Beta Phase 2: Final Leaderboard Announcement
:loudspeaker: Beta Phase 2: Final Leaderboard Announcement :loudspeaker:
Token Adjustment:
  • The reward pool, initially set at 125K tokens, has been adjusted to 87K tokens to reflect the shortened testing period from 10/24/2024 16:38 to 10/29/2024 14:38. Here’s the math behind the adjustment: (125,000/168) ∗ 118
Calculation Method:
  • Rewards were calculated based on the ending balance at the most recent snapshot to ensure fairness and accuracy. :bar_chart: View the leaderboard here, and search by your ETH wallet address.
Additional Updates:
  • Our team continues working hard to reduce resource consumption on nodes. Remember, a stable and healthy node is a happy node! (And an earning node)
  • And a little heads-up… I’ve heard whispers that @Bux is preparing something BIG for node operators by Tuesday! :shushing_face:
I can’t find my address in the list:
0xB13a508EF65b16955d7448876b665700Fed6F216
@rusty.spork @JimCollinson @Bux
this is more than a little bit disappointing I was under the impression that rewards were due where they were earned not where they ended up. this is just a snap shot of the final locations of the attos.
so i lost over 50% of my rewards uploading and giving away tokens for testing.
also the hot wallet that i used for uploads is on the leader board despite never having a single node attached to it.
I’m very sure about this too tbh but don’t manage to find the statements on discord anymore :open_mouth: discord looks like a difficult tool to communicate exact rules of the games it seems Oo …
iv been throwing the private key for the hot wallet around with out a care in the world as no nodes were earning into it.
and my nodes are only earning into a trezor secured wallet.
in Bulgarian we have a saying: There is no kindness that goes unpunished :frowning:
Check out the Dev Forum
we have that one as well “No good deed goes unpunished” :rofl: :rofl:
Maybe there is some additional clarification now needed for the current phase @JimCollinson
Will reward payout be treated the same again?
final balance is what counts for TGE…?
(Might influence a bit what we do before tge since data is not permanent and spent coin do cost real money)
For current phase - I understood that [after the Oct launch,] both earning AND spending [Attos] for uploading would be rewarded? Now I am reading that ANT [balances] will be exchanged for MAID/eMAID/? on 1:1 basis. I am confused too.
Incredibly, it’s as if the confusion from the beta waves carries over to the live network. It’s as if nothing has been learned from the past mistakes… Very sad…
For the attos earned (or balances of account???) will be exchanged 1:1 for the network token after TGE. MAID/eMAID will also be able to be exchanged for the network token too 1:1. We’ve been told that we can keep our (e)MAID till the Native token is introduced becoming the network token and exchange our MAID/eMAID then.
According to the block explorer, there seems to be no payments/earnings until after launch on the 29th. No records at the old contract address, but I see 100 payments since launch on the new contract address.
This should not be news. This system has not changed over previous leaderboards.
Although don’t get me wrong I’m not opposed to the idea of your approach/logic.
To me all of this sounded like it’s about the earning process … Not the movement of coin later on
So to be clear - same pattern with balances is planned for the period now until TGE @rusty.spork?
I made the same assumption as it would encourage people to use earned tokens for uploads and testing of the network by getting the juices flowing.
Hi Rusty, i honestly don’t understand it. There are 100+ transactions but no amounts related to my adress. And i dont see my adress in the leaderboard, but according to my data 17 ATTOS were farmed. Is this an error, or is there something that I am overlooking here?
That last one point from me was me responding to someone asking about what the process is for the first phase of beta.
i.e:
  • We’ll contact you via your registered discord account to give you the redemption instructions, and collect the payment address for reward earned in the first phase (where we had native tokens)
  • For the second phase, we already have your address, so will pay out to that.
The now 110 transactions are/will pay to your address. You can see ANT accumulating in my screenshot. The leaderboard posted was for node earnings from 10/24/2024 to 10/29/2024. During that period the blockchain saw no transactions for your wallet address, which is what we based the leaderboard off of.
Ok thanks for the explanation :+1:t2:
The actual question being asked here by @riddim though is not that and not what Rusty answered
Since the last leaderboard used balance of an addresses will the TGE exchange post Oct 29th launch use balance as well
In other words I have 4 addresses each with attos. Then prior to TGE I put all attos into one address what will happen at TGE?
Only the one address get the network token attos (IE using the balance amt) OR will all 4 get the network token attos for their earned amounts?
