Seems we finally had that volume breakout on Uniswap. Bittrex pushing higher with increasing volume on intraday.
A humble attempt at Wyckoff distribution. Fake it until you make it, right?
Hi all.
Forgive the rather vague nature of this question butâŚ
How do you feel the e-maid offering is doing now that it has been live for a while now?
I havenât participated yet 'cause I wanted to see how it worked first before looking to get involved.
I donât use Uniswap but seems easy enough. I have a p2b,b2b account from years ago but the emaid volume on there is non-existant now (read about the reasons on Telegram) so wonât be using that I guess.
Anyhoo. Would be interested to get an idea of how anyone feels about emaidâs current state of play.
Thanks,
DG
Itâs really easy and I advice to just try small amount first to check out how metamask/swapping works.
Especially now that Ethereum moved from PoW to PoS fees have gone down a lot. On average I pay around $1 per transaction now which is much better then $6-8 I used to pay when they had PoW.
Iâm just noting that the Merge didnât lower the fees - fees are down because of the bear market and reduced network usage. We will see a reduction in fees at the network level with sharding sometime in the future.
There is an Arbitrum eMaid/Eth pair in Uniswap for those who want to avoid high Ethereum fees.
eMaid token in Arbitrum: MaidSafeCoin (eMAID) Token Tracker | Arbiscan
Bridge from Ethereum to Arbitrum: https://bridge.arbitrum.io
A guy who hasnt posted in 5 yrs now suddenly wants us to put our money into
Thats fine, thats totally fine.
These bridges burn mostly with the users on it, play at your own risk
How do you validate the contract that exists on the bridge?
Usually every bridge come with the âsmartcontractâ code that you can lookup on etherscan or whatever
If the people who write smartcontracts can still loose million$ sometimes even after audits, reading and truly understanding them is probably the next level⌠And just because you see a smartcontracts code doesnât have to mean thatâs whatâs truly happening in the ui you see. But things only get more complex and difficult, not crypto related but probably already happeningâŚ
In truth he is most likely right and most likely Arbitrum will also give free money as Optimism did (they gave me 500$ because I had donated to Gitcoin developers).
The connection between Optimism and Arbitrum is that they are both Ethereum Layer 2 solutions.
The techradar article that I linked above already shows that even if you got 2FA enabled on your phone your currency is not SAFE. Bridges are not a SAFE playground, even if you get $10K from arbitrum, it and all your crypto could vanish in the future due to a hack you donât even know about.
MAID should be bought and kept in cold storage with mulitsig! MAID on a mobile, computer, omniwallet.org or exchange is basically not your MAID, donât take my word for it but in time youâll find out.
Yes, yes - no point of risking MAID moving there. My thought was that they would probably give free money - one could easily send $10 ETH there and put liquidity in there UniSwap against USDC for the chance to get an airdrop:
https://info.uniswap.org/#/arbitrumpools
Anyone noticed the history on Bittrex only goes back as far as when eMAID started trading on uniswap. I wonder if they are thinking of converting over to the ERC20 token?
I can only guess, but the work is done for maid / btc pair, apart from maintenance.
Id imagine theyll keep it if its earning revenue.
Wouldnt surprise me if they added emaid pairs though, more revenue and thats what they do.
Is there anyone willing to trade me some omni MAID for ETH/BTC over the counter? The omni MAID price is lower than the eMAID price right now, so Iâm willing to pay somewhere in the middle of the two prices. Happy to use an escrow service if you want.
If someone decides to take advantage, I can help as an escrow for free (fees are at your expense) ![]()
Emaid is now cheaper if your still looking to buy.
Burned over 290K MAID and counting, hopefully can reach 1M before end of 2022!
PS: Already talked to @SwissPrivateBanker on how to donate back ETH minting fees to @BambooGarden BGF but not sure where to send it?
Thanks for the nice arbitrage, stranger
