Thanks for the logs @digipl!
I think we might have some issue with backward compatibility there. Sorry about that. Also, we should’ve had a nicer error messages when there are such issues, I’ll look into both of those!
vdash Users
Unless you upgrade using node-manager may want to move the logs for old nodes out of the way and restart vdash. It’s not necessary, but will remove the old nodes from the display.
If you use node-manager to upgrade that should not be necessary, though i haven’t tested that!
v0.17.3
There’s a new version out (v0.17.3) but I’m not sure if there’s a need to upgrade for this test.
@joshuef does this have Qi’s PR with the bad node notification in it?
If so, folks please upgrade and look out for ‘SHUNNED’ under node status. I’ve never seen that myself yet, so a screenshot would be nice. ![]()
naively i upgraded with the node-manager and didn’t do nothing
everything looks perfect
so it begins ![]()
just starting to update all my nodes now first one looks like it was a success ![]()
Upgrade summary:
✓ safenode1 upgraded from 0.105.2 to 0.105.6
✓ safenode2 upgraded from 0.105.2 to 0.105.6
✓ safenode3 upgraded from 0.105.2 to 0.105.6
✓ safenode4 upgraded from 0.105.2 to 0.105.6
✓ safenode5 upgraded from 0.105.2 to 0.105.6
✓ safenode6 upgraded from 0.105.2 to 0.105.6
✓ safenode7 upgraded from 0.105.2 to 0.105.6
✓ safenode8 upgraded from 0.105.2 to 0.105.6
✓ safenode9 upgraded from 0.105.2 to 0.105.6
✓ safenode10 upgraded from 0.105.2 to 0.105.6
✓ safenode11 upgraded from 0.105.2 to 0.105.6
✓ safenode12 upgraded from 0.105.2 to 0.105.6
✓ safenode13 upgraded from 0.105.2 to 0.105.6
✓ safenode14 upgraded from 0.105.2 to 0.105.6
✓ safenode15 upgraded from 0.105.2 to 0.105.6
✓ safenode16 upgraded from 0.105.2 to 0.105.6
✓ safenode17 upgraded from 0.105.2 to 0.105.6
✓ safenode18 upgraded from 0.105.2 to 0.105.6
✓ safenode19 upgraded from 0.105.2 to 0.105.6
✓ safenode20 upgraded from 0.105.2 to 0.105.6
✓ safenode21 upgraded from 0.105.2 to 0.105.6
✓ safenode22 upgraded from 0.105.2 to 0.105.6
✓ safenode23 upgraded from 0.105.2 to 0.105.6
✓ safenode24 upgraded from 0.105.2 to 0.105.6
✓ safenode25 upgraded from 0.105.2 to 0.105.6
✓ safenode26 upgraded from 0.105.2 to 0.105.6
✓ safenode27 upgraded from 0.105.2 to 0.105.6
✓ safenode28 upgraded from 0.105.2 to 0.105.6
✓ safenode29 upgraded from 0.105.2 to 0.105.6
✓ safenode30 upgraded from 0.105.2 to 0.105.6
✓ safenode31 upgraded from 0.105.2 to 0.105.6
✓ safenode32 upgraded from 0.105.2 to 0.105.6
✓ safenode33 upgraded from 0.105.2 to 0.105.6
✓ safenode34 upgraded from 0.105.2 to 0.105.6
✓ safenode35 upgraded from 0.105.2 to 0.105.6
✓ safenode36 upgraded from 0.105.2 to 0.105.6
✓ safenode37 upgraded from 0.105.2 to 0.105.6
✓ safenode38 upgraded from 0.105.2 to 0.105.6
✓ safenode39 upgraded from 0.105.2 to 0.105.6
✓ safenode40 upgraded from 0.105.2 to 0.105.6
✓ safenode41 upgraded from 0.105.2 to 0.105.6
✓ safenode42 upgraded from 0.105.2 to 0.105.6
✓ safenode43 upgraded from 0.105.2 to 0.105.6
✓ safenode44 upgraded from 0.105.2 to 0.105.6
✓ safenode45 upgraded from 0.105.2 to 0.105.6
✓ safenode46 upgraded from 0.105.2 to 0.105.6
✓ safenode47 upgraded from 0.105.2 to 0.105.6
✓ safenode48 upgraded from 0.105.2 to 0.105.6
✓ safenode49 upgraded from 0.105.2 to 0.105.6
✓ safenode50 upgraded from 0.105.2 to 0.105.6
✓ safenode51 upgraded from 0.105.2 to 0.105.6
✓ safenode52 upgraded from 0.105.2 to 0.105.6
✓ safenode53 upgraded from 0.105.2 to 0.105.6
✓ safenode54 upgraded from 0.105.2 to 0.105.6
✓ safenode55 upgraded from 0.105.2 to 0.105.6
✓ safenode56 upgraded from 0.105.2 to 0.105.6
✓ safenode57 upgraded from 0.105.2 to 0.105.6
✓ safenode58 upgraded from 0.105.2 to 0.105.6
✓ safenode59 upgraded from 0.105.2 to 0.105.6
✓ safenode60 upgraded from 0.105.2 to 0.105.6
✓ safenode61 upgraded from 0.105.2 to 0.105.6
✓ safenode62 upgraded from 0.105.2 to 0.105.6
✓ safenode63 upgraded from 0.105.2 to 0.105.6
✓ safenode64 upgraded from 0.105.2 to 0.105.6
✓ safenode65 upgraded from 0.105.2 to 0.105.6
✓ safenode66 upgraded from 0.105.2 to 0.105.6
✓ safenode67 upgraded from 0.105.2 to 0.105.6
✓ safenode68 upgraded from 0.105.2 to 0.105.6
✓ safenode69 upgraded from 0.105.2 to 0.105.6
✓ safenode70 upgraded from 0.105.2 to 0.105.6
hmmm - traffic for my nodes seems to have decreased a fair amount oO (by ~50% from what i’m seeing)
is this just me and i lost connection or have we increased data efficiency and reduced not needed node chatter?
My 15 nodes are already upgraded, and running the new version for a couple of hours already. All of them connected, but without peers or puts so far. One of them has a 10 in storecost, 0 for the rest. Let’s have some patient, I guess (and without faucet, I assume not a lot of activity ongoing).
I’ve killed those nodes and started new ones using safenode-manager instead. However, it seems they’re still having trouble dialling out.
BTW, these are running on my home network with UDP port forwarding from 45000-45009 enabled on my router. The last beta network worked great with that.
FWIW, this is how I started the nodes:
sudo /home/paul/.local/bin/safenode-manager add --count 5 --node-port 45000-45004 --peer /ip4/138.68.146.254/udp/52597/quic-v1/p2p/12D3KooWDV4aSK3oxQNumbvKAvrAExKRhDSwEbti6y5JaW9MHeAv
sudo /home/paul/.local/bin/safenode-manager start
[2024-04-10T10:03:14.128630Z INFO safenode] Node started with initial_peers ["/ip4/138.68.146.254/udp/52597/quic-v1/p2p/12D3KooWDV4aSK3oxQNumbvKAvrAExKRhDSwEbti6y5JaW9MHeAv"]
[2024-04-10T10:03:14.128689Z INFO safenode] Starting node ...
[2024-04-10T10:03:14.130238Z WARN sn_transfers::wallet::hot_wallet] No main key found when loading wallet from path, generating a new one with pubkey: aa6c13853f2da6e216279587e3dcea4642d2e2a3c8abf4b02ef8b752b8b7d62755ca2f70b43de4c66a67848fb2c4fef0
[2024-04-10T10:03:14.130843Z INFO sn_networking::driver] Process (PID: 226046) with PeerId: 12D3KooWKkaNFb1Xi6247Y7BRUffW6UMyQuyUerJsK1dGiEuKsL7
[2024-04-10T10:03:14.130868Z INFO sn_networking::driver] Self PeerID 12D3KooWKkaNFb1Xi6247Y7BRUffW6UMyQuyUerJsK1dGiEuKsL7 is represented as kbucket_key 9f1cfe374dd0afd23b41dee6b65d801bb6a5178564023baf7b9ea17636a4b7e8
[2024-04-10T10:03:14.130888Z INFO sn_networking::driver] Building request response with "/safe/node/0.16"
[2024-04-10T10:03:14.130947Z INFO sn_networking::record_store] Attempting to repopulate records from existing store...
[2024-04-10T10:03:14.131435Z INFO sn_networking::driver] Building Identify with identify_protocol_str: "safe/0.16" and identify_version: "safe/node/0.16"
[2024-04-10T10:03:14.155028Z INFO sn_networking::network_discovery] Time to generate NetworkDiscoveryCandidates: 22.842772ms
[2024-04-10T10:03:14.155054Z INFO sn_networking::network_discovery] The generated network discovery candidates currently cover these ilog2 buckets: [(239, 1), (242, 2), (244, 1), (245, 5), (246, 5), (247, 5), (248, 5), (249, 5), (250, 5), (251, 5), (252, 5), (253, 5), (254, 5), (255, 5)]
[2024-04-10T10:03:14.155826Z INFO safenode::rpc_service] RPC Server listening on 127.0.0.1:46825
[2024-04-10T10:03:14.156513Z DEBUG sn_node::node] Replication interval set to 31s
[2024-04-10T10:03:14.156715Z INFO sn_networking::event] Local node is listening on "/ip4/127.0.0.1/udp/45001/quic-v1/p2p/12D3KooWKkaNFb1Xi6247Y7BRUffW6UMyQuyUerJsK1dGiEuKsL7"
[2024-04-10T10:03:14.156839Z INFO sn_networking::event] Local node is listening on "/ip4/192.168.188.50/udp/45001/quic-v1/p2p/12D3KooWKkaNFb1Xi6247Y7BRUffW6UMyQuyUerJsK1dGiEuKsL7"
[2024-04-10T10:03:14.156915Z INFO sn_networking::event] Local node is listening on "/ip4/192.168.188.53/udp/45001/quic-v1/p2p/12D3KooWKkaNFb1Xi6247Y7BRUffW6UMyQuyUerJsK1dGiEuKsL7"
[2024-04-10T10:03:14.157008Z INFO sn_networking::event] Local node is listening on "/ip4/172.21.0.1/udp/45001/quic-v1/p2p/12D3KooWKkaNFb1Xi6247Y7BRUffW6UMyQuyUerJsK1dGiEuKsL7"
[2024-04-10T10:03:14.157162Z INFO sn_networking::event] Local node is listening on "/ip4/172.17.0.1/udp/45001/quic-v1/p2p/12D3KooWKkaNFb1Xi6247Y7BRUffW6UMyQuyUerJsK1dGiEuKsL7"
[2024-04-10T10:03:14.157227Z INFO sn_networking::event] Local node is listening on "/ip4/172.18.0.1/udp/45001/quic-v1/p2p/12D3KooWKkaNFb1Xi6247Y7BRUffW6UMyQuyUerJsK1dGiEuKsL7"
[2024-04-10T10:03:14.158358Z DEBUG sn_node::node] BadNodesCheck interval set to 150s
[2024-04-10T10:03:14.160053Z ERROR sn_node::node] Failed to dial /ip4/138.68.146.254/udp/52597/quic-v1/p2p/12D3KooWDV4aSK3oxQNumbvKAvrAExKRhDSwEbti6y5JaW9MHeAv: DialError(DialPeerConditionFalse(NotDialing))
[2024-04-10T10:03:14.160094Z ERROR sn_node::node] Failed to dial /ip4/138.68.146.254/udp/52597/quic-v1/p2p/12D3KooWDV4aSK3oxQNumbvKAvrAExKRhDSwEbti6y5JaW9MHeAv: DialError(DialPeerConditionFalse(NotDialing))
[2024-04-10T10:03:14.160160Z ERROR sn_node::node] Failed to dial /ip4/138.68.146.254/udp/52597/quic-v1/p2p/12D3KooWDV4aSK3oxQNumbvKAvrAExKRhDSwEbti6y5JaW9MHeAv: DialError(DialPeerConditionFalse(NotDialing))
[2024-04-10T10:03:14.160217Z ERROR sn_node::node] Failed to dial /ip4/138.68.146.254/udp/52597/quic-v1/p2p/12D3KooWDV4aSK3oxQNumbvKAvrAExKRhDSwEbti6y5JaW9MHeAv: DialError(DialPeerConditionFalse(NotDialing))
[2024-04-10T10:03:14.160223Z ERROR sn_node::node] Failed to dial /ip4/138.68.146.254/udp/52597/quic-v1/p2p/12D3KooWDV4aSK3oxQNumbvKAvrAExKRhDSwEbti6y5JaW9MHeAv: DialError(DialPeerConditionFalse(NotDialing))
[2024-04-10T10:03:14.200000Z INFO sn_networking::event] external address: new candidate has the same configured port, adding it. address=/ip4/51.155.194.163/udp/45001/quic-v1
paul@Vader:/var/log/safenode$ sudo ~/.local/bin/safenode-manager status
Safenode Services
Service Name Peer ID Status Connected Peers
safenode21 12D3KooWEDAHUcgGnxcapaGYzqNT7dwrPsCgJLqp18Qrdk24bYyu RUNNING 0
safenode22 12D3KooWKkaNFb1Xi6247Y7BRUffW6UMyQuyUerJsK1dGiEuKsL7 RUNNING 0
safenode23 12D3KooWNEzFygdhs9wfvNaeQ4iDT37wcDKioSpoBJadokuaAZ14 RUNNING 0
safenode24 12D3KooWRNq8DLDPDDKrshSK85orEFA5wM2ZumEeXqn4PaAr6Vty RUNNING 0
safenode25 12D3KooWH23g2ofGbkapUuiPvjW2kZxebMHSVNxrSJc9A23usXy9 RUNNING 0
I also tried adding some nodes using a different peer, but received the same error:
[2024-04-10T10:31:24.277348Z ERROR sn_node::node] Failed to dial /ip4/144.126.194.103/udp/55644/quic-v1/p2p/12D3KooWFSYX9kwZKnsbBn263VpCkW8EvpE6DG7nBinLgF66USTT: DialError(DialPeerConditionFalse(NotDialing))
Same here, my nodes do not dial out. I had the same problem in the previous Alpha net.
Running safenode v0.105.6
[2024-04-10T10:16:24.748503Z DEBUG safenode] Built with git version: f532de4 / stable / f532de4 / 2024-04-10
[2024-04-10T10:16:24.748505Z INFO safenode] Node started with initial_peers ["/ip4/46.101.11.193/udp/54868/quic-v1/p2p/12D3KooWD6Nossk565ANUhR8fw2VUDvG3F9kfg9PXmp2BSK7xi8i", "/ip4/165.22.120.188/udp/43546/quic-v1/p2p/12D3KooWG1Bb2akh2cPpt5jgxSS64NhFyx9EsoM45UxzBiQwrYtp", "/ip4/159.65.25.115/udp/32941/quic-v1/p2p/12D3KooWDJ6qPG42qj3hPh7M9BXqwMAFhtn6BPn6UPWDyaybx4Am", "/ip4/165.232.36.234/udp/36395/quic-v1/p2p/12D3KooWHhDB3ABJc8o5kHYHLuqHKXKwffXeCiKhQCsFAXSj9wJx", "/ip4/46.101.12.150/udp/60904/quic-v1/p2p/12D3KooWBv1bYmT9MQHRUCoqncYmtsofGrNNPFHKTArBq3Amuuhr", "/ip4/188.166.174.103/udp/57929/quic-v1/p2p/12D3KooWHRSKaZm58fp1PwNDBAqNAkTT9uLaZXB2xLaZ8nbw5WNp", "/ip4/134.209.20.218/udp/55195/quic-v1/p2p/12D3KooWALWDb3qoJEy5GTrAHTL4yCRoqufVkteHgeCo5moAmsTv", "/ip4/46.101.94.136/udp/60717/quic-v1/p2p/12D3KooWNo88cx5yXsNka66tGPHVZd8ij63uDp5MdCY5sR7pMhib", "/ip4/134.209.19.138/udp/42612/quic-v1/p2p/12D3KooWBQ4bw25WQftysCKcMETSns2Gq42DeTa7M32V2XizZRhK", "/ip4/165.227.225.208/udp/55913/quic-v1/p2p/12D3KooWJ6NwxiqMj9Xy6XzLS5GD2V9Ks4NvTLoXejQHXMcKP34k", "/ip4/144.126.234.162/udp/37284/quic-v1/p2p/12D3KooWFTMioLueKChk9rWEFNFGTH3zRQ6eTiGxjL2ss1wWgZ11", "/ip4/134.209.28.37/udp/53921/quic-v1/p2p/12D3KooWP7rPCHPCQjdjSwoq4fzztvNTfSSbyadBrd1LtNgHgCx8", "/ip4/64.227.41.221/udp/53004/quic-v1/p2p/12D3KooWG8CNQjSenbpzRnJi1XudbpBceKCAtv7eQJdjgtayf8Z1", "/ip4/46.101.8.32/udp/54952/quic-v1/p2p/12D3KooWLdcZrhKt92wtwpq5GvLpqyMykx8VeBwudJP2eu7LeSnH", "/ip4/188.166.173.237/udp/53206/quic-v1/p2p/12D3KooWSXMboWADPvRNY1opXioUxNNGWTPvZKiR9kY2DY3Gtr9S", "/ip4/144.126.236.14/udp/33468/quic-v1/p2p/12D3KooWAmJQWWtDqVmXqQSfMu4ropWq81kfwgb1JePrR4g9AXLS", "/ip4/46.101.12.206/udp/43960/quic-v1/p2p/12D3KooWLRePKcLDGYEQ14HrXq2kyeh2x5ncmQsQ3kuxSAAXkjrZ", "/ip4/144.126.238.186/udp/35780/quic-v1/p2p/12D3KooWMCwNegzc3AsgoMajSCz27x2xGVaoe3pWkMSpggRVf3n1", "/ip4/159.65.51.105/udp/39251/quic-v1/p2p/12D3KooWJQKQkenhn2a6bY92FnZ1bWiCBLsMdCTBF5fuybk9x9iV", "/ip4/144.126.193.205/udp/35756/quic-v1/p2p/12D3KooWSZTJeW9aWsqM9FB8bZP22x1JaXWbnKXwMAiz1FwKbtY2", "/ip4/142.93.44.25/udp/51960/quic-v1/p2p/12D3KooWCDZirVXnir2Fab8JRaAJSoA3d1cKru9tsK4nNHjRrvWh", "/ip4/159.65.60.39/udp/57731/quic-v1/p2p/12D3KooWCzmkPNL8jYDvAPZxUBXjquXCmz5RMNrtyvh6CsfaFK1A", "/ip4/138.68.158.117/udp/35973/quic-v1/p2p/12D3KooWNM9xQKGKNbEEuQGcNLU5Rfx9eZGE4ks4eVAXwfdymghX", "/ip4/142.93.42.205/udp/33217/quic-v1/p2p/12D3KooWABLuRycrxPjuozdBhkD8oeWP8WPr79K81mQ29czFTbmw", "/ip4/144.126.194.103/udp/55644/quic-v1/p2p/12D3KooWFSYX9kwZKnsbBn263VpCkW8EvpE6DG7nBinLgF66USTT", "/ip4/165.227.239.170/udp/46212/quic-v1/p2p/12D3KooWRtejNqpxCdEsmhoWRVGMo49oDMysCfMTqkeQGfxUNSKv", "/ip4/144.126.198.181/udp/40767/quic-v1/p2p/12D3KooWR5ZfCsR3axhMvBygFEQz8eTqawRYHBVoESwnCWekfbN6", "/ip4/144.126.236.186/udp/35302/quic-v1/p2p/12D3KooWQjvmJLvEypdPcXX793CLwQNfsa8QpeijLJhZcfPv8aWh", "/ip4/138.68.140.61/udp/43731/quic-v1/p2p/12D3KooWSQjSv216q4Tbpr6MBeziWvcyep5pBz9wQPm9uhydtZNh", "/ip4/138.68.148.205/udp/47263/quic-v1/p2p/12D3KooWLVrXppf5XUdzixFhrxPSkWWiGiZBGtm1t3z2Avf8CQfF", "/ip4/138.68.130.205/udp/36640/quic-v1/p2p/12D3KooWHU8A5K9GyrQnjLgrdyMBGWpyCctUxi7YcDyD9rA4G5f5", "/ip4/159.65.91.131/udp/50340/quic-v1/p2p/12D3KooWCevGsqqTkMCrZrhovZ1okdrSd5fWFiwHwieZZcpRstVk", "/ip4/144.126.193.206/udp/41423/quic-v1/p2p/12D3KooWLGW6mbzZiqSFeYhXFTbgx9YNR9WqWcZ9PkVAa7xHRT6h", "/ip4/144.126.193.200/udp/54464/quic-v1/p2p/12D3KooWLPudQyrREYeC5sCmpcaVqAXGdvubiJ5xzJzLSjajTMhv", "/ip4/188.166.156.156/udp/59795/quic-v1/p2p/12D3KooWMZuoQNPWR1mmQ4pJ8AUZEVmsKscADRwpMBHGcbQALVie", "/ip4/138.68.146.254/udp/52597/quic-v1/p2p/12D3KooWDV4aSK3oxQNumbvKAvrAExKRhDSwEbti6y5JaW9MHeAv", "/ip4/165.232.44.18/udp/36842/quic-v1/p2p/12D3KooWJpk5gMrrVbWdYL8BqACn1d8kXLYUWii3a26ncuhBXkPf", "/ip4/134.209.24.249/udp/48658/quic-v1/p2p/12D3KooWJgjenQgQfsprkbm9mFKjaFvUL3hn9645UEC3YZ43Ri7e", "/ip4/144.126.193.192/udp/45254/quic-v1/p2p/12D3KooWErtLZeGnmZzHJk1dPF3Mtz53hpqe1Td1Sacn8dAD7WBF", "/ip4/144.126.238.31/udp/51712/quic-v1/p2p/12D3KooWNH1fNmgZWDsohjQoyAUoBoJDRaT8js59vBpWocLr9AtA", "/ip4/142.93.33.228/udp/53182/quic-v1/p2p/12D3KooWEYdZTatHHPyQ8nTHiKtjoUuNJYwMz5ayhtmQmjohYDKQ", "/ip4/188.166.173.170/udp/51241/quic-v1/p2p/12D3KooWA5LWCV5mJ15Tk36vGBy6u68egqcQcPAyrW3AXo2TuePm", "/ip4/139.59.174.231/udp/45232/quic-v1/p2p/12D3KooWRXA4pmz4sAF8xFhUEpmRkxtwSTeTH3WZxNV5c88f1YwZ", "/ip4/138.68.154.253/udp/38315/quic-v1/p2p/12D3KooWMaAWqPi1AnUu744BFd7RNG5MU7LR382Ycv2PFzX1T4R6", "/ip4/159.65.52.34/udp/41862/quic-v1/p2p/12D3KooWGZEjGNjET7J5SbmBJ4EMfvu1RqPr6SedeQiBrybReCtw", "/ip4/138.68.154.151/udp/58080/quic-v1/p2p/12D3KooWETp7vBVGr22frvrnMVUTEgmNjA8dbatKUBDaNnKKtVfm", "/ip4/159.65.57.30/udp/53302/quic-v1/p2p/12D3KooWSAknfaVMGUPBiQVmhcW4EJwGgA73ic8ZRFv6Hgt2WSga", "/ip4/159.65.57.43/udp/55158/quic-v1/p2p/12D3KooWLrHqbQ2Bb5xxLQFo7tz2MEytDBqsBm98dWXSMyTGKLkn", "/ip4/209.97.130.14/udp/59662/quic-v1/p2p/12D3KooWRUdjPHiHwWKJqH83BBBsomYGVu3YGX8D5i21W5mEE184", "/ip4/142.93.34.55/udp/37653/quic-v1/p2p/12D3KooWRzuf14HtznVD5yVujbDhzWn6bBasZqqGj7pdwswD6RiT"]
[2024-04-10T10:16:24.748759Z INFO safenode] Starting node ...
[2024-04-10T10:16:24.750304Z WARN sn_transfers::wallet::hot_wallet] No main key found when loading wallet from path, generating a new one with pubkey: 9016533492bac323814c149f9dfb4f6cd4e94e967063c091b1d3f10e7efed3a2118a9d9ffab8ca764836b75c25ba389c
[2024-04-10T10:16:24.751208Z INFO sn_networking::driver] Process (PID: 5167) with PeerId: 12D3KooWRazpLz7TETEhyAWatearq3eqDpQDbsnmP3DYCXzQNKd3
[2024-04-10T10:16:24.751249Z INFO sn_networking::driver] Self PeerID 12D3KooWRazpLz7TETEhyAWatearq3eqDpQDbsnmP3DYCXzQNKd3 is represented as kbucket_key 0abd9e25669dd3178edda0121920c929f1c7660d2cc1bfd0f521f48894c9f5b4
[2024-04-10T10:16:24.751265Z INFO sn_networking::driver] Building request response with "/safe/node/0.16"
[2024-04-10T10:16:24.751299Z INFO sn_networking::record_store] Attempting to repopulate records from existing store...
[2024-04-10T10:16:24.751356Z DEBUG sn_networking::driver] Using Kademlia with NodeRecordStore!
[2024-04-10T10:16:24.751623Z INFO sn_networking::driver] Building Identify with identify_protocol_str: "safe/0.16" and identify_version: "safe/node/0.16"
[2024-04-10T10:16:24.752722Z DEBUG sn_networking::driver] Preventing non-global dials
[2024-04-10T10:16:24.868218Z INFO sn_networking::network_discovery] Time to generate NetworkDiscoveryCandidates: 115.452144ms
[2024-04-10T10:16:24.868236Z INFO sn_networking::network_discovery] The generated network discovery candidates currently cover these ilog2 buckets: [(243, 1), (244, 5), (245, 5), (246, 5), (247, 5), (248, 5), (249, 5), (250, 5), (251, 5), (252, 5), (253, 5), (254, 5), (255, 5)]
[2024-04-10T10:16:24.871309Z DEBUG sn_logging::metrics] {"physical_cpu_threads":4,"system_cpu_usage_percent":2.1506867,"process":{"cpu_usage_percent":0.00066204515,"memory_used_mb":17,"bytes_read":0,"bytes_written":16384,"total_mb_read":0,"total_mb_written":0}}
[2024-04-10T10:16:24.871401Z DEBUG sn_node::node] Replication interval set to 24s
[2024-04-10T10:16:24.872171Z DEBUG sn_node::node] BadNodesCheck interval set to 195s
[2024-04-10T10:16:24.872462Z INFO sn_networking::event] Local node is listening on "/ip4/127.0.0.1/udp/12005/quic-v1/p2p/12D3KooWRazpLz7TETEhyAWatearq3eqDpQDbsnmP3DYCXzQNKd3"
[2024-04-10T10:16:24.872487Z TRACE sn_networking::event] SwarmEvent handled in 36.796µs: "new listen addr"
[2024-04-10T10:16:24.872521Z INFO sn_networking::event] Local node is listening on "/ip4/192.168.1.85/udp/12005/quic-v1/p2p/12D3KooWRazpLz7TETEhyAWatearq3eqDpQDbsnmP3DYCXzQNKd3"
[2024-04-10T10:16:24.872535Z TRACE sn_networking::event] SwarmEvent handled in 19.703µs: "new listen addr"
[2024-04-10T10:16:24.872624Z TRACE sn_node::node] Handling NetworkEvent "NetworkEvent::NewListenAddr(\"/ip4/192.168.1.85/udp/12005/quic-v1/p2p/12D3KooWRazpLz7TETEhyAWatearq3eqDpQDbsnmP3DYCXzQNKd3\")"
[2024-04-10T10:16:24.872634Z TRACE sn_node::node] Network handling statistics, Event "NewListenAddr" handled in 20.944µs : "NetworkEvent::NewListenAddr(\"/ip4/192.168.1.85/udp/12005/quic-v1/p2p/12D3KooWRazpLz7TETEhyAWatearq3eqDpQDbsnmP3DYCXzQNKd3\")"
[2024-04-10T10:16:24.872642Z TRACE sn_node::node] Handled non-blocking network event in 42.203µs: "NetworkEvent::NewListenAddr(\"/ip4/192.168.1.85/udp/12005/quic-v1/p2p/12D3KooWRazpLz7TETEhyAWatearq3eqDpQDbsnmP3DYCXzQNKd3\")"
[2024-04-10T10:16:24.872668Z TRACE sn_node::node] Handling NetworkEvent "NetworkEvent::NewListenAddr(\"/ip4/127.0.0.1/udp/12005/quic-v1/p2p/12D3KooWRazpLz7TETEhyAWatearq3eqDpQDbsnmP3DYCXzQNKd3\")"
[2024-04-10T10:16:24.872674Z TRACE sn_node::node] Network handling statistics, Event "NewListenAddr" handled in 12.833µs : "NetworkEvent::NewListenAddr(\"/ip4/127.0.0.1/udp/12005/quic-v1/p2p/12D3KooWRazpLz7TETEhyAWatearq3eqDpQDbsnmP3DYCXzQNKd3\")"
[2024-04-10T10:16:24.872678Z TRACE sn_node::node] Handled non-blocking network event in 28.556µs: "NetworkEvent::NewListenAddr(\"/ip4/127.0.0.1/udp/12005/quic-v1/p2p/12D3KooWRazpLz7TETEhyAWatearq3eqDpQDbsnmP3DYCXzQNKd3\")"
[2024-04-10T10:16:24.872718Z TRACE sn_networking::driver] Dialing manually addr=/ip4/46.101.11.193/udp/54868/quic-v1/p2p/12D3KooWD6Nossk565ANUhR8fw2VUDvG3F9kfg9PXmp2BSK7xi8i
[2024-04-10T10:16:24.872755Z TRACE sn_networking::driver] SwarmCmd handled in 61.537µs: "SwarmCmd::Dial { addr: \"/ip4/46.101.11.193/udp/54868/quic-v1/p2p/12D3KooWD6Nossk565ANUhR8fw2VUDvG3F9kfg9PXmp2BSK7xi8i\" }"
[2024-04-10T10:16:24.872790Z TRACE sn_networking::driver] Dialing manually addr=/ip4/46.101.11.193/udp/54868/quic-v1/p2p/12D3KooWD6Nossk565ANUhR8fw2VUDvG3F9kfg9PXmp2BSK7xi8i
[2024-04-10T10:16:24.872801Z TRACE sn_networking::driver] SwarmCmd handled in 27µs: "SwarmCmd::Dial { addr: \"/ip4/46.101.11.193/udp/54868/quic-v1/p2p/12D3KooWD6Nossk565ANUhR8fw2VUDvG3F9kfg9PXmp2BSK7xi8i\" }"
[2024-04-10T10:16:24.872812Z ERROR sn_node::node] Failed to dial /ip4/46.101.11.193/udp/54868/quic-v1/p2p/12D3KooWD6Nossk565ANUhR8fw2VUDvG3F9kfg9PXmp2BSK7xi8i: DialError(DialPeerConditionFalse(NotDialing))
[2024-04-10T10:16:24.873353Z TRACE sn_networking::driver] Dialing manually addr=/ip4/165.22.120.188/udp/43546/quic-v1/p2p/12D3KooWG1Bb2akh2cPpt5jgxSS64NhFyx9EsoM45UxzBiQwrYtp
[2024-04-10T10:16:24.873402Z TRACE sn_networking::driver] SwarmCmd handled in 75.666µs: "SwarmCmd::Dial { addr: \"/ip4/165.22.120.188/udp/43546/quic-v1/p2p/12D3KooWG1Bb2akh2cPpt5jgxSS64NhFyx9EsoM45UxzBiQwrYtp\" }"
[2024-04-10T10:16:24.873438Z TRACE sn_networking::driver] Dialing manually addr=/ip4/165.22.120.188/udp/43546/quic-v1/p2p/12D3KooWG1Bb2akh2cPpt5jgxSS64NhFyx9EsoM45UxzBiQwrYtp
[2024-04-10T10:16:24.873449Z TRACE sn_networking::driver] SwarmCmd handled in 26.407µs: "SwarmCmd::Dial { addr: \"/ip4/165.22.120.188/udp/43546/quic-v1/p2p/12D3KooWG1Bb2akh2cPpt5jgxSS64NhFyx9EsoM45UxzBiQwrYtp\" }"
[2024-04-10T10:16:24.873458Z ERROR sn_node::node] Failed to dial /ip4/165.22.120.188/udp/43546/quic-v1/p2p/12D3KooWG1Bb2akh2cPpt5jgxSS64NhFyx9EsoM45UxzBiQwrYtp: DialError(DialPeerConditionFalse(NotDialing))
[2024-04-10T10:16:24.873812Z TRACE sn_networking::driver] Dialing manually addr=/ip4/159.65.25.115/udp/32941/quic-v1/p2p/12D3KooWDJ6qPG42qj3hPh7M9BXqwMAFhtn6BPn6UPWDyaybx4Am
[2024-04-10T10:16:24.873870Z TRACE sn_networking::driver] SwarmCmd handled in 81.092µs: "SwarmCmd::Dial { addr: \"/ip4/159.65.25.115/udp/32941/quic-v1/p2p/12D3KooWDJ6qPG42qj3hPh7M9BXqwMAFhtn6BPn6UPWDyaybx4Am\" }"
[2024-04-10T10:16:24.873892Z TRACE sn_networking::driver] Dialing manually addr=/ip4/159.65.25.115/udp/32941/quic-v1/p2p/12D3KooWDJ6qPG42qj3hPh7M9BXqwMAFhtn6BPn6UPWDyaybx4Am
[2024-04-10T10:16:24.873901Z TRACE sn_networking::driver] SwarmCmd handled in 21.722µs: "SwarmCmd::Dial { addr: \"/ip4/159.65.25.115/udp/32941/quic-v1/p2p/12D3KooWDJ6qPG42qj3hPh7M9BXqwMAFhtn6BPn6UPWDyaybx4Am\" }"
[2024-04-10T10:16:24.873915Z ERROR sn_node::node] Failed to dial /ip4/159.65.25.115/udp/32941/quic-v1/p2p/12D3KooWDJ6qPG42qj3hPh7M9BXqwMAFhtn6BPn6UPWDyaybx4Am: DialError(DialPeerConditionFalse(NotDialing))
looks similar here my network usage fell off a cliff at 10:55 when I upgraded the nodes on that system
a
just tried sending a coin from one wallet to another one and got an error ![]()
I was able to transfer coins around last night when I was trying to scrape all my dust together
🔗 Connected to the Network Successfully parsed transfer.
Failed to verify and redeem transfer: CouldNotReceiveMoney("InvalidTransfer(\"GetRecord Query Error NotEnoughCopies { record_key: d2b0a3(b6b931793e10ef9f69809c08f9825c3ff843edb55fd46ed4237fcc0b5111da44), expected: 5, got: 3 }\")")
Error:
0: Failed to receive transfer due to InvalidTransfer("GetRecord Query Error NotEnoughCopies { record_key: d2b0a3(b6b931793e10ef9f69809c08f9825c3ff843edb55fd46ed4237fcc0b5111da44), expected: 5, got: 3 }")
sn_cli/src/bin/subcommands/wallet/helpers.rs:141
I couldn’t upload a log either. I wonder if the network is full, if there are a lot of nodes struggling to join?
paul@Vader:/var/log/safenode$ safe files upload -b 1 -p /var/log/safenode/safenode21/safenode.log
Logging to directory: "/home/paul/.local/share/safe/client/logs/log_2024-04-10_11-15-35"
Connecting to the network with 50 peers
🔗 Connected to the Network "/var/log/safenode/safenode21/safenode.log" will be made public and linkable
Splitting and uploading "/var/log/safenode/safenode21/safenode.log" into 4 chunks
Error:
0: Failed to upload chunk batch: Multiple consecutive network errors reported during upload
/home/runner/work/safe_network/safe_network/sn_cli/src/files/files_uploader.rs:133
In the associated log, I’m getting lots of these:
[2024-04-10T10:15:35.783619Z DEBUG sn_networking] send_and_get_responses for Query(GetStoreCost(NetworkAddress::ChunkAddress(67ae78 - 2055a79fe7e091f6c6cbe301d7c79ecf7888f0f1f5f2e732f7a9eb775ebcc7c9)))
[2024-04-10T10:15:35.800830Z DEBUG sn_networking] Got response from PeerId("12D3KooWDsXBurtQQhjAQu6x3tpGt4sH7ku7fJdmNy5EHBU4zh74") for the req: Query(GetStoreCost(NetworkAddress::ChunkAddress(67ae78 - 2055a79fe7e091f6c6cbe301d7c79ecf7888f0f1f5f2e732f7a9eb775ebcc7c9))), resp: OutboundError(UnsupportedProtocols)
[2024-04-10T10:15:35.801141Z DEBUG sn_networking] Got response from PeerId("12D3KooWKAEFMPCygS1xEcWE6EKbPR2ahCvyxxKAiRffAz6fPJ86") for the req: Query(GetStoreCost(NetworkAddress::ChunkAddress(67ae78 - 2055a79fe7e091f6c6cbe301d7c79ecf7888f0f1f5f2e732f7a9eb775ebcc7c9))), resp: OutboundError(UnsupportedProtocols)
[2024-04-10T10:15:35.801355Z DEBUG sn_networking] Got response from PeerId("12D3KooWFaYWhcAhkpcejVLpmbuprcyX6bnuTvVrg1jmyaijvAzR") for the req: Query(GetStoreCost(NetworkAddress::ChunkAddress(67ae78 - 2055a79fe7e091f6c6cbe301d7c79ecf7888f0f1f5f2e732f7a9eb775ebcc7c9))), resp: OutboundError(UnsupportedProtocols)
[2024-04-10T10:15:35.801519Z DEBUG sn_networking] Got response from PeerId("12D3KooWCTQ7nQqSUHM5wrES4cj47qHivNYTEyAzQuAjoTnHryb1") for the req: Query(GetStoreCost(NetworkAddress::ChunkAddress(67ae78 - 2055a79fe7e091f6c6cbe301d7c79ecf7888f0f1f5f2e732f7a9eb775ebcc7c9))), resp: OutboundError(UnsupportedProtocols)
Before eventually getting this:
[2024-04-10T10:15:41.568200Z DEBUG sn_networking] Received all responses for Query(GetStoreCost(NetworkAddress::ChunkAddress(67ae78 - 2055a79fe7e091f6c6cbe301d7c79ecf7888f0f1f5f2e732f7a9eb775ebcc7c9)))
[2024-04-10T10:15:41.568301Z ERROR sn_client::uploader::upload] Encountered error Network(NoStoreCostResponses) when getting store_cost for 67ae78(01100111)..
[2024-04-10T10:15:41.568354Z TRACE sn_client::uploader::upload] Received task result: GetStoreCostErr { xorname: 67ae78(01100111).., get_store_cost_strategy: Cheapest, max_repayments_reached: false }
[2024-04-10T10:15:41.568376Z TRACE sn_client::uploader::upload] GetStoreCostErr for 67ae78(01100111).. , get_store_cost_strategy: Cheapest, max_repayments_reached: false
[2024-04-10T10:15:41.568387Z ERROR sn_client::uploader::upload] Max sequential network failures reached during GetStoreCostErr.
Weird thing is, if I just open a CLI and start:
safenode
without any ports specified, it starts fine while being behind a NAT router. Shouldn’t it say ‘determined to be behind NAT, closing’ or something? Or did I miss the announcement about hole punching? ![]()
Are you running behind a home router or in the cloud? I wonder if that could be impacting.
FWIW, I didn’t participate in the alpha net, so I can’t say whether that failed or worked for me.
my un upgraded systems also show a drop in network activity around 11:00
im all stopped on upgrading the rest of my systems at the moment until we know what to do next
same here I have peers also
ubuntu@s00:~$ safenode-status
safenode-status: command not found
ubuntu@s00:~$ safenode-manager status
Safenode Services
safenode1 12D3KooWJ3T3PedpFzQF9hvU9SrQnCxznphMdo3mnUScA5YriWVQ RUNNING 27
safenode2 12D3KooWT1K73ny9PEK45bT94Mguoei4kvKdDSfU8x65Bgzr4VKo RUNNING 27
safenode3 12D3KooWSJDpu9FcEuSansBYZV7os2sT3UsfAopAHfyoz9DN2m3y RUNNING 36
safenode4 12D3KooWFE5U7svzPr4SsJVwThAbxdYiZ15M8Un2gg6HuzjkPJnA RUNNING 22
safenode5 12D3KooWGsUt5pTrw4nNNyShoF8QFXFxrUxEYX5vr3oncm4WaRJj RUNNING 40
safenode6 12D3KooWEamdX7dGa2iKcGbquc4HiB4sXj2inpxNW5wxowiubn7D RUNNING 21
safenode7 12D3KooWSPxwwJqSVdgf2rC2iboDYtBxbVeRCRHeXYFkZq4zXtrM RUNNING 40
safenode8 12D3KooWHPstir6gBYmKDrbTF66nPmfs5x8iKopH5M25JSp4xi7N RUNNING 26
safenode9 12D3KooWGqf7CRyWprs9UqyxuuPFcfeC2YS13hPttbVhkvfunB8j RUNNING 28
safenode10 12D3KooWJnpzhDGoW544DN9HofJwirAjGKhyMn6aNhuYmNtNcMQ1 RUNNING 28
safenode11 12D3KooWEr5yZHmQUQvhPKFDQtLQ44teNVtmGcrkeQ64pjDkFNs3 RUNNING 46
safenode12 12D3KooWLptqBHywF2FiVtiYHU41UD9xdvueCbtaFprmUJNLLD4u RUNNING 31
safenode13 12D3KooWCtWZwXQf1bQuSxSE87Dcc4D52E3kzqSEdhCa98MFqzyL RUNNING 28
safenode14 12D3KooWQfDGWhoHcwW8PchAi9D7s748FSzfQvwfrTwjxWDdtDEq RUNNING 29
safenode15 12D3KooWG6aExNGz47WLkgYr4j6SiktzaLAwAu1fTC472Li5GAnw RUNNING 35
safenode16 12D3KooWE99u5MRYja3Y1a9hqpK3pJJmLr6bFFkordQSREdUs92B RUNNING 25
safenode17 12D3KooWR7bvSEdotA1yt7Zm3FhkCC1KY3qNrx4i6YdDzgCuw4ZE RUNNING 25
safenode18 12D3KooWJVUFCqj2ANaouPndEgFsorZnQDqRBz28TPxizazEMmyC RUNNING 38
safenode19 12D3KooWDz51iTsekNLpeXmCq8rWPYFazYJMRa8B1KWkzu77jy5u RUNNING 27
safenode20 12D3KooWFjLx4WAxYqbdycRmaUXGRNd1KfzEzL5g7BjSLLGWKbEq RUNNING 26
safenode21 12D3KooWJ3GGR1CeVWsZdZLtSnbRp8pTu3HPCoK8Lo77JMncDJA9 RUNNING 23
safenode22 12D3KooWEa6RXiUZtuoNxsuDu1GveKHrN27PnSctdxZQfUbdn8tF RUNNING 25
safenode23 12D3KooWFFF1usGSendqv9YC7yKGk4ZMH5RWE8MUazj7vX5MY5eF RUNNING 17
safenode24 12D3KooWH63GmEyNGHd9uaCoayr2MHWWwhA8jqkwmYFB1s4HmgPn RUNNING 33
safenode25 12D3KooWMRH1dTPQwDfdauVGsyYw5RzACQN8nePjusiSmompsE93 RUNNING 26
safenode26 12D3KooWLZ2z64BU9D2hh8imiugmFAiQ55wumTFbCSMMGBrJm1KC RUNNING 35
safenode27 12D3KooWC64WZkcSm4JES9WYWuAjdF5k4SSqV9X7fqFCmv5DmoSe RUNNING 45
safenode28 12D3KooWD5e8ZuvVv6qsUrLbDWucGZmWsiiegcxWowDCoeSp2FEY RUNNING 31
safenode29 12D3KooW9qTaKVXUwovNLXXFu7PhHDwrAupLais1C7jzjy932LLd RUNNING 36
safenode30 12D3KooWBV4yi2K8DmZudQwa4voh2aaMPahL5dBGePznP1BJvBEC RUNNING 32
safenode31 12D3KooWJ8om1RQVMBPakHZoybEDtFVc82tMwHtoFtEMFsRGMHKZ RUNNING 26
safenode32 12D3KooWH7fbZSuTB7zEFJNsQhvpSRfbcnw8cfGE3DoDdRxUfMyR RUNNING 34
safenode33 12D3KooWG5x7Qs5Mh7hHLHTuHjCH72vp8uYbnapDHi6NU74z8s7f RUNNING 33
safenode34 12D3KooWNg3Hf7KR3oHVfSg2EixxDvrRH8RbdMfYkKdNogZQwmZR RUNNING 24
safenode35 12D3KooWBQYpzpnYB3p5HocLq3NhQMDyWTrLpsS6hjmU8KKSnXXb RUNNING 30
safenode36 12D3KooWFkc5YbMBkbizwZkPhXdM7ywvaohsdeiWTdxpqx5qQ8d4 RUNNING 25
safenode37 12D3KooWNsMfvHybL1cKPQd8BG59zX9jZYPMZsk3WSLfYfYwUHtB RUNNING 24
safenode38 12D3KooWCBcxjKe3moFJKqQG15zxD3GjhVQtDpjp8daELbe5K94G RUNNING 28
safenode39 12D3KooWEtKWyEJgwf7MXDLKvmXVk3fE31k9WFQ8TH2RKctbvE57 RUNNING 30
safenode40 12D3KooWKB3EU1ZGCi994GWATjmu6RhMGNZ9GyxTvrMYGuKtQFNG RUNNING 27
safenode41 12D3KooWDtKutr6UWAjkqwKUJpg5FTeBcng2eMzju7cy1awnNHUj RUNNING 38
safenode42 12D3KooWFYHyMJL1dXj1YREoGjCNnTBac1iZUfwZvkKDFcTCQXHr RUNNING 25
safenode43 12D3KooW9yxPaCVQb8VPPB4chdvP9qyGwCh5u77qy2YiYrHMzATf RUNNING 41
safenode44 12D3KooWDCKdYbcq9RQNZdcP52oFBeZCRcBzP19GVPnVHnMcxCL6 RUNNING 31
safenode45 12D3KooWMqmegLsdpMvmw9kDNLnKEVuR7VHbKmATj3Yo7Fe4iFHT RUNNING 33
safenode46 12D3KooWSxcF8sJTQ36MuDvT9AAihVDV9qzXY224n5shekNzMeDL RUNNING 21
safenode47 12D3KooWNfP2qutZpUNL5eBZrdrcy1qL1JQkMgxrabxSofUK3Zh1 RUNNING 31
safenode48 12D3KooWQkbKjEWg4CavjxHB3PjwctisZVNy8mc75KVLrxcuRann RUNNING 24
safenode49 12D3KooWSYhS8nWnJxjMHjhdJQGmZ5phXL5SiVzFLT1MdbL1c5Q8 RUNNING 22
safenode50 12D3KooWK9pTkkLr4LX2hfB96MdboTxjG2DEb34W5h2E215nZ2x2 RUNNING 39
safenode51 12D3KooWJ77GJt8rBnKEFy2xfkzJdZtozcZoqveGSCQumsAzxhw9 RUNNING 23
safenode52 12D3KooWHWYS6tbZcXEeiKXPj9PqyXK8YJ86DSXTo9nxVk5xXgpA RUNNING 19
safenode53 12D3KooWHyDUT66p7kVZeMp4mnJLbykwepFUDYBFjwbweWtv8M8H RUNNING 46
safenode54 12D3KooWDE7c9Drz7V4LQE3mPqaYuDQbYUSKj78X8Xda3YR3EZf4 RUNNING 23
safenode55 12D3KooWHchX1Sr3U1aqrQpazxkjWppi9YU59qmPAgiP8MkJ9uuv RUNNING 35
ping @chriso when we use the upgrade command does it lose the previously assigned port ?
ie I start my nodes with this comand
sudo env "PATH=$PATH" safenode-manager add --node-port "$NODE_PORT_FIRST"-$(($NODE_PORT_FIRST+$NUMBER_NODES-1)) --count "$NUMBER_NODES" --peer "$PEER" --version "$NODE"
will upgrading with
sudo env "PATH=$PATH" safenode-manager upgrade
lose the previous settings the node started with ?
— edit
looking at safenode-manager status --details
I can see they are on the same ports as before so should all be all good ![]()
---- edit
downloads failing now as well we have lost the southside
🔗 Connected to the Network Downloading "AnarchyInTheSouthside.mp3" from c0893739a688b739aac5b75ac845b6c428c21b73dc782352bb1ad529495a87af with batch-size 1
Error downloading "AnarchyInTheSouthside.mp3": Chunks error Chunk could not be retrieved from the network: 394af5(00111001)...
Yes my nodes are all from home.
I still don’t have peers and use safenode-manager. My logs are too big for the forum, and not enough safecoins to add them to the network (23 MB in a tar.bz2):
0: Not enough balance in wallet to pay for chunk. We have NanoTokens(941399577) but need NanoTokens(2441944190) to pay for the chunk
Maybe I can borrow some tokens:
raul@raspberrypi4:~> $ safe wallet address
Logging to directory: "/home/raul/.local/share/safe/client/logs/log_2024-04-10_13-14-09"
ada182e91edd024c2f3d519cd0a96afad12ee0b7cadb5d3decb254747e008f86f20c3a0f8bd4e8cf80fdc1ab3b959cfa
trying to send you some now @raulillo but I think its going to fail
