Edit:
Current status:
08/08
- Only one more node lost.
- Many nodes full
- Mem appears to climb slowly across nodes
03/08
A spike in network activity appears to have killed nodes for maidsafe and community users.
- Maidsafe right now has 1675 nodes alive and kicking
- some of those nodes have reached max capacity
- Investigations underway
(31/07)
- still 2001 maidsafe nodes
- largest droplets are about ~60% full
(28/07)
- All maidsafe nodes still live. 2001 going strong (biiig improvement over last testnets).
- Droplets are about ~40% full on random sampling (~400-600 records)
- Client validation of PUTs is problematic for some users. We’re investigating. (Large files will be harder to store)
- There’s no mechanism for actually sending the DBCs as yet. You’ll need to inform the other party atm (I think… @roland is double checking there).
Orignal Post
We’ve seen some good improvements to node memory usage, and things have been looking healthy on the data side for a few testnets now.
As such, we’re going to try something new. Actually paying for data! And with this comes a faucet which you’ll need to ask for Safe Network Tokens before you’re allowed to upload! (if all goes well).
So with this testnet we want to check:
- Faucet stability / ux
- DBC transfers work as expected (are timely, no double spends etc).
- Data payments work as expected
(It should be noted that the faucet is a temporary distribution measure until we have nodes earning money.)
Network Details
Node version: 0.87.1
Client version: 0.80.1
Faucet url: http://178.62.79.112:8000
SAFE_PEERS: /ip4/167.99.195.200/tcp/41805/p2p/12D3KooWP7SR4kWdN2SdeBdnpkxTbk1Buomb5PEjZVaZU3fGkkpK
Alternatives:
"/ip4/167.99.197.30/tcp/33243/p2p/12D3KooWFBYaQcFqM8GMW91ifuxgTXHxmdjns14XPGTQVcopnkqn"
"/ip4/167.99.199.20/tcp/45197/p2p/12D3KooWBfZcLR3kCNFnqzJsEdNKSL2vA5MHg24jAcg2HNJJHjnq"
"/ip4/167.99.199.231/tcp/33541/p2p/12D3KooWDPnfjR7LTSjcJgQGjhdN2bK6j3Pw345g2d8TbXU5yUQy"
"/ip4/178.62.79.112/tcp/46803/p2p/12D3KooWJnPhTVEnv7rx9ZCZZZRgTxrts33m33sKWfDdFH4jBcGo"
"/ip4/167.99.195.200/tcp/44037/p2p/12D3KooWSc6JmQE6yQaXxaBbiUSjm3YUgZpu44oLeUVL8yAs6zAL"
"/ip4/167.99.205.124/tcp/46301/p2p/12D3KooWMWkpHQkjJHDqwZRHd8RyzcykmFHm7mszMy7syqKySCvp"
We have 100 droplets running a total of 2000 nodes. One droplet has 2vcpu and 4GB of memory.
Quickstart
safeup client --version 0.80.1
safeup node --version 0.87.1
Run a Node
Linux/macOS:
SN_LOG=all safenode
Windows:
$env:SN_LOG = "all"; safenode
Connect to the Network
Linux/macOS:
export SAFE_PEERS="/ip4/167.99.195.200/tcp/41805/p2p/12D3KooWP7SR4kWdN2SdeBdnpkxTbk1Buomb5PEjZVaZU3fGkkpK"
safe wallet get-faucet http://178.62.79.112:8000
Windows:
$env:SAFE_PEERS = "/ip4/167.99.195.200/tcp/41805/p2p/12D3KooWP7SR4kWdN2SdeBdnpkxTbk1Buomb5PEjZVaZU3fGkkpK"
Further Information
Cleanup
If you’ve used previous versions of the Network before, you will want to cleanup the previous files (worthless DBCs from previous runs, old logs, old keys).
# Linux
rm -rf ~/.local/share/safe
# macOS
# Windows
Obtaining Binaries
Installing Safeup
Installing Binaries
safeup client --version 0.80.1 # get a specific version
safeup node --version 0.87.1 # get a specific version
Running a Node
# Linux/macOS
SN_LOG=all safenode
# Windows
$env:SN_LOG = all; safenode
This will output all the logs in the terminal.
Sometimes it will be preferable to output the logs to file. You can do this by running the node like so:
# Linux/macOS
SN_LOG=all safenode --log-output-dest data-dir
# Windows
$env:SN_LOG = "all"; safenode --log-output-dest data-dir
The location of data-dir is platform specific:
# Linux
# macOS
# Windows
# Linux/macOS
# Windows
Connecting as a Client
To connect, you must provide another peer, in the form of a multi address. You can find one in the ‘Network Details’ section at the top.
It is recommended to set the peer using the environment variable SAFE_PEERS. You can set this variable once and it will apply for the duration of your shell session:
# Linux/macOS
# Windows
NOTE: If you close and/or start a new shell session, you will be required to redefine this environment variable in the new session.
As an alternative to the environment variable, it’s also possible to use the --peer argument:
safe --peer="/ip4/167.99.195.200/tcp/41805/p2p/12D3KooWP7SR4kWdN2SdeBdnpkxTbk1Buomb5PEjZVaZU3fGkkpK" ...
However, this requires specifying the peer with each command.
Using the Client
safe files download
# Linux
# macOS
# Windows
safe file download [directory/filename] [XORURL]
Troubleshooting
