NoClientGossipNet [22/11/23 Testnet] - [Offline]
In the past couple of testnets we’ve been verifying RoyaltyPayments have been processed and are being received at maidsafe controlled nodes.
That part of the testnets has been successful, though they haven’t been particularly usable for very long.
We’ve been debugging this, looking at memory issues in nodes etc. The last testnet had far too much replication, which has been dialed back. And we’ve been looking at an excess of connectivity…
It appears that clients may well have been inserting themselves into the gossip portion of the network, and so adding to the load for each and every node for each and every royalty payment.
Here we want to test out this theory with clients that are now refusing themselves from gossip. We’ll be evaluating the load at nodes as we progress.
In addition to this, there are a few other notable tweaks since the last testnet:
  • the default batch size has been increased (which should use a bit more client mem, but speed up uploads some)
  • royalty payments are now 15% of storage cost
  • replication has been dialed back from the previous excessive rate
If you’re running a node, memory looks to be in the 200-300mb range.
And we’ve a sample 5gb file uploaded:
safe files download ubuntu.iso 3911604a5798de6e7f591a6c9e44097e9f4979c0a1ef439d02d17494d7f41886
Network Details
Node version: 0.98.25
Client version: 0.86.13
Faucet url: 138.68.161.91:8000
We have 101 droplets running a total of 2001 nodes. One droplet has 4vcpu and 8GB of memory.
Quickstart
safeup client --version 0.86.13
safeup node --version 0.98.25
Run a Node
Linux/macOS:
safenode
Windows:
safenode
Linux/macOS:
safe wallet get-faucet 138.68.161.91:8000
Windows:
To do this with non-default concurrency or batch-sizes (along with SAFE_PEERS set as above):
safe files upload -c 10 --batch-size 40 <directory-path>
10 and 40 being the integer values you want to set for each
Further Information
Obtaining Binaries
Installing Safeup
Installing Binaries
safeup client --version 0.86.13 # get a specific version
safeup node --version 0.98.25 # get a specific version
Running a Node
# Linux/macOS
safenode
# Windows
safenode
This will output all the logs to the filesystem, with the location of logs being platform specific:
# Linux
# macOS
# Windows
# Linux/macOS
# Windows
Connecting as a Client
Using the Client
safe files download
# Linux
# macOS
# Windows
safe file download [directory/filename] [NetworkAddress]
Troubleshooting
Cleanup
# Linux
rm -rf ~/.local/share/safe
# macOS
# Windows
OK, It’s been like half an hour and nobody has said anything, so I’ll do it: FIRST!
Great thing to have a new testnet up! :tada:
Personally I’m going to focus more on the client work this time. That means uploading and downloading, and I’d like to encourage everybody on the forum to do so - even not-so-technoligically-oriented. It’s not so difficult. :vulcan_salute:
I’ll probably spin up a coupe of nodes too, but later. Actually everything is going to happen a bit later, I got to go to work now.
This :point_up_2:
Be along shortly with some nodes and a beg blag
Ok, found strange message:
“Repaid and reuploaded 223 chunks”
I’m not sure about that “Re” in conjunction with 223.
By the way, progress messages spam is still annoying.
With such fast scrolling of console it is very hard to read text messages.
I’ve found hack - it is possible to make screenshot and read it afterwards.
But it is better to make progress messages at least slower.
Or better use text rewrite features of console, like many other programs are doing.
I’m getting why more bandwidth is needed for upload - for redundancy purposes.
But why downloading 110 MB file uses 1002 MB of bandwidth?
It looks possible to download chunk from single node and only in case if it is corrupted, download it from other node.
faucet is down
🔗 Connected to the Network        Requesting token for wallet address: 90d3f1b7721b1a82b53bf190628d1c999eacfce61bea3d0a07f9387058b6c34db461b5975c3e0832fdd2d03398afaefc...
Failed to get tokens from faucet, server responded with: Failed to send tokens: Transfer Error Failed to send tokens due to The transfer was not successfully registered in the network: CouldNotSendMoney("Network Error Could not retrieve the record after storing it: 05d2f438ac4769474f553fa17e1d2510aad25aab2ab4dd7dafc36465599460a7(7a37b954504be063f0209e7b620b18a43175aaa35a5e147be8bd0123226664e0).").
Same - was working at first though.
Beg Blag test is a pass :slight_smile:
safe files download BegBlagandSteal.mp3 80744b3d25bab269cab54e8baccf4f54f1aa01615230b99171bc3576c1ca7230
we’re looking into this
Party time, the year of the testnets continues. :tada:
Pass it on the clients cannot be gossipers anymore, all the node gossipers need to get in on this juicy deal.
i could be part of the problem the script im running to start nodes on several different vps’s get some coins at the end of the script so could have had several requests for coins hitting it at the same time
it should be tolerant to this, we’ll see though, thanks for the heads up!
thanks to at @anon26713768 http://safe-oracle.ddns.net/
Jeez you lot are way ahead of me!
This thread It didn’t show up for me until just now, foul play… restart, restart :rofl:
Looks like nodes are not pruning data. Not 100% sure, but they’re erroring w/r/t fullness (and proximity to the data :thinking: )
That’s probably the faucet’s issue
Not sure how we’ve not seen this before, we’ve not touched anything here recently… :eyes:
