodes per droplet due to excessive memory.
We’ve a few fixes in and more pending that should improve things here. And we’d like to see how this goes for our MaidSafe Digital Ocean droplets and for those starting nodes in the community.
With all that, our objectives for this testnet are relatively simple:
- Verify if we still have “lost nodes” and get more data there (we may be asking for some specific types of behaviour to be tested as we go foward).
For those wondering what a lost node might look like: It’s basically a node dying or being killed due to excessive memory usage (>400mb for a long time eg). If you’re only runnning a node at home, or one per machine, you should likely not see this. If you run many nodes per machine, it’s more likely that a spike might cause the operating system to kill your node.
Network Details
Node version: 0.86.25
Client version: 0.79.26
SAFE_PEERS: /ip4/176.58.124.107/tcp/44439/p2p/12D3KooWEwMPj64C1MXEKaCYHGgtMApNzzvoynfprLJRLfgfGo7G
Alternatives:
"/ip4/161.35.39.103/tcp/38297/p2p/12D3KooWCgxHVhPfSndYod2KzRivZF5AnF125R5WoZt5GbX7JMtB"
"/ip4/143.110.169.215/tcp/38247/p2p/12D3KooWHSrZhRZSstxdhHGU3Vfj6Czxp12zqepsLvhFEfGS9R5Q"
"/ip4/161.35.39.22/tcp/36197/p2p/12D3KooWT1ywindpChtzfaWHfCFWexGfxYG1AVNQxwyEwR2cZwR4"
"/ip4/165.232.101.63/tcp/46029/p2p/12D3KooWGEBCRAmekSwfa7yidNNYbXtRDh1JPP14mntgtJ1yGChb"
"/ip4/178.62.91.4/tcp/39243/p2p/12D3KooWGXKWUfiCvEevBaT9VnmR7qVihyQD1PaJThzG4LLewJCU"
"/ip4/165.232.101.62/tcp/34009/p2p/12D3KooWAUuNGrFXux6Fx9kJGSzRxM6fXr1ZBvjY64ujqx3MwjSv"
"/ip4/161.35.39.101/tcp/40003/p2p/12D3KooWEPNrJmZyhRyEqvFkSng8v4yVuQ1ZJDu2PerLRpaQkELH"
We have 100 droplets running a total of ~2000 nodes. One droplet has 2vcpu and 4GB of memory.
Quickstart
safeup client --version 0.79.26
safeup node --version 0.86.25
Run a Node
Linux/macOS:
SN_LOG=all safenode
Windows:
$env:SN_LOG = "all" ; safenode
Connect to the Network
Linux/macOS:
export SAFE_PEERS="/ip4/176.58.124.107/tcp/44439/p2p/12D3KooWEwMPj64C1MXEKaCYHGgtMApNzzvoynfprLJRLfgfGo7G"
Windows:
$env:SAFE_PEERS = "/ip4/176.58.124.107/tcp/44439/p2p/12D3KooWEwMPj64C1MXEKaCYHGgtMApNzzvoynfprLJRLfgfGo7G"
Further Information
Obtaining Binaries
Installing Safeup
Installing Binaries
safeup client --version 0.79.26 # get a specific version
safeup node --version 0.86.25 # get a specific version
Running a Node
# Linux/macOS
SN_LOG=all safenode
# Windows
$env:SN_LOG = "all"; safenode
This will output all the logs in the terminal.
Sometimes it will be preferable to output the logs to file. You can do this by running the node like so:
# Linux/macOS
SN_LOG=all safenode --log-output-dest data-dir
# Windows
$env:SN_LOG = "all"; safenode --log-output-dest data-dir
The location of data-dir is platform specific:
# Linux
# macOS
# Windows
# Linux/macOS
# Windows
Connecting as a Client
To connect, you must provide another peer, in the form of a multi address. You can find one in the ‘Network Details’ section at the top.
It is recommended to set the peer using the environment variable SAFE_PEERS. You can set this variable once and it will apply for the duration of your shell session:
# Linux/macOS
# Windows
NOTE: If you close and/or start a new shell session, you will be required to redefine this environment variable in the new session.
As an alternative to the environment variable, it’s also possible to use the --peer argument:
safe --peer="/ip4/176.58.124.107/tcp/44439/p2p/12D3KooWEwMPj64C1MXEKaCYHGgtMApNzzvoynfprLJRLfgfGo7G" ...
However, this requires specifying the peer with each command.
Using the Client
safe files download
# Linux
# macOS
# Windows
safe file download [directory/filename] [XORURL]
Troubleshooting
