is this live now ? or are we getting ready
This version of Launchpad is beautiful. I love the blue background and the general feel.
I;ve started the launcher without a code. Am i doing it right?
Going to put my discord username here for help. 000000219
Yes, for now no one has the code, we are waiting, there is a broadcast on Discord.
can we get some example how 5 nodes can affect memory, cpu, net speed?
intresting. Mine are not starting even after hitting ctrl+S
/rank on discord says I am not registered, but I guess the big red button needs to be pressed so will wait a bit.
How do we find out our rank on discord, or If we are even in wave 1. Autonomi Bot OfficialAPP does not seem to work, says Contact your channel admin.
Norton Commander ![]()
YES!!! That’s it!!! Beautiful. ![]()
If I choose 5 nodes at the beginning, can or how then add up more?
Is everything working for me?!
Will I get my nanos? ![]()
How did you launch the nodes? At my place Launchpad does not respond to any commands.
I also had it, and I restarted as an administrator. ![]()
Does not work. Trying to run on W11 with last launchpad
2024-06-04T20:47:26.536407Z DEBUG sn_peers_acquisition\src\lib.rs:184: Attempting to parse /ip4/134.209.183.241/udp/52503/quic-v1/p2p/12D3KooWDoKVe5p1opqW5zhdx5yFZN6uXirRivhptr9VC3rkoEdn
2024-06-04T20:47:26.536411Z DEBUG sn_peers_acquisition\src\lib.rs:154: Parsing a full multiaddr: “/ip4/134.209.183.241/udp/52503/quic-v1/p2p/12D3KooWDoKVe5p1opqW5zhdx5yFZN6uXirRivhptr9VC3rkoEdn”
2024-06-04T20:47:26.865412Z ERROR node-launchpad\src\components\home.rs:642: Error while maintaining 1 running nodes
0: e[91mFailed to add one or more servicese[0m
e[96mSuggestione[0m: However, any services that were successfully added will be usable.
2024-06-04T20:47:26.865437Z DEBUG node-launchpad\src\app.rs:137: HomeActions(StartNodesCompleted)
2024-06-04T20:47:26.865604Z INFO node-launchpad\src\components\home.rs:121: Loaded node registry. Running nodes: 0
2024-06-04T20:47:31.101377Z DEBUG node-launchpad\src\node_stats.rs:59: No running nodes to fetch stats from.
2024-06-04T20:47:36.104047Z DEBUG node-launchpad\src\node_stats.rs:59: No running nodes to fetch stats from.
2024-06-04T20:47:42.103668Z DEBUG node-launchpad\src\node_stats.rs:59: No running nodes to fetch stats from.
I’m not sure, I’m launching node-launchpad from the local safe directory trough Tilix. For me the the command work start with Ctrl B
im on 0.9.5
ubuntu@s00:~$ safenode-manager -V
sn-node-manager 0.9.5
What do I need to type to Discord to get the bot to respond if I’m in? @JimCollinson told it many times over in Discord today, but as a non-native in English, I just happen to have a hole or two in my vocabulary in that place… ![]()
You go into General-chat and type /rank to see your rank (if you’re lucky enough to be in) or /get-id to see your ID.
If you’re not in it will say “You’re not in the Beta Rewards Program yet.”
For me, Ctrl B works, even Ctrl G works, but I can’t select the number of nodes and I can’t execute any of them. ![]()
