First track was fine, it didn’t like the “(” in the other one
safe files download “The Teskey Brothers - Hold Me (Official Video).webm” 2edd216e7b939080588c13815444bf9e472bcfad6137a242c7ba2f26f8bc9ef1
bash: syntax error near unexpected token `('
weird, seems to work fine on my end (also in bash)
Client (read all) download progress 78/79
Client (read all) download progress 79/79
Client downloaded file in 29.268270551s
Saved The Teskey Brothers - Hold Me (Official Video).webm at /home/tom/.local/share/safe/client/The Teskey Brothers - Hold Me (Official Video).webm
The mem_usage of the testnet this time supposed to be much flatter than the last one.
I just checked the genesis node and one of our droplets (both have run for over 30 hours) and they seems consuming much less memory than last testnet.
Genesis is consuming 72MB and 20 nodes in the droplet mostly is below 40MB, with 3 around 70MB and one highest at 108MB .
The timing of the snapshot might affects, if the node was busying at something.
If the three nodes in your graph remains high with the mem_usage, please give me a shout, and upload the logs of those three if possible.
Thank you very much.
It is my impression too that memory use is lower. I’m not sure if the profile is different over time but for my ten nodes which have been running for 11 hours the memory use is 23 to 60 average 34 MB.
Storage cost is also more sensible: 13-45 average 27 nanos
frilly@chintz:~$ curl -sSL https://raw.githubusercontent.com/maidsafe/safeup/main/install.sh | bash
* Installing safeup *
Will retrieve safeup for x86_64-unknown-linux-musl architecture
Latest version of safeup is 0.4.1
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0
100 4097k 100 4097k 0 0 1949k 0 0:00:02 0:00:02 --:--:-- 4424k
safeup installed to /home/willie/.local/bin/safeup
The safeup binary has been installed, but it's not available in this session.
You must either run 'source ~/.config/safe/env' in this session, or start a new session.
When safeup is available, please run 'safeup --help' to see how to install network components.
Prooobably. We should hopefully be tolerant enough to this, but it really also depends on node quantities!
Something to look into down the line
Okay thanks or this, useful to get more perspectives here. There’s a pending PR that will trigger a new CLI release, I’m hoping folk should get a more stable upload process with that
Perhaps if an upload fails, instead of stopping it could automatically reduce the batch-size and restart … If you think in terms of a feedback loop circuit, batch-size and other bandwidth related magic numbers could be automated away.
Hi, @Josh
Just had a quick scan through the log files you shared.
Due to the log file rotatioini, the 9 files for 3 nodes you shared covering the period of
node 1: 13th Dec 21:01:13 - 14th Dec 00:29:30 .
node 2: 13th Dec 22:22:26 - 14th Dec 00:31:30 .
node 3: 13th Dec 22:34:58 - 14th Dec 00:33:30
which in your garph, showing at least one node (or even all three nodes) had mem spike during the period.
But the logs showing the mem_usage was not wild. (searching keyword of memory_used_mb among the logs) :
one node remains under 40MB, and the other two remains under 70MB.
There is just total_mb_written having value over 400MB.
Could you let me how the graph collecting the statistics (parse from the log files or just using OS figures) ?
Well really it just seems like you add chunks to the payment queue initially and start paying for those, then add more when those in the queue complete. Seems very much like a queue to me.
Maybe upload_batch_queue_size. That might make it clearer that its not a one out one in type of queue but a queue where there is no regard to order for completion. I don’t think there is a technical name for a queue where there is order for joining the queue but no order for exit (completion)
