BasicEconomyTweaks [Early Technical Beta] Part Deux [Offline]
Upgrade summary:
â safenode1 upgraded from 0.105.3 to 0.105.6
â safenode2 upgraded from 0.105.3 to 0.105.6
â safenode3 was not upgraded: Error: Could not connect to RPC endpoint 'https://127.0.0.1:46665'
â safenode4 upgraded from 0.105.3 to 0.105.6
â safenode5 upgraded from 0.105.3 to 0.105.6
â safenode6 upgraded from 0.105.3 to 0.105.6
â safenode7 was not upgraded: Error: Could not connect to RPC endpoint 'https://127.0.0.1:37695'
â safenode8 upgraded from 0.105.3 to 0.105.6
â safenode9 upgraded from 0.105.3 to 0.105.6
â safenode10 upgraded from 0.105.3 to 0.105.6
â safenode11 upgraded from 0.105.3 to 0.105.6
â safenode12 upgraded from 0.105.3 to 0.105.6
â safenode13 upgraded from 0.105.3 to 0.105.6
â safenode14 upgraded from 0.105.3 to 0.105.6
â safenode15 upgraded from 0.105.3 to 0.105.6
â safenode16 upgraded from 0.105.3 to 0.105.6
â safenode17 upgraded from 0.105.3 to 0.105.6
â safenode18 upgraded from 0.105.3 to 0.105.6
â safenode19 upgraded from 0.105.3 to 0.105.6
â safenode20 upgraded from 0.105.3 to 0.105.6
â safenode21 upgraded from 0.105.3 to 0.105.6
â safenode22 upgraded from 0.105.3 to 0.105.6
â safenode23 was not upgraded: Error: Could not connect to RPC endpoint 'https://127.0.0.1:35059'
â safenode24 upgraded from 0.105.3 to 0.105.6
â safenode25 was not upgraded: Error: Could not connect to RPC endpoint 'https://127.0.0.1:42787'
â safenode26 upgraded from 0.105.3 to 0.105.6
â safenode27 upgraded from 0.105.3 to 0.105.6
â safenode28 was not upgraded: Error: Could not connect to RPC endpoint 'https://127.0.0.1:41011'
â safenode29 upgraded from 0.105.3 to 0.105.6
â safenode30 upgraded from 0.105.3 to 0.105.6
Same here. start --service-name safenodeXX and then upgrade --service-name safenodeXX for each of the five that failed to upgrade worked for me. All 30 are now upgraded and running.
@qi_ma
I am trying to send some tokens and I see this error in the logs is the wallet broken or is it recoverable ?
@riddim just managed to send me some token to the same address im trying to send to
No holder of record '1d17dc(a3850ef53908bdd78144dd67479090e7d7cd1ba03cb5ac849e38e3b8e1536dd5)' found.
No.
Looks like an error in network: the record is missed
Hard to tell.
This could be something triggered by the backward compatibility, as mentioned at
You may have to wait, with finger crossed. :pray:
They are still the different spends (as spent by different owner), which will be handled by different nodes.
The succeeded one just being lucky that all holders of that spend is healthy ones.
But, the holders of your spend will be different, and unfortunately not that healthy at moment.
Since we’re going from beta → alpha → beta with the software and it had two separate faucets, which coins are (or should be) valid here? The OG beta coins?
Upgrade for Win11 worked ok, then the nodes would not start, see below: I did screw up by not being in Powershell Admin mode for the first 5 nodes, did the exact same command with the safenode manager to add 5 nodes and it added additional nodes 6-10, …
What am I missing here? Suggestions?
PS C:\WINDOWS\system32> safenode-manager add --count 5 --peer /ip4/46.101.80.187/udp/58070/quic-v1/p2p/12D3KooWKgJQedzCxrp33u3dBD1mUZ9HTjEjgrxskEBvzoQWkRT9
          Add Safenode Services
5 service(s) to be added
Retrieving latest version for safenode…
Downloading safenode version 0.105.6…
Download completed: C:\Users\Admin\AppData\Local\Temp\b4d7b46e-7c8d-4ac1-87ee-b5d2d0128c81\safenode.exe
Services Added:
✓ safenode6
- Safenode path: C:\ProgramData\safenode\data\safenode6\safenode.exe
- Data path: C:\ProgramData\safenode\data\safenode6
- Log path: C:\ProgramData\safenode\logs\safenode6
- RPC port: 127.0.0.1:50279
✓ safenode7
- Safenode path: C:\ProgramData\safenode\data\safenode7\safenode.exe
- Data path: C:\ProgramData\safenode\data\safenode7
- Log path: C:\ProgramData\safenode\logs\safenode7
- RPC port: 127.0.0.1:50280
✓ safenode8
- Safenode path: C:\ProgramData\safenode\data\safenode8\safenode.exe
- Data path: C:\ProgramData\safenode\data\safenode8
- Log path: C:\ProgramData\safenode\logs\safenode8
- RPC port: 127.0.0.1:50281
✓ safenode9
- Safenode path: C:\ProgramData\safenode\data\safenode9\safenode.exe
- Data path: C:\ProgramData\safenode\data\safenode9
- Log path: C:\ProgramData\safenode\logs\safenode9
- RPC port: 127.0.0.1:50282
✓ safenode10
- Safenode path: C:\ProgramData\safenode\data\safenode10\safenode.exe
- Data path: C:\ProgramData\safenode\data\safenode10
- Log path: C:\ProgramData\safenode\logs\safenode10
- RPC port: 127.0.0.1:50283
[!] Note: newly added services have not been started
PS C:\WINDOWS\system32> safenode-manager start
         Start Safenode Services
Refreshing the node registry…
Attempting to start safenode1…
Attempting to start safenode2…
Attempting to start safenode3…
Attempting to start safenode4…
Attempting to start safenode5…
Attempting to start safenode6…
Attempting to start safenode7…
Attempting to start safenode8…
Attempting to start safenode9…
Attempting to start safenode10…
Failed to start 10 service(s):
←[31m✕←[0m safenode1: [SC] StartService FAILED 1053:
The service did not respond to the start or control request in a timely fashion.
←[31m✕←[0m safenode2: [SC] StartService FAILED 1053:
←[31m✕←[0m safenode3: [SC] StartService FAILED 1053:
←[31m✕←[0m safenode4: [SC] StartService FAILED 1053:
←[31m✕←[0m safenode5: [SC] StartService FAILED 1053:
←[31m✕←[0m safenode6: [SC] StartService FAILED 1053:
←[31m✕←[0m safenode7: [SC] StartService FAILED 1053:
←[31m✕←[0m safenode8: [SC] StartService FAILED 1053:
←[31m✕←[0m safenode9: [SC] StartService FAILED 1053:
←[31m✕←[0m safenode10: [SC] StartService FAILED 1053:
Error:
0: ←[91mFailed to start one or more services←[0m
←[35msn_node_manager\src\cmd\node.rs←[0m:←[35m421←[0m
PS C:\WINDOWS\system32> safenode-manager status
Hey, see my response to the issue you raised yesterday. You need to have WinSW to use the node manager on Windows.
Some loose coins…
a6f5d39679c96cd7d8dd2d88247da3c592a8097a90e81c6dfc98aa29f5b2d31c6c0c349e1f25e1075433fadce7f617e1
Here we go;
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
Thanks bro…
Old balance: 0.000000000
New balance: 0.005000000
imagen
Error:
0: Not enough balance in wallet to pay for chunk. We have NanoTokens(5000000) but need NanoTokens(21684921630061379) to pay for the chunk
would send you some of my holdings … but i’m afraid that won’t change anything in the picture xD …
Thanks for the feedback on this. I believe that “Text file busy” error results from trying to overwrite a running binary. It might be the case that somehow those services were not stopped correctly.
Lol. Sorry, got little left after I wiped my old wallets…
Good old Windows. Not being able to delete a running executable file is such a PITA.
This is on Linux. I think this error message is an old, classic Unix one. Hence the kind of ambiguous nature of it.
Edit: I came across it before and found this explanation: What generates the "text file busy" message in Unix? - Stack Overflow
PS C:\Users\Wes> safe files upload small.txt
Logging to directory: "C:\\Users\\Wes\\AppData\\Roaming\\safe\\client\\logs\\log_2024-04-10_11-13-12"
Built with git version: f532de4 / stable / f532de4 / 2024-04-10
Connecting to the network with 50 peers
⠁ Connecting to The SAFE Network...        ⠁ Connecting to The SAFE Network...        ⠂ Connecting to The SAFE Network...        ⠄ Connecting to The SAFE Network...        ⠄ 1/5 initial peers found.        ⠄ 2/5 initial peers found.        ⠄ 3/5 initial peers found.        ⠄ 4/5 initial peers found.        ⠄ 5/5 initial peers found.        🔗 Connected to the Network        Chunking 1 files...
Splitting and uploading "small.txt" into 3 chunks
Error:
   0: Not enough balance in wallet to pay for chunk. We have NanoTokens(100) but need NanoTokens(112391023457) to pay for the chunk
   D:\a\safe_network\safe_network\sn_cli\src\files\files_uploader.rs:128
ouchie. Will spin up more nodes at lunch and hopefully we can get this price down by dispersion of chunks.
EDIT: However, this does prove that the Beta coins are valid on this network. I copied my node wallet that got paid 8 coins during first section of beta to my client. So I’ve got some coins to spread out - for what it’s worth with current store prices. Not sure who’s been paid so far so reply to this and I can send you some coin.
^^^ Maybe. Worked once, but hasn’t worked since.
Started up 20 more nodes.
@wes if you could spare a nano or two …
8819c673391b1dff55f2caf1f82ce01d20059abf299f7865c2727f77df5b92da2dff06ab75f219063575a1816003c729
Thanks :slight_smile:
I’m trying
   0: Wallet Error Failed to send tokens due to The transfer was not successfully registered in the network: CouldNotSendMoney("Failed to send spend requests to the network:b25c13801ac3f7b8e48d78328f8012ecc9a4aaa787cd1c2b4a6edb0dc67901e327385ded6e5cd7658f375a276cca0631: Network Error Record not stored by nodes, it could be invalid, else you should retry: NetworkAddress::RecordKey(6a5658 - a4d932601c9f358ddad1fe698974b3c76a7b01780c669380eaf5a5de859af21a).b3f931d49a0715dcd2bb1205c5d84887a4c01f4c393be064c7a5247c50e7d4aad537c8b659726ed5e7241149e7cbe85a: Network Error Record not stored by nodes, it could be invalid, else you should retry: NetworkAddress::RecordKey(e4b83c - 3f28ce3c2f2f6789732b32c042fe34bcd0f3e5b05d3943ada81cc9bee5060f1c).").
   1: Failed to send tokens due to The transfer was not successfully registered in the network: CouldNotSendMoney("Failed to send spend requests to the network:b25c13801ac3f7b8e48d78328f8012ecc9a4aaa787cd1c2b4a6edb0dc67901e327385ded6e5cd7658f375a276cca0631: Network Error Record not stored by nodes, it could be invalid, else you should retry: NetworkAddress::RecordKey(6a5658 - a4d932601c9f358ddad1fe698974b3c76a7b01780c669380eaf5a5de859af21a).b3f931d49a0715dcd2bb1205c5d84887a4c01f4c393be064c7a5247c50e7d4aad537c8b659726ed5e7241149e7cbe85a: Network Error Record not stored by nodes, it could be invalid, else you should retry: NetworkAddress::RecordKey(e4b83c - 3f28ce3c2f2f6789732b32c042fe34bcd0f3e5b05d3943ada81cc9bee5060f1c).")
This happened 2 times before it succeeded when sending myself coin. Currently on attempt 4 with decreasing value.
All instantly filled:
This is a count of chunks in the data_dir, not chunks that it’s close to (however, for brand new nodes starting up, I’d think they’d only get chunks they are close to)
The data_dir size also ~400-500MB which is where they seem to top off.
These nodes (81-102) were started in the last 10 minutes
im going to try one more upgrade then ill fire up another 10 idle VPS
