ClientImprovementNet [22/09/23 Testnet] [Offline]
BUG: this looks like an old upload bug (cannot store empty file) while uploading a very large deep directory:
Built with git version: 2c47455 / main / 2c47455
🔗 Connected to the Network        Error:
   0: Chunks error Cannot store empty file..
   1: Cannot store empty file.
   sn_cli/src/subcommands/files.rs:140
No dice :frowning:
Alright coffee and brekky then :coffee: :smiley:
393MB file. Approximately half of the chunks are due for repayment.
After 44.754108212s, verified 403 chunks
======= Verification: 193 chunks were not stored. Repaying them in batches. =============
After 18.385724174s, verified 193 chunks
======= Verification: 117 chunks were not stored. Repaying them in batches. =============
After 16.057979836s, verified 117 chunks
======= Verification: 60 chunks were not stored. Repaying them in batches. =============
After 13.377975202s, verified 60 chunks
======= Verification: 56 chunks were not stored. Repaying them in batches. =============
After 17.576739165s, verified 56 chunks
======= Verification: 16 chunks were not stored. Repaying them in batches. =============
After 3.111694874s, verified 16 chunks
======= Verification: 12 chunks were not stored. Repaying them in batches. =============
Repaid and re-uploaded 12 chunks in 36.677941666s
======= Verification: 12 chunks to be checked and repaid if required =============
After 3.650865739s, verified 12 chunks
======= Verification complete: all chunks paid and stored =============
Uploaded all chunks in 53 minutes 29 seconds
Same thing. And also this happens:
export SAFE_PEERS= "/ip4/142.93.76.173/tcp/41717/p2p/12D3KooWJ51eYsdyksy87PazS3M7wRVdPNJWfH58u8fxBk2Y9hdp"
bash: export: `/ip4/142.93.76.173/tcp/41717/p2p/12D3KooWJ51eYsdyksy87PazS3M7wRVdPNJWfH58u8fxBk2Y9hdp': not a valid identifier
Remove the space after the equals sign?
Yep, that was it, thanks!
7 nodes and no records here either so far
Got it working with:
safeup node --version 0.90.34
Chunks flowing in!
NOT like it was in OP:
safeup node --version 0.90.33
Should we use this or wait for a restart @joshuef
While we wait to know, I can tell that both PUTs and GETs are happening on my machine according to VDash.
But yeah, I just blindly tried one smaller and one higher versions, and the latter seems to work. No idea if it is good for the test or not.
Thanks, everything works now. :slight_smile:
I would say if it’s working for @Toivo we should go for it.
Using safenode v0.90.34 I immediately got some PUTS but am not seeing store cost or payment messages in the logs. I doubt those have changed? :man_shrugging:
I also haven’t seen any GETS but if Toivo is seeing them I guess that’s just my node.
EDIT: I have a store cost message. I guess the above makes sense because I won’t be asked to quote until some new chunks are coming, and I won’t see payment until a client decides to pay! :man_facepalming:
Im very happy to see how this testnet has started for the client side. Client uploads seems to work way smoother than the previous couple of testnets.
During my uploads, 4 chunks gave the following error at first (and in the end those where repaid correctly without problems!)
> Cannot get store cost for NetworkAddress::ChunkAddress(a7e573(10100111)… - - a7e5730880fbfa71e2dc23f49aaca3e14de9ac618ac8beeb3776e26786f0fa4d) with error CouldNotSendMoney(“Network Error Not enough store cost prices returned from the network to ensure a valid fee is paid.”)
Upload/Download statistics for a 604MB video file:
Upload with default settings: 108 minutes
Upload with -c 50 --batch-size 100: 67 minutes
Download: 19 minutes
Great job Maidsafe team!!! :tada:
Okay, so first batch of files uploaded using -c 10 --batch-size 5
Worked after a few re-uploads
Trying second set of files with -c 20 --batch-size 10 – trying to keep it proportional, not sure if it will make a difference. In my experience with previous net, my upload speed doesn’t like the large batch sizes … but also failed often after trying one round of reuploads - this net seems okay to try multiple reuploads - not sure if that is one of the new fixes or not, or if I was just unlucky in previous net.
Still getting the deserialized bytes don't encode a group element error
willie@gagarin:~$ safe files upload -c50 --batch-size=10 /fgfs/Aircraft/A340-313X/
🔗 Connected to the Network                                                     Total number of chunks to be stored: 2118
Error:
   0: Transfer Error Bincode error:: deserialized bytes don't encode a group element.
   1: Bincode error:: deserialized bytes don't encode a group element
   2: deserialized bytes don't encode a group element
   sn_cli/src/subcommands/files.rs:195
willie@gagarin:~$  safe -V
sn_cli 0.82.0
willie@gagarin:~$ echo $SAFE_PEERS
/ip4/142.93.76.173/tcp/46229/p2p/12D3KooWQi1eeRbwtRWRvYTSQ2gSKt6M8QjseS65Hwzb7PDGKghE
What am I missing?
Can you upload a single file?
The year of the testnets continues with more exciting tests.
And the ants keep marching on raising even more testnets.
Nope…
willie@gagarin:~$ safe files upload willie03.ics
🔗 Connected to the Network        Total number of chunks to be stored: 4
Error:
duh… I had not grabbed anything from the faucet
but then
willie@gagarin:~$ safe wallet get-faucet 139.59.175.64:8000
Error:
   0: Bincode error:: deserialized bytes don't encode a group element
   1: deserialized bytes don't encode a group element
   sn_cli/src/subcommands/wallet.rs:162
However on my newly fired up Hetzner instance it seems to be OK so far
Yep - looks OK on the cloud instance
safe@IntolerantNetSouthside01:~$ safe files upload main.zip
Transfers applied locally
All transfers completed in 15.020509616s
Total payment: NanoTokens(1538) nano tokens for 4 chunks
Made payment of 0.000001538 for 4 chunks
Stored wallet with cached payment proofs. New balance: 99.999998462
Uploaded chunk #c716fa.. in 0 seconds
Uploaded chunk #85574b.. in 0 seconds
Uploaded chunk #b4f948.. in 0 seconds
Uploaded chunk #485302.. in 0 seconds
Uploaded 4 chunks in 22.065171556s. Current progress is 4/4.
First round of upload complete. Verifying and repaying if required...
======= Verification: 4 chunks to be checked and repaid if required =============
Failed to fetch a chunk ChunkAddress(485302(01001000)..)
After 1.929998274s, verified 4 chunks
======= Verification: 1 chunks were not stored. Repaying them in batches. =============
Failed to fetch 1 chunks. Attempting to repay them.
All transfers completed in 14.0842108s
Total payment: NanoTokens(403) nano tokens for 1 chunks
Repaid and re-uploaded 1 chunks in 17.154251527s
======= Verification: 1 chunks to be checked and repaid if required =============
After 1.589507841s, verified 1 chunks
Uploaded all chunks in 48 seconds
Uploaded main.zip to 48530269f54c46dc11b5f74717604c24bd5b1980da997e9e794c4e74dd82134f
Yes I know its using the old network name - just cosmetic - a reboot will sort that.
