We’re quite happy with how ZeroNet went. With nodes running smoothly, and some client/faucet issues highlighted and acted upon, we’re hoping for a similar showing this time round.
Indeed, the nodes themselves were so cool, this time round we’re trying twice as many nodes per droplet, i.e. 40 nodes per droplet. This may well change things/cause some issues, but it will be good to find out exactly what’s possible here.
Another important change is that clients no longer publish the DataMap by default. This means that you’re not forced into making your data public (as the final data maps, being small data, may not be encrypted; please see below for more info there!).
Instead clients now have a -p flag to publish the DataMaps optionally. If you’re wanting to share your data, this will be needed to be added to any scripts you might have.
Other changes:
- Transaction progression now checks previous spends have been stored, and will otherwise try and resend transactions.
- Data is verified by clients via a hashing system as opposed to requesting the full data.
- The pricing algo has been tweaked and goes off of the new tests we have. It aims to ensure nodes adjust price depending on how many records they’ve had in, so more nodes should get paid sooner here, and price variation should be reduced
A note for testers:
Just to highlight for folk (as the question has cropped up in other threads), encryption of files is a client side endeavour, and right now there is a lower limit on what can be encrypted. So small files are not yet encrypted as things stand.
This also means that the DataMaps, which are used to know where all the self-encrypted chunks of a file live, may not be encrypted. So be careful using the publish option with your data (-p).
And finally, registers are currently not encrypted at all. We’re looking at ways to improve UX and allow for encryption there too.
Network Details
Node version: 0.100.36
Client version: 0.86.90
Faucet url: 134.209.21.136:8000
We have 51 droplets running a total of 2001 nodes. One droplet has 2vcpu and 4GB of memory.
Quickstart
safeup client --version 0.86.90
safeup node --version 0.100.36
Run a Node
Linux/macOS:
safenode
Windows:
safenode
Linux/macOS:
safe wallet get-faucet 134.209.21.136:8000
Windows:
To do this with non-default batch-sizes (along with SAFE_PEERS set as above):
safe files upload --batch-size 40 <directory-path>
40 being the integer value you want to set
To do this and make the files publicly accessible
safe files upload -p <directory-path>
Further Information
Obtaining Binaries
Installing Safeup
Installing Binaries
safeup client --version 0.86.90 # get a specific version
safeup node --version 0.100.36 # get a specific version
Running a Node
# Linux/macOS
safenode
# Windows
safenode
This will output all the logs to the filesystem, with the location of logs being platform specific:
# Linux
# macOS
# Windows
# Linux/macOS
# Windows
Connecting as a Client
Using the Client
To obtain a network address you can use for sharing data, ensure you publish your data with the -p flag.
safe file upload -p [directory/filename] <directory-path>
safe files download
# Linux
# macOS
# Windows
safe file download [directory/filename] [NetworkAddress]
Troubleshooting
Cleanup
# Linux
rm -rf ~/.local/share/safe
# macOS
# Windows
