All you need to do is just extract the archive you already downloaded earlier.
Sadly, I may have caused him to wipe his home folder, in which case he might not be back for a while. ![]()
Iām sure heāll be fine.
For Sale: Smashed Mac with brand new hard drive. ![]()
Yeah, heās not back ⦠heās either reinstalling his OS or prepping to murder me.
:GUILT:
Hahaha
Just had to put a pause on the tinkering. Iāll be back at it tomorrow.
Thank god. I was writing my will. ![]()
Make sure to remove the line 108 if you run that script.
So great to see everyoneās analysis here and info on nodesā health ![]()
I can report that we have lost nodes too. I presume to the same spike. It may well have been a cascading situation that then stabilized.
Weāre at 1675 nodes, and some of those are at capacity now. Iāll be poking about to see what I can see of those nodes today. (will update OP too).
Edit: initial analysis shows this was most likely replication related. Thereās a lot going on in nodes that died.
Mem was ~340mb at the time. (So not insane, but if we can smooth that out thatāll be good).
We did discover a couple of replication-related bugs in the last week. Iām not sure if thatād have impacted this.
We may just be too keenly replicating, and need to turn that down / make it configurable based upon the system.
Iāll update more as we poke more at this!
Failed to setup SSH before coming to the office and now have to wait another 8 hours to get back to tinkering.
My periodic (hourly) upload has started failing with this.
š Connected to the Network Preparing (chunking) files at '2.2MB.txt'...
Making payment for 6 Chunks that belong to 1 file/s.
Error: Failed to send tokens due to Network Error Could not retrieve the record after storing it: Key(b"\x07v\x01\x83h\xc5\xd5\x17\xe8`j\xd7\x82$z\x85\xe9\xdb\xd3whA\xe4\xac\x06\xaf\xd2\x0c\xcb\x1c\x98\xc2").
sn_cli/src/subcommands/wallet.rs:293:18
12.72user 3.19system 0:58.45elapsed 27%CPU (0avgtext+0avgdata 58076maxresident)k
0inputs+5128outputs (0major+51897minor)pagefaults 0swaps
Status: Upload successful
7.52user 1.46system 0:48.77elapsed 18%CPU (0avgtext+0avgdata 33744maxresident)k
0inputs+4288outputs (0major+19734minor)pagefaults 0swaps
Status: Download successful
Command exited with non-zero status 1
7.31user 0.90system 0:56.08elapsed 14%CPU (0avgtext+0avgdata 33912maxresident)k
0inputs+4464outputs (0major+13144minor)pagefaults 0swaps
Status: Upload failed
7.40user 1.58system 0:51.19elapsed 17%CPU (0avgtext+0avgdata 32948maxresident)k
0inputs+4296outputs (0major+16794minor)pagefaults 0swaps
8.19user 1.06system 1:00.11elapsed 15%CPU (0avgtext+0avgdata 34908maxresident)k
0inputs+4464outputs (0major+14363minor)pagefaults 0swaps
7.22user 1.55system 0:43.06elapsed 20%CPU (0avgtext+0avgdata 35624maxresident)k
0inputs+4288outputs (0major+18314minor)pagefaults 0swaps
7.59user 1.03system 1:02.65elapsed 13%CPU (0avgtext+0avgdata 33476maxresident)k
0inputs+4464outputs (0major+13767minor)pagefaults 0swaps
6.88user 1.45system 0:45.00elapsed 18%CPU (0avgtext+0avgdata 33472maxresident)k
0inputs+4288outputs (0major+19317minor)pagefaults 0swaps
10.08user 1.46system 1:16.40elapsed 15%CPU (0avgtext+0avgdata 38668maxresident)k
0inputs+4464outputs (0major+15674minor)pagefaults 0swaps
7.09user 1.52system 0:46.74elapsed 18%CPU (0avgtext+0avgdata 34016maxresident)k
0inputs+4288outputs (0major+15790minor)pagefaults 0swaps
8.24user 0.89system 0:54.01elapsed 16%CPU (0avgtext+0avgdata 34100maxresident)k
0inputs+4464outputs (0major+13485minor)pagefaults 0swaps
6.83user 1.32system 0:44.29elapsed 18%CPU (0avgtext+0avgdata 35552maxresident)k
0inputs+4288outputs (0major+17243minor)pagefaults 0swaps
Is that uploading the same thing each time?
No, but it does have the same name each time.
For the download I upload a file once and then time the downloads of that specific file.
For the upload it is a randomly generated 2.2MB file but always the same name.
I was not certain if uploading the same file repeatedly is equal to a uploading unique files.
Is the name causing the issue?
Only around 100 uploads, I would imagine many thousands of unique cat pics being named cat.jpeg ![]()
(Although I was wondering if this was the cause)
It should not be. Do the commands have any delay between them or itās all back to back?
It could be that the upload isnāt 100% successful, but that doesnāt mean that all data isnāt on 7/8 nodes⦠But that should mean that the upload does not fail on validation⦠which is what it looks like at the moment. ![]()
The upload is on the hour and download 30 minutes later.
As in each command runs once per hour but 30 minutes apart from each other.
Magic
it started working again.
It appears the issue was with the network as I made no changes on my end, came to add a counter to the name just in case but found the issue went away.
Great that it sorted the problem out and carries on!
Iām slightly baffled by this! My AWS Instance had lost more nodes and I was down to 31 from the initial 50. So I killed them all and started a new 50.
Look at how the, Network in (bytes) and Network out (bytes) have changed.
Iām getting records so Iām not surprised that Iām getting a lot of Network In. But why the relative lack of Network out (bytes).
Also, look at the difference between Network out (bytes) and Packets out (bytes). Are the new nodes doing a different kind of traffic?
are the new nodes the same safenode version?
Yes, no upgrade in between. Just killed the old ones and started new ones.
Edit: This is the version:-
safenode cli 0.87.1
I think might have just answered my own question! Maybeā¦
Could it be that they are new nodes so are taking a greater share of new data coming into the system? Does the network do that?
That would explain the higher number of bytes coming in and the higher number of packets.
And maybe there arenāt as many bytes going out because there is less need for replication writing to other nodes due to churn for the records written because they are newer and therefore the nodes they were originally written to are still alive? Iām guessing that the older the record the more likely it is to be on nodes that are subject to dying.
Is there that kind of interaction going on?
Theyād be new and therefore getting a lot of data coming in in terms of data packets that already exist that they should be responsible for.
Yeh, as theyāre new they dont have any data to send anywhere unless requests come in or until thereās more churn ![]()
I suspect that might be it. lets see if they quieten down after replication is done.
