Can you type in type number of nodes at the top of the window?
Why the hell do I need discord to take part in this. Absolutely ridiculous. discord its a heap of spyware pish.
I sorted it - an early version was hiding somewhere.
Well, I cannot enter the number of nodes, and the up and down arrows do not work.
Thanks!
It said I’m not in. That must be because of using my Display name instead of Discord username when filling in the form. Now what?
I’m running node launchpad on a Rpi4 with a 64GB sd card. When I hit ctrl+G I can’t manage my nodes. It sais using 0 GB of 1 GB available space, this while I have 50 GB free space.
Anybody know how I can use the rest of my free space?
How else can I check if the nodes are working? The task manager shows that practically nothing is transmitted over the network…
Well, I’m certainly no expert in networking exe, but all I did was click at the top where to add the number of nodes, in my case 5, and hit return.
up running on my laptop, but my home/safe computer does this:
PS C:\windows\system32> node-launchpad
node-launchpad failed:
Error:
0: Failed to parse app data
it has been on safe pre beta but not shore how to reset…
I have nodes added but not started
should they automatically start?
Thanks, perhaps there is a problem with Launchpad in Win or there is some problem on my side although up to a certain point everything works…
Is anyone else having trouble typing the number of nodes and running them in Windows?
I provided both, because I wasn’t sure, but that may have confused it! I think we’ll get in, from what was being said.
I put two forms in, first with the wrong user name, then did it again with the correct one when i realized my mistake.
Added, but not started ![]()
Yeah, I accidentally filled out the form twice when it went live. I entered how much RAM I had the first time…realized my mistake…and then loaded the form again and entered my available storage.
We’ve got a fix coming for that in the morning!
Off to the races!
You're in the Beta Rewards Program, but I still need to get Nanos from your nodes.
Are you using a Windows computer or another OS? I tried restarting as admin but Launchpad still stops working when I want to select the number of nodes.
I’m getting the same on Linux (no AV). Nodes are sitting there not doing much.
