Am I the only one concerned?
Windows Defender keep raising alarm pretending that node-launchpad.exe is a “Trojan:Script/Wacatac.B!ml” and must be deleted.
yes.
email Microsoft and tell them to sort it out there node hating defender ![]()
safeup is only needed for downloading the latest versions, or older versions, of node, client and node-manager. Maybe you already have it installed?
You should have left it at least until rewards
probably would have caused me a mental breakdown though ![]()
you will need the rewards when you actually come up the road and settle up that beer tab with myself and the southside lol
To get my first test Tokens, I execute “safe wallet get-faucet 161.35.173.105:8000” but when I then check my wallet balance, it still shows 0.000000000… Do I miss something?
To be honest I can’t remember how they were started so just going to leave them. You can have the rewards of this one ![]()
what we are looking for is it to look like this
Logging to directory: "/home/ubuntu/.local/share/safe/client/logs/log_2024-05-26_14-34-04"
safe client built with git version: 2a695ca / alpha-reward-test / 2a695ca / 2024-05-24
Connecting to the network with 50 peers
🔗 Connected to the Network Requesting token for wallet address: a5c095dff47b166123789b7af980ab9e8c3e99f5aa255836143ebcbaf0c3691559f7a70d259324c1a0176e10feda13db
Successfully parsed transfer.
Successfully verified transfer.
Old balance: 1.997885113
New balance: 2.997885113
Successfully got tokens from faucet.
what is the out put of
safe -V
iv not really played with windows but you are on the correct version and i see connected to the network so all good.
have you been playing on other test nets on this PC?
if so you may need to clear out the old client data.
as per OP for windows do this command but replace the username bit with your own username ![]()
No actually I’have always had the same issue. I thought it was because I was late in the testnet so the faucet was stoped at that time, but today with the new testnet, stille the issue…
I’ve done a clear and still no tokens.
I am running Windows 10 Pro (version 22H2) from my home computer.
hmm not sure maybe try with command prompt and not in power shell ?
@Vort you use windows have you got any suggestions ?
I’ve just tried with command prompt and with powershell started as an administrator, still nothing…
Yes if anyone has an idea please share ![]()
can you download from the network ?
safe files download "BegBlagandSteal.mp3" 3509bad03dc869dec883c7b44662c3503d2517fa9e828bb64f4dbe719d3837bf
ill try and send you a coin what is your address ?
safe wallet address
Here it is ![]()
943c2c4c10797e368a074990fe070ad2e40f5c5dc593dec325cc8a5a5d5c6d29a6893fefc25a93562fac2ad5fd1f3735
try this out
safe wallet receive 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
Here are my logs… But I can’t find anything really obvious…
safe.zip (18.6 KB)
