Welcome to the our first attempt to have a couple of testnets running in parallel!
Here we have an alpha network, where we want to verify changes before we do a full release that would be compatible with the existing BasicEconomyTweaks network.
This is not expected to be a wildly long testnet. But participation here will help iron out any potential issues as/when we release new code compatible with BasicEconomyTweaks.
Right now, this alpha network is not compatible. We cannot cross the streams, any attempt to access it using BasicEconomyTweaks’s network-contacts eg, will result in errors (or it should).
Other info:
- Max chunk size: 500kb
- Max chunk count: 2048
- Storecost algo: Bases price off of relevant close chunks not total chunk count. (This should allow prices to shift as capacity shrinks/grows).
Network Details
Node version: 0.105.6-alpha.4
Client version: 0.90.4-alpha.5
Faucet url: 159.65.29.172:8000
We have 50 droplets running a total of 2000 nodes. One droplet has 2vcpu and 4GB of memory.
Quickstart
safeup client --version 0.90.4-alpha.5
safeup node --version 0.105.6-alpha.4
Run a Node
Linux/macOS:
safenode --peer /ip4/209.97.139.230/udp/59695/quic-v1/p2p/12D3KooWPTyqVdNzqcaeNGzjHA4nNnqJWkxU81gW7uBPYewu3jop
Windows:
Linux/macOS:
safe wallet get-faucet 159.65.29.172:8000
Windows:
To do this with non-default batch-sizes (along with SAFE_PEERS set as above):
safe files upload --batch-size 40 <directory-path>
40 being the integer value you want to set
Further Information
Obtaining Binaries
Installing Safeup
Installing Binaries
safeup client --version 0.90.4-alpha.5 # get a specific version
safeup node --version 0.105.6-alpha.4 # get a specific version
Running a Node
# Linux/macOS
# Windows
This will output all the logs to the filesystem, with the location of logs being platform specific:
# Linux
# macOS
# Windows
# Linux/macOS
# Windows
Connecting as a Client
Using the Client
safe files download
# Linux
# macOS
# Windows
safe file download [directory/filename] [NetworkAddress]
Troubleshooting
Cleanup
# Linux
rm -rf ~/.local/share/safe
# macOS
# Windows
