Mine too with ports forwarded in the router, and I used to get instantly connected after node launch, but this network just does not work…
seems not.
PR is still not merged.
maybe due to a missing approval ?
looks like a version mismatch between client and nodes ?
maybe using old client ? or certain amount of nodes in the network not upgraded yet ?
Ten cloud nodes started manually, no activity:
After safeup update:
sn_cli 0.90.4
safenode cli 0.105.6
I believe everything on my box is on the right version:
paul@Vader:/var/log/safenode$ sudo ~/.local/bin/safenode-manager upgrade
[sudo] password for paul:
Upgrade Safenode Services
Retrieving latest version of safenode...
Latest version is 0.105.6
Downloading safenode version 0.105.6...
Download completed: /tmp/30d27d7e-7ce4-46d0-8a67-216499e3012c/safenode
✓ All nodes are at the latest version
That’s great.
However, I mean the nodes in network that run by others.
Is there a window of opportunity for nodes to upgrade, surely people cant wait days and be considered a good node.
No I just got up.
I have 5 running from home - no records yet but its only 10 mina
I’ll fire up a couple of VPSs shortly
Can anyone still upload download or transfer coins on this network ?
Hey everyone,
We’ve had some issues here with an unintentional breaking change that went in, with respect to protocol versions. This is likely the source of the problems with nodes not dialing out, and possibly other things. We actually had it on our list for a long time to put some backwards compatibility testing into CI, but with everything going on, it’s been hard to get to.
The solution should be to upgrade our own nodes, which I’m going to do shortly. I will keep this thread updated on the progress.
For now, you may want to wait until we’ve completed our upgrade, to see how things go after that.
sending tokens works at my end
Did you upgrade the client ?
Ok I’ll have a retry see how I get on I tried to send a coin to @raulillo and was unsuccessful
✓ safenode15 upgraded from 0.105.3 to 0.105.6
✓ safenode16 upgraded from 0.105.3 to 0.105.6
✕ safenode17 was not upgraded: Error: Text file busy (os error 26)
✓ safenode18 upgraded from 0.105.3 to 0.105.6
✕ safenode19 was not upgraded: Error: Text file busy (os error 26)
✕ safenode20 was not upgraded: Error: Text file busy (os error 26)
✓ safenode21 upgraded from 0.105.3 to 0.105.6
✓ safenode22 upgraded from 0.105.3 to 0.105.6
Not an issue I can’t fix, just reporting what happened when upgrading. Maybe a catch in the upgrade checker to retry on non-fatal issues?
I had that start the stopped ones like
sudo env "PATH=$PATH" safenode-manager start --service-name safenode17
once they are running again re run the upgrade and all should be well
if you give me a wallet address i can try sending you some token to verify that it’s working on your end
make it a 0.000000001 send don’t waste any incase it fails. if this network gets back in action i think every coin will be worth more than gold lol
932826f7b0af0e8a5d2903897cc2e2cf403d70a695e865cd8484df6af76f7aa900820135072ba91855010229918349e1
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
didn’t plan on being that cheap - but you’re right … just loosing the coin would be a pity -.-" …
Im in your debt kind sir but now I am gutted my other wallet with my treasury of 27 SNT home farmed organic tokens must be borked ![]()
🔗 Connected to the Network Successfully parsed transfer.
Successfully verified transfer.
Old balance: 0.000000000
New balance: 0.000000001
