52MB file with -c 50 --batch-size 100…
======= Verification complete: all chunks paid and stored =============
Uploaded all chunks in 2 minutes 25 seconds
42.2MB file->86 chunks
520,8MB file->15018 Chunks
Is this normal?
why does the chunk size change so much?
Hmmmm. Looks buggy in that second one there. Chunks top out at 1mb so that number is way off ![]()
Yep I have a 2.1G file going up that’s 4069 chunks
Sorry my fault. It’s an App folder that shows up as a single file. F**ng OSX…
I have the same error as in the last TestNet:
PS C:\Users\gggg> safe wallet balance --peer-id="<local-node-peer-id>"
Built with git version: 2c47455 / main / 2c47455
Error:
0: I/O error: file name, directory name or volume label syntax is incorrect. (os error 123)
1: File name, directory name or volume label syntax is invalid. (os error 123)
sn_clirc-subcommandswallet.rs:156
None of my 3 nodes have any chunks. Getting errors like this:
get_closest query failed after network inactivity timeout - check your connection: Could not get enough peers (8) to satisfy the request, found 1
And I got another error:
PS C:\Users\gggg> env:SAFE_PEERS = "/ip4/139.59.125.187/tcp/35163/p2p/12D3KooWE75czdXUnZJ59gtMDwNZCyBx24whf9WXbNTmEoCaiUrA"
env:SAFE_PEERS : The term 'env:SAFE_PEERS' is not recognized as the name of a cmdlet, function, script file, or operabl
e program. Check the spelling of the name, or if a path was included, verify that the path is correct and try again.
At line:1 char:1
+ env:SAFE_PEERS = "/ip4/139.59.125.187/tcp/35163/p2p/12D3KooWE75czdXUn ...
+ CategoryInfo : ObjectNotFound: (env:SAFE_PEERS:String) [], CommandNotFoundException
+ FullyQualifiedErrorId : CommandNotFoundException
Please any guidance on what I should change or where I am making a mistake.
Just checking: your local-node-peer-id should be something like ‘12D3KooWPyEFqbrBY7Sfdo1YPMA5ipBXKJzFiNMPfazMC6QaTWSa’
so in that case the command would be
safe wallet balance --peer-id="12D3KooWPyEFqbrBY7Sfdo1YPMA5ipBXKJzFiNMPfazMC6QaTWSa"
You need to include the $ before env.
I think maybe you’re missing the $ in front of the command? $env:SAFE_PEERS…
I’m also puzzled with this beer-id piece
eddy@Hal9000:~$ export SAFE_PEERS="/ip4/139.59.125.187/tcp/35163/p2p/12D3KooWE75czdXUnZJ59gtMDwNZCyBx24whf9WXbNTmEoCaiUrA"
SN_LOG=all safenode
Logging to stdout
Using SN_LOG=all
[2023-09-22T07:56:12.648275Z INFO safenode]
Running safenode v0.90.33
[2023-09-22T07:56:12.648304Z DEBUG safenode] Built with git version: 800753c / main / 800753c
[2023-09-22T07:56:12.648313Z INFO safenode] Node started with initial_peers ["/ip4/139.59.125.187/tcp/35163/p2p/12D3KooWE75czdXUnZJ59gtMDwNZCyBx24whf9WXbNTmEoCaiUrA"]
[2023-09-22T07:56:12.649182Z INFO safenode] Starting node ...
[2023-09-22T07:56:12.651042Z INFO sn_networking::driver] Node (PID: 43937) with PeerId: 12D3KooWAbrVb5p9M5YmNtvL1xXsmN6jWtzMpgWV9PLoyGoH3aZh
[2023-09-22T07:56:12.651332Z DEBUG sn_networking::driver] Using Kademlia with NodeRecordStore!
[2023-09-22T07:56:12.652648Z DEBUG sn_networking::driver] Preventing non-global dials
Node started
PeerId is 12D3KooWAbrVb5p9M5YmNtvL1xXsmN6jWtzMpgWV9PLoyGoH3aZh
You can check your reward balance by running:
`safe wallet balance --peer-id=12D3KooWAbrVb5p9M5YmNtvL1xXsmN6jWtzMpgWV9PLoyGoH3aZh`
Iran
eddy@Hal9000:~$ safe wallet balance --peer-id=12D3KooWAbrVb5p9M5YmNtvL1xXsmN6jWtzMpgWV9PLoyGoH3aZh
Error:
0: I/O error: No such file or directory (os error 2)
1: No such file or directory (os error 2)
sn_cli/src/subcommands/wallet.rs:156
eddy@Hal9000:~$ `safe wallet balance --peer-id=12D3KooWAbrVb5p9M5YmNtvL1xXsmN6jWtzMpgWV9PLoyGoH3aZh`
Error:
Command 'Built' not found, did you mean:
command 'guilt' from deb guilt (0.36-2)
command 'quilt' from deb quilt (0.66-2.1)
Try: sudo apt install <deb name>
You need quotes around the address
safe wallet balance --peer-id="12D3KooWAbrVb5p9M5YmNtvL1xXsmN6jWtzMpgWV9PLoyGoH3aZh"
Yeah I also did that before
eddy@Hal9000:~$ safe wallet balance --peer-id="12D3KooWAbrVb5p9M5YmNtvL1xXsmN6jWtzMpgWV9PLoyGoH3aZh"
Error:
Error:
Error:
how is every ones nodes getting on im not getting any gets or puts and end up with this in the logs
[2023-09-22T11:15:58.980011Z TRACE sn_networking::event] Query task QueryId(1) returned with peers GetClosestPeersOk { key: [0, 32, 4, 44, 241, 222, 172, 194, 109, 25, 129, 173, 147, 190, 178, 79, 208, 71, 47, 53, 248, 171, 122, 170, 211, 92, 138, 167, 224, 235, 208, 6, 71, 230], peers: [] }, QueryStats { requests:>
[2023-09-22T11:15:58.980097Z WARN sn_networking] Not enough peers in the k-bucket to satisfy the request
[2023-09-22T11:15:58.980105Z WARN sn_node::api] get_closest query failed after network inactivity timeout - check your connection: Could not get enough peers (8) to satisfy the request, found 1
[2023-09-22T11:15:58.980114Z INFO sn_node::log_markers] OperationFailedAfterNetworkInactivityTimeout
A couple of suggestions…
For the OP:
safe wallet balance’ afterwards for checking the client balance.safe wallet balance’In the node code, change name of the directory ‘received_dbcs’ (in the ‘safe/node/wallet’ directory.)
I have done some uploads with the default settings and things went smoothly and seemed fast. A directory of four files totalling 56MB took 3m 25s.
My node has been running for 23 minutes but has no records which seems a bit slow to get going. Everything looks ok otherwise. ![]()
I’ll fire a massive upload and see how that goes!
I am having node issues too.
But, I have barely woken up and that may be the culprit.
Anyhow if it is not me that would be great to know.
Same for me
I tried several do overs using different initial peers from the OP
I was about to do that, no dice?
