Of course you are right, I originally connected using the command to connect to the network first, whereas now I just typed in the command to start the node to trigger the error and show it to @Chriso.
The important thing is that the error has been discovered and corrected.
Are nodes deleting chunks now?
9am today
Total size of all files in .local/share/safe/node/12D3KooWEwMPj64C1MXEKaCYHGgtMApNzzvoynfprLJRLfgfGo7G/record_store/
734178794
Number of files in .local/share/safe/node/12D3KooWEwMPj64C1MXEKaCYHGgtMApNzzvoynfprLJRLfgfGo7G/record_store/
1864
10.30 am
60186132
166
They’d prune records if you got to 2048 records. Which doesn’t look so wild given you had 1864 already there.
OK - and the pruned records are automatically replicated to other nearby nodes?
Record replication should already have been done passively as any churn happened.
You can check logs for A pruning reduced number of record in hold from {num_records} to {new_num_records}
Records or Chunks, where are we here ![]()
Have Chunks officially gone to join the Farmers? ![]()
Maybe you’ll find records are any type of data record. Chunks are specific to files uploading. Files chuncks. But appendable data is not chunks
NODE UPDATE:
Overnight for my node, vdash shows a lot of PUTS but memory remains fluctuating around 50MB so I am seeing improvement over the last test network ![]()
basically as @neo says, chunks are made from files part of what we store in records.
A record is the kad data structure that is replicated across nodes.
A record can be:
- chunk
- register
- dbc
How is the XOR address determined for a register and other non-chunks
excellent.
in terms of “node survival”, we’re down to ~1500 which is I think a wee bit better than before. Not the wild improvement I’d been hoping for, but improvements nonetheless.
Kad has its own NetworkAddress struct. The name we feed into that for registers is (at the moment) determined by the client.
There’s some security improvements if we remove that capability, but we’d also be losing other functionality, so TBD on what we do there.
My node:
810 Records
299 MB
safenode is using 46MB of RAM
Similar, a hundred more PUTS and memory now also 46MB. ![]()
16 nodes running from an AWS t3micro
avg mem per node is 36MB
just killed two largest nodes cos / was at 99% of 8Gb
I kept getting told I was behind a NAT (on AWS!!!) until I made a security group rule to allow ports 12000-12020
then started each node like
ubuntu@ip-172-31-6-177:~/.local/share/safe/node$ SN_LOG=all safenode --log-output-dest data-dir --port=12014 &
and just change the port for each node instance.
how does that 36MB compare to you holdings?
rock64@one:~/.local/share/safe/node/12D3KooWCjQTTLy1no2RxTX6CkJZdZdmUpHqoBgNH5rKthooJdH5$ ls -1 record_store | wc -l
1060
rock64@one:~/.local/share/safe/node/12D3KooWCjQTTLy1no2RxTX6CkJZdZdmUpHqoBgNH5rKthooJdH5$ du -sh record_store
323M record_store
rock64@one:~/.local/share/safe/node/12D3KooWCjQTTLy1no2RxTX6CkJZdZdmUpHqoBgNH5rKthooJdH5$ ps -o rss= -p $(pgrep safenode)
48016
Mine has risen by ~3/4MB with more records, now at 46.91MB
ubuntu@ip-172-31-6-177:~/.local/share/safe/node$ du -sh */record_store
106M 12D3KooWAya3P33jS9QqtE5w7sBHaq5hU9nuuH6SKxXpeAvvYk5q/record_store
31M 12D3KooWCRQgoxsy3zBfWGxCh4SuhWNvrQRRD5s9XfQaeUdcJ8Ug/record_store
707M 12D3KooWD2sAYbfH35U66657AWHQmxtGV44MBV6ey1MPvZ812VyL/record_store
99M 12D3KooWHJGM6YEG8r2GgjxS9pVCabRVzpXEy9kH4wYNAKGqosix/record_store
4.0K 12D3KooWHhcGAuvoqPcEyVpDMAS1JYKbb1Fe6eGvKS6GNzGviQTa/record_store
23M 12D3KooWKG3ywERZFGBzC3MmXorFLdETdawdS8CVSerz9C9oyEfD/record_store
344M 12D3KooWKRCCKDCjMF95cWWDZK7YBSWEF54gsrQHoySUM4QxGpxe/record_store
89M 12D3KooWKiyLPSyrCn7QRtgqohgedZJkQtumJrbWfSAhVcz7zzLU/record_store
83M 12D3KooWKngcYQCCpeinAX5UjHUBRLhdqxz591ZQYBUEqLEvSJQx/record_store
122M 12D3KooWMjc471FMckTTchcne8U4hd2fKqYmmiodQUUfdxYsdx9a/record_store
374M 12D3KooWNF5wTH8KzFfcyTy68LpyBQd8HGNnBrz4WPRayGFeWi59/record_store
101M 12D3KooWPMJGL53akrEUTEyZxGMXXJm5oyzR7gCHr1zUzgCMVNrT/record_store
136M 12D3KooWPTqgrhKHyYUvPfztrFGqLw44sThUmKfKsEbwGi1idU5S/record_store
4.0K 12D3KooWPsWkKy5smBMDUQLnPeZPSbnxyAviwguSMwgdGPuCuzw4/record_store
177M 12D3KooWRTf9x3Ajp4WiHx7UUjGNA7EzCmezdAiuvEKndKCP1Ddp/record_store
27M 12D3KooWRqNyzJLqxi8FrnDccwsUt7FGSj3SJ6Gjj8LLr3Vn4DHP/record_store
325M 12D3KooWSJJpDDPPFs6iMxndy3gcRyjBzbXuWL1qCR5tGpq6qnfj/record_store
288M 12D3KooWSgzk2az6HDoUhBtGoFGR5UubkQG8VBgagGRtEU5YVPcH/record_store
ubuntu@ip-172-31-6-177:~/.local/share/safe/node$ ls -1 */record_store | wc -l
9681
ubuntu@ip-172-31-6-177:~/.local/share/safe/node$ ps -o rss= -p $(pgrep safenode)
29844
31164
39636
29396
25704
33804
39216
30368
32268
34284
28040
27188
38760
30016
24132
ubuntu@ip-172-31-6-177:~/.local/share/safe/node$ df
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/root 7941576 6815708 1109484 87% /
tmpfs 490044 0 490044 0% /dev/shm
tmpfs 196020 836 195184 1% /run
tmpfs 5120 0 5120 0% /run/lock
/dev/xvda15 106858 6182 100677 6% /boot/efi
tmpfs 98008 4 98004 1% /run/user/1000
Looks like you have 2 duds up there (4.0K), yet they are using memory.
This is true,
I will kill them after Ive had my tea
Just wanted to preserve that sentence.
