The objective of this testnet is to test that network royalties payments are made by clients as part of content storage payments, and that they are submitted to nodes when uploading the content.
Nodes are expected to not only verify that network royalties payments are valid, but they shall also be sending notifications through gossipsub for the beneficiary to subscribe to and receive the cash notes. In this testnet, our genesis node is expected to collect such royalties payments cash notes so we can check they are received and in good shape to deposit them to a local wallet, mimicking what the beneficiary of these royalties payments would be able to do once its public key is setup in the launched network.
Other interesting updates since the last testnet was launched:
- Weāve been tweaking the upload/verification process to speed things up (not blindly retrying).
- Nodes can now specify the number of log files to keep
- old hat hashing of content that was still pointlessly being done node-side has been removed.
- Node users can specify the
metricsport if they are building for that feature. - Various memory/replication optimisations.
Network Details
Node version: 0.96.19
Client version: 0.84.34
Faucet url: 138.68.153.228:8000
We have 101 droplets running a total of 2001 nodes. One droplet has 2vcpu and 4GB of memory.
If you are a regular user, see the āquickstartā section for getting up and running.
If you are a first-time user, or would like more information, see the āfurther informationā section.
Quickstart
safeup client --version 0.84.34
safeup node --version 0.96.19
Run a Node
Linux/macOS:
safenode
Windows:
safenode
Check local nodeās reward balance
Your local nodeās peer id will be printed to the terminal on startup with an example command). (You can also retrieve this from the node directory.)
Linux/macOS:
safe wallet get-faucet 138.68.153.228:8000
Windows:
To do this with non-default concurrency or batch-sizes (along with SAFE_PEERS set as above):
safe files upload -c 10 --batch-size 40 <directory-path>
10 and 40 being the integer values you want to set for each
Further Information
Obtaining Binaries
Installing Safeup
Installing Binaries
safeup client --version 0.84.34 # get a specific version
safeup node --version 0.96.19 # get a specific version
The binaries are installed to ~/.local/bin on Linux and macOS, and on Windows they go to C:\Users\<username>\safe. Windows doesnāt really have a standard location for binaries that doesnāt require elevated privileges.
The safeup tool will modify the PATH variable on Linux/macOS, or the user Path variable on Windows. The effect of this is that the installed binaries will then become available in your shell without having to refer to them with their full paths. However, if youāre installing for the first time, you may need to start a new shell session for this change to be picked up.
Running a Node
You can participate in the testnet by running your own node. At the moment, you may not be successful if youāre running the node from your home machine. This is a situation we are working on. If you run from a cloud provider like Digital Ocean or AWS, you should be able to participate.
# Linux/macOS
safenode
# Windows
safenode
This will output all the logs to the filesystem, with the location of logs being platform specific:
# Linux
# macOS
# Windows
# Linux/macOS
# Windows
Connecting as a Client
Using the Client
Youāll first need to get some Safe Network Tokens:
safe files download
# Linux
# macOS
# Windows
safe file download [directory/filename] [XORURL]
Troubleshooting
Cleanup
If youāve used previous versions of the network before and you find problems when running commands, you may want to consider clearing out previous data (worthless DBCs from previous runs, old logs, old keys, etc.).
# Linux
rm -rf ~/.local/share/safe
# macOS
# Windows
or
rmdir C:\Users\<username>\AppData\Roaming\safe -r -Force
If you encounter a problem running any of our binaries on Windows, itās possible you need the Visual C++ Redistributable installed.d
