It must be kept running the whole time, or only very short down time. The reason is that it’s a log parser, and the node logs (especially home-node logs) grow pretty quickly. Node’s will rotate to a new log file every 20MB. So if you miss a rotation, vdash will be out of sync.
Testnet is working fine for me, got some test tokens, uploaded and downloaded an image.
Then tried with a larger file (1GB) and it chunked and split into 2048 chunks, and the speed was a bit slow - took around 27 minutes to upload, which might be a drawback for people that wish to upload a lot of media content. The progress loader is great, helps to know it’s moving along.
5GB randome data file as i can not find any more Linux iso that have not already been uploaded to use
upload went up first time with no repayment errors in 22 minutes batch size 224
home network fiber broadband 1000 down 100 up
ubuntu@sha:~$ time safe files upload -p 5GB-test.txt --batch-size 224
Logging to directory: "/home/ubuntu/.local/share/safe/client/logs/log_2024-05-14_18-58-52"
safe client built with git version: 16f3484 / stable / 16f3484 / 2024-05-09
Connecting to the network with 49 peers
🔗 Connected to the Network Chunking 1 files...
"5GB-test.txt" will be made public and linkable
Splitting and uploading "5GB-test.txt" into 10244 chunks
* Uploaded Files *
"5GB-test.txt" 7f3d626274d70ba0dd3a1e61b7e23cd86e508d9ca102ea55a5bc540b74c804c2
Among 10244 chunks, found 0 already existed in network, uploaded the leftover 10244 chunks in 20 minutes 19 seconds
* Payment Details *
Made payment of NanoTokens(690337839) for 10244 chunks
Made payment of NanoTokens(121819371) for royalties fees
New wallet balance: 3.187842374
real 22m34.521s
user 37m27.946s
sys 10m3.102s
It seems like my router can’t handle the 100 nodes I’ve set up from home this week. My internet connection randomly drops. Has anyone else experienced this?
sn_networking version should be Semvar compatible + it requires the same protocol.
Ie, it’s possible launch a testnet that is restricted, so to join that you need to have the same restriction set when building code (As well as the same sn_networking version). If we do this, we’ll document this in a post for that network for folk wanting to self-build
Otherwise for stable networks it’s sn_networking version numbering.
We may be at cross purposes here because I’m still not understanding how to use the information you are giving.
My app uses several (~5 from memory) sn_ crates, I’m not sure sn_networking is one of them. Maybe.
They represent the API, not just the protocol, so I am asking how to manage what is in my Cargo.toml both for builds using crates.io and, on occasion if I’m debugging more deeply with a local copy (or fork) of safe_network.
I have been noticing that when a machine starts exhibiting high cp usage it generally never returns down the cpu levels that other machines running the same amount of nodes are using.
after getting one machine that got into trouble when I increased the node count from 50 to 60.
I stopped the additional 10 nodes last night this morning it was still using around 90% cpu.
after greping the logs for considered as bad I stopped those safe nodes.
ubuntu@s26:~$ grep -r "$(date '+%Y-%m-%dT')" /var/log/safenode/ | grep "us as BAD"
/var/log/safenode/safenode3/safenode.log.20240515T053229:[2024-05-15T01:37:22.843118Z WARN sn_networking::event::request_response] Peer NetworkAddress::PeerId(12D3KooWBFpe5QCrktZbPLtvLCJdF1kbyWdmNCxVbSrs9eqgcx73 - 44db808313a1ec5eec0b5fc598e3f3ff940c4e642539166c35da012cd059a0ac) consider us as BAD, due to "ConnectionIssue".
/var/log/safenode/safenode28/safenode.log:[2024-05-15T13:50:37.858167Z WARN sn_networking::event::request_response] Peer NetworkAddress::PeerId(12D3KooWAgyeUcAJWhj5Vf5ZwZJr82zsiG8KH1XZx6mWgKKmbFAn - 6569eccc37729abb183032e30450334228d9fb7c23da2332b2558af6d103a9c3) consider us as BAD, due to "ConnectionIssue".
/var/log/safenode/safenode18/safenode.log:[2024-05-15T10:19:28.752135Z WARN sn_networking::event::request_response] Peer NetworkAddress::PeerId(12D3KooWL7BFKxFVNxAfJd1ySzJmN97hMsJFYgYv3BQF3BECcYha - de7388488efcba7341e9b8db80eff32c230a48f86c46f8779f0db70845e2447b) consider us as BAD, due to "ConnectionIssue".
/var/log/safenode/safenode4/safenode.log:[2024-05-15T10:08:39.363549Z WARN sn_networking::event::request_response] Peer NetworkAddress::PeerId(12D3KooWN65jGMmUWZKaCXzdQ4CBgGQdxBMSa9LRKaujVFUnsM2E - 7cd860bba6ac02d263d372ff0e9ff89e41c273bf6690583f76b6515ed7619ebf) consider us as BAD, due to "ConnectionIssue".
/var/log/safenode/safenode19/safenode.log.20240515T085726:[2024-05-15T02:21:25.003916Z WARN sn_networking::event::request_response] Peer NetworkAddress::PeerId(12D3KooWSDqDMx81b9po2QF8zVzC4qUxCdNvQa9Lnx9MofTzhLVh - e60a3cb90212eaa6f5c7f0b75624cfd9412708e2f7e8d90e597dbccd2ad95f3c) consider us as BAD, due to "ReplicationFailure".
/var/log/safenode/safenode21/safenode.log.20240515T073114:[2024-05-15T04:11:47.698150Z WARN sn_networking::event::request_response] Peer NetworkAddress::PeerId(12D3KooWDBz3RMmt39RzaVeUQZuXVVYReso6sYLzDRyrxcASLdgu - afd0f26a46619457612a31acda0f2bfd6ec5fdacdfc525f4ad930d5b791c369e) consider us as BAD, due to "ConnectionIssue".
/var/log/safenode/safenode12/safenode.log:[2024-05-15T12:43:17.528340Z WARN sn_networking::event::request_response] Peer NetworkAddress::PeerId(12D3KooWBxRd75NtUVyGUR5C5CwgPoUyMAY8nCJXS5EQ6fyacPjr - f6af1e9f1ae8f73836d1a63ee067f6b8ecacd04b0586180506700c5465b6363a) consider us as BAD, due to "ConnectionIssue".
/var/log/safenode/safenode46/safenode.log:[2024-05-15T14:18:28.926536Z WARN sn_networking::event::request_response] Peer NetworkAddress::PeerId(12D3KooWAbR3SoewCWPgSmbJUqeVuTLfj1V8UfTMhznAqHMKZtEW - fadfc3c9921ad4e804b2a8901f708cce84d4e8e74e449b207c93d5884b13cf3b) consider us as BAD, due to "ConnectionIssue".
/var/log/safenode/safenode46/safenode.log.20240515T132758:[2024-05-15T06:24:45.691154Z WARN sn_networking::event::request_response] Peer NetworkAddress::PeerId(12D3KooWNgFt2S1nyHVCL6TQQcnK7d3QgCSfgqWPx4vmFUjnJv1r - f83cfd6810a64496884d86a4355c4a103a3359e77b3b41774650ac3e3fae3788) consider us as BAD, due to "ConnectionIssue".
/var/log/safenode/safenode37/safenode.log.20240515T123301:[2024-05-15T05:07:22.221516Z WARN sn_networking::event::request_response] Peer NetworkAddress::PeerId(12D3KooWRFXYez35pHU8ovv17aFTokTuS5iCSU5JQaibUvKn3FmB - ac77b40dca40bc6622d353f0ee31efe24ce3b1ac672deb79ac159caed5d883a9) consider us as BAD, due to "ReplicationFailure".
/var/log/safenode/safenode31/safenode.log.20240515T131953:[2024-05-15T01:52:44.080612Z WARN sn_networking::event::request_response] Peer NetworkAddress::PeerId(12D3KooWDX2yhNuRqHVxhHWxP3K9hDyzQB2ft8KEYxjRZ3ek7zfc - 8d017b81bcf61826df8d8b0f8262967359da00bd1732268ed1b0d780a67940b9) consider us as BAD, due to "ConnectionIssue".
ubuntu@s26:~$
ubuntu@s26:~$
ubuntu@s26:~$ sudo $HOME/.local/bin/safenode-manager stop --service-name safenode28 --service-name safenode18 --service-name safenode4 --service-name safenode19 --service-name safenode21 --service-name safenode12 --service-name safenode46 --service-name safenode37 --service-name safenode31
║ Stop Safenode Services ║
Attempting to stop safenode28...
✓ Service safenode28 with PID 64249 was stopped
Attempting to stop safenode18...
✓ Service safenode18 with PID 34913 was stopped
Attempting to stop safenode4...
✓ Service safenode4 with PID 6542 was stopped
Attempting to stop safenode19...
✓ Service safenode19 with PID 37283 was stopped
Attempting to stop safenode21...
✓ Service safenode21 with PID 42508 was stopped
Attempting to stop safenode12...
✓ Service safenode12 with PID 19826 was stopped
Attempting to stop safenode46...
✓ Service safenode46 with PID 148154 was stopped
Attempting to stop safenode37...
✓ Service safenode37 with PID 100015 was stopped
Attempting to stop safenode31...
✓ Service safenode31 with PID 75318 was stopped
after those nodes were stopped the cpu usage dropped down to 49%
it apears that "us as BAD" nodes start hogging the cpu and jam up the machine they are running on.
here are the logs from the "us as BAD" nodes in case they are useful.
Yes, this. I also find it useful to give screens names of you’re going to use more than one
screen -S *name here* *command here*
Then you can reconnect to a named screen with
screen -r *screen name*
The command you gave, @Future, will send all output to null. So your logging / checkpointing will work, but you’d need to kill that command before running again in the foreground so the checkpoint files won’t get messed up.
