could be a user self compiled executable, forgot to setup the correct PK.
OR, some bug in our arm build release flow, that used incorrect key.
I’m also seeing this “wrong” key in all of my logs (but I believe I’m on the latest version):
$ safenode --version
safenode cli 0.108.4
$ grep -h "Using default PAYMENT_FORWARD_PK" ~/.local/share/safe/node/*/logs/safenode.log*
[2024-06-29T17:51:59.405497Z WARN sn_transfers] Using default PAYMENT_FORWARD_PK: a585839f0502713a0ed6a327f3bd0c301f9e8fe298c93dd00ed7869d8e6804244f0d3014e90df45cd344a7ccd702865c
I used safeup to get the latest version. Wondering how widespread this problem is?
Just to clarify, that’s the standard ARM binary, as downloaded by safenode_manager, not compiled
Maybe was fixed for the alpha releases, but not for the regular releases, @chriso (I believe you were on leave when that happened)?
This sounds familar to me - i suspect i’m experiencing the same issue here.
I don’t think it can be widespread. All I’m running is ARM based nodes and they are earning and that is being relfected using ‘/rank’ in Discord.
I tried that search for the "Using default PAYMENT_FORWARD_PK"
and found it on 5 nodes all on the same machine:-
[2024-07-01T10:16:10.571967Z WARN sn_transfers] Using default PAYMENT_FORWARD_PK: a585839f0502713a0ed6a327f3bd0c301f9e8fe298c93dd00ed7869d8e6804244f0d3014e90df45cd344a7ccd702865c
[2024-07-01T10:17:03.896764Z WARN sn_transfers] Using default PAYMENT_FORWARD_PK: a585839f0502713a0ed6a327f3bd0c301f9e8fe298c93dd00ed7869d8e6804244f0d3014e90df45cd344a7ccd702865c
[2024-07-01T10:17:56.788396Z WARN sn_transfers] Using default PAYMENT_FORWARD_PK: a585839f0502713a0ed6a327f3bd0c301f9e8fe298c93dd00ed7869d8e6804244f0d3014e90df45cd344a7ccd702865c
[2024-07-01T10:18:49.878621Z WARN sn_transfers] Using default PAYMENT_FORWARD_PK: a585839f0502713a0ed6a327f3bd0c301f9e8fe298c93dd00ed7869d8e6804244f0d3014e90df45cd344a7ccd702865c
[2024-07-01T10:19:42.932975Z WARN sn_transfers] Using default PAYMENT_FORWARD_PK: a585839f0502713a0ed6a327f3bd0c301f9e8fe298c93dd00ed7869d8e6804244f0d3014e90df45cd344a7ccd702865c
that’s 5 different nodes at the same location on the same machine. There was a powercut there this morning and that is the time the machine came up again.
It looks like it was part of the startup:-
[2024-07-01T10:16:10.542264Z INFO sn_networking::driver] Listening on ListenerId(1) with addr: "/ip4/0.0.0.0/udp/0/quic-v1"
[2024-07-01T10:16:10.556492Z INFO safenode::rpc_service] RPC Server listening on 127.0.0.1:44947
[2024-07-01T10:16:10.569530Z DEBUG sn_node::node] Replication interval set to 35s
[2024-07-01T10:16:10.570845Z DEBUG sn_node::node] BadNodesCheck interval set to 220s
Hmmm, I’m a bit confused (probably just my ignorance)…
According to @qi_ma above, the key starting with “a585839f” is the wrong key, so I’m a bit lost!
Depends on the version you are running. I am guessing it was the latest version
Yes, I’m definitely running the latest version:-
Version: 0.108.4
But my point is that this message that @lis was talking about seems to be a result of a normal startup.
On looking further in the logs I see this from a few seconds later:-
[2024-07-01T10:16:11.996725Z WARN sn_transfers::genesis] Using compile-time GENESIS_PK: b38f61b8df2cc7d86ceb1039cc23c9e1e2857a97e59ce01a6b1a5d6f7fa5311b521efb158fcdb66113986058ec9e25c8,GENESIS_SK=32b5510bf273d5e15bbb31b65987cee62d41ab2b38f398ed780a47a8d3e281e2,FOUNDATION_PK=84418659a8581b510c40b12e57da239787fd0d3b323f102f09fae9daf2ac96907e0045b1653c301de45117d393d92678,NETWORK_ROYALTIES_PK=8c027130571cea2387a0ceb37c14fec12849015be1573ea6d0a8e4d48da2c1fbe2907ae7503bb7c385b21e2d7ac9d6ff,PAYMENT_FORWARD_PK=8c2f406a52d48d48505e1a3fdbb0c19ab42cc7c4807e9ea19c1fff3e5148f3bbe53431ec5a07544aaeef764e073e4b2f,NETWORK_VERSION_MODE=
So it looks like the PAYMENT_FORWARD_PK is then changed to what other nodes use. Because I see that address being used on other nodes.
The point was that the ARM build was wrong. There is at least 2 ARM builds for 0.108.4 if I am not mistaken
That’s right, I believe the only one that had the right PK was 108.3-alpha, but the full release reverted back to the wrong PK
There has not been a build fixing the key issue on ARM yet. It should be coming very soon.
Sorry for the negativity - but it would have been nice to know this a couple of weeks ago.
There has been a lot of complaints about nanos not showing up in discord - but this is practically the first time I’ve seen this problem confirmed (maybe my bad, maybe I missed it?)
How do I compile launch pad for Ubuntu 24 and not make any mistakes? I want to use this for the Beta.
Should I downgrade my arm nodes or does the ranking bot pick up the other earnings too? (since this issue is known for >3 weeks now…?)
Thank you for pointing this out - my earnings were lower than I expected but I thought I screwed up my deployment…
For the records, I restarted my nodes with 108.3-alpha.1 and got 10 nanos forwarded with the correct PK,
grep "Total forwarded amount" /var/log/safenode/safenode*/*.log* | awk '$NF
> 0'
/var/log/safenode/safenode4/safenode.log:[2024-07-03T03:50
:15.902585Z INFO sn_node::node] Reward forwarding sending
1 spends in this iteration. Total forwarded amount: 10
/var/log/safenode/safenode4/safenode.log:[2024-07-03T03:54
:25.912072Z INFO sn_node::node] Reward forwarding sending
and they got registered correctly by the bot.
This confirms my suspicions above.
While we wait for the correction by the development team, do you know what the instructions are to ask safenode-manager to use version 108.3-alpha.1 instead of the current one ?
Ok I found the answer above… I should have read ![]()
safenode-manager add --count 1 --version 0.108.3-alpha.1
