ThisIsNotBetaRewardsNet [Mini-Testnet 26/05/24] [Offline]
All the latest code. All the hottest fixes. And at least some of the beta reward tracking flow!
THIS IS NOT THE REAL DEAL. Do not get excited about anything beta-rewardsy happening early. We’re hope you can help us with some pre-flight checks of the flow here, that is all.
In this testnet we’re really just looking to asses:
  1. If folk can use the Node Launchpad to start nodes with a Discord Username (Windows users see notes below)
  2. Is that Discord Username tracked by the network properly
  3. We can see and perhaps generate a leaderboard from this!
With this we have most of the flow for the reward calculations (beyond some discord plumbing).
So please let us know if you have issues, UX woes, or node world problems.
This testnet might well be short lived.
Testing The Flow
So first, we’d like everyone who’s interested to try starting nodes inputting their Discord Username into the launchpad.
  1. O allows you to allocate resources
  2. D sets Discord Username
  3. ctrl+g actually starts the nodes (assuming the rest is set)
What is my Discord Username?
This is your username on discord. Note that it can be different from your display name on a particular server.
You can copy it from Discord by clicking your profile (bottom left) and then clicking your name just under the profile image. It’s the Username you see when you right click on your name in discord and copy your id. It’s also the number you see in the URL when you visit your profile on discord.
Note: Discord Usernames aren’t validated in the launchpad, so you’ll have to watch out for typos..
Once you have have entered your Discord Username, please comment it in the thread here.
What happens next?
Nodes will encrypt the discord id as metadata when forwarding rewards to the foundation.
The foundation DAG has the ability to decrypt this, and will allow us to collate stats on rewards being generated by nodes.
To enable this, we’ll periodically update the DAG node with shared discord ids (from this thread), which will allow us to see rewards being forwarded to the foundation key.
(For rewards to be generated, we’ll obviously need some data to be uploaded, so the faucet still exists here, and we’d encourage folk to use that as normal).
And then
We’ll report back here with any modicum of success or no!
Stretch goals (for advanced users):
There’s a potential fix in for some home node issues (we’re seeing a 2%->15% increase in success rates here). We’d be keen to know if anyone is seeing a lot of the follow error (searched for via ripgrep in the node logs dirs)
rg -c 'Dcutr with remote peer: PeerId\(".*"\) is: Ok' ./ --search-zip | awk -F: '{sum += $2} END {print sum}'
rg -c 'Dcutr with remote peer: PeerId\(".*"\) is: (Ok|Err)' ./ --search-zip | awk -F: '{sum += $2} END {print sum}'
Windows
For Windows users, the launchpad and/or node manager requires the availability of WinSW.
To do this:
  • Download the WinSW-x64.exe binary from here
  • Rename the downloaded binary to winsw.exe
  • Copy the binary to C:\Windows\system32 or another location that is on the system or user Path
The C:\Windows\system32 is just somewhere that is guaranteed for every Windows install.
Network Details
Launchpad version: 0.2.0
Node version: 106.5
Client version: 0.92.0
Faucet url: 161.35.173.105:8000
You should download the launchpad from here choosing your platform there.
We have 50 droplets running a total of 2001 nodes. One droplet has 2vcpu and 4GB of memory.
Quickstart
If you already have safeup, you can obtain the client binary:
safeup client --version 0.92.0
Linux/macOS:
safe wallet get-faucet 161.35.173.105:8000
Windows:
To do this with non-default batch-sizes (along with SAFE_PEERS set as above):
safe files upload --batch-size 40 <directory-path>
40 being the integer value you want to set
Further Information
Obtaining Binaries
Installing Safeup
Installing Binaries
safeup client --version 0.92.0 # get a specific version
Connecting as a Client
Using the Client
safe files download
# Linux
# macOS
# Windows
safe file download [directory/filename] [NetworkAddress]
Troubleshooting
Cleanup
# Linux
rm -rf ~/.local/share/safe
# macOS
# Windows
A pseudo betarewards then
The Americans will read this as
In this testnet we’re really just looking to arses:
I am confused, we may/can only use the lauchpad to participate?
Do you normally only show the client upgrade in the quickstart section?
discord user name for @aatonnomicc = timbobjohnes
did you use launchpad or safenode directly?
Discord username = joshclsn
Discord name JPL/mysterious_dragon_54020.
2 nodes marked as ‘added’ in the launchpad but no logs so far
I am testing it out on safe-node manager add --owner all my boxes are headless for my normal set up.
im also on a rubbish limited internet connection right now but ill try and start a single node on windows :slight_smile:
bloody Norton lets me get a virus last month and says nothing about it. but its all over safe node launcher
ohh my this is is pretty
that’s as far as I get unfortunately udp is blocked on the network I am on right now :frowning:
udp being blocked also spoils my wire guard fun as well :frowning:
Norton itself is malware in many peoples professional opinions. Ever tried to remove it, its harder than most malware to remove. And McAfee along with it. Both are riding on their 1990’s good names.
Go for something cheaper and better, even avast is 10, to 100 times better
I am happy to test that for this testnet but would prefer to use my current methods. I hope this is not a requirement.
I’m really sick of Norton I got that yahoo redirect virus a few months ago and it did sod all about it.
I downloaded and installed supper putty and next think I know I was in yahoo hell.
what would you recommend I don’t mind paying I just want a good antivirus ?
@maidsafe the launchpad could have a couple of improvements
  1. display the discord name once set. Want to be sure it is recorded. At this time the line at the bottom shows the key commands with setting the discord name but when set there is no indications that it has been set.
  2. adding 30 nodes left me with “please wait” for a long time, I ended up going to do some housework and came back to see 25 of the 30 running and last 5 “added”. What happened? Why not start the whole 30? Is it still starting them up? or what?
    It’s be nice if there is an indication of what went wrong and they were not started rather than nothing and just saying “added”
    And be nice if the “please wait” was changed to “Starting node# xx Please Wait”
I started using avast free a few years ago and it seems to be real good. There are others that like really good but the names elude me. I ended up paying for it to get the firewall that allows me to control individual applications. Currently only on my windows machines and block microsoft’s spying ip addresses and apps. One way to give middle finger to microsoft, their store cannot work on my machine, some tracking sites are blocked too. I plan to have pie hole on my “homelab” (stupid name but flavour of the month) network and will do that blocking there
BTW I don’t have microsoft login either, just local machine login
ill give Avast a go next time I format the windows pc
uploads are going up nice and fast
"BegBlagandSteal.mp3" 3509bad03dc869dec883c7b44662c3503d2517fa9e828bb64f4dbe719d3837bf
"AnarchyInTheSouthside.mp3" c0893739a688b739aac5b75ac845b6c428c21b73dc782352bb1ad529495a87af
"Deep Feelings Mix.mp3" 614cb5c5dd84e9e1db69ae6fea37f280fb20347d278fef1d154f12a46d21ec4f
"Best_CD_Ever.mp3" 560678b8585c48bc67b547b3dfc517eaac1a355323670ab6ea0b4e79877238ed
you can spin up nodes manually, but we’re interested in the launchpad process
(you can still set owner on the nodes, and give us that info as your discordid, that is valid)
We thought we’d remove the node instructions as we’re really wanting to focus on the launchpad process, but it’s the same as always for joining nodes.
Launchpad will be for non tech folk. Node-manager isn’t going anywhere.
That’s the first couple of ids added to the reward tracker. Showing 0 atm but the interval is a few mins before we recollect.
@anon26713768 @aatonnomicc Let me know a) if you are able to get rewards via the launchpad or b) if you launch nodes in the classic fashion w/ the same owner and they are earning.
Awesome, I gave getting it to work headless a go but I have thrown in the towel, if it can be done I couldn’t figure it out.
