Yes ![]()
some bug in parsing whitespaces ![]()
what they got in common is the “phonk” that is the main folder name!
Oooh ok I see, not exactly what you wanted.
But that’s great ![]()
Again this “NotEnoughChunks” error from AWS which cannot yet join as a node
ubuntu@ip-172-31-7-155:~$ safe files get "safe://hyryyryynruxz7dbgejeozr7rjfepfpt785hdzujm4xnkkpze87ix7zg53h1yeuy?v=hqhh61i5eue5bf96nn9917gzhu4wjnbxnnms6ggu7phws9bjeexyy"
Error:
0: NetDataError: Failed to GET Blob: NotEnoughChunks(3, 1)
/rustc/f1edd0429582dd29cccacaf50fd134b05593bd9c/library/core/src/result.rs:1914
Backtrace omitted.
I’m trying to node join as per @Southside’s port forwarning tip. Now I get warnings and errors.
INFO 2021-12-19T18:48:42.417774Z [sn/src/routing/core/bootstrap/join.rs:L505]:
➤ join {network_genesis_key=PublicKey(03a4…e396) target_section_key=PublicKey(03a4…e396) recipients=[Peer { name: 46c749(01000110)…, addr: 167.71.131.135:12000, connection: Some(Connection { id: 93825005165360, remote_address: 167.71.131.135:12000, … }) }]}
➤ send_join_requests {join_request=JoinRequest { section_key: PublicKey(0373…7551), resource_proof_response: None, aggregated: None } recipients=[Peer { name: 0d5374(00001101)…, addr: 167.172.57.225:12000, connection: None }, Peer { name: 340a7b(00110100)…, addr: 167.172.53.54:12000, connection: None }, Peer { name: 767610(01110110)…, addr: 167.172.49.98:12000, connection: None }, Peer { name: 76c2d6(01110110)…, addr: 167.71.131.135:12000, connection: Some(Connection { id: 93825005165360, remote_address: 167.71.131.135:12000, … }) }, Peer { name: 8df9d1(10001101)…, addr: 167.172.62.117:12000, connection: None }, Peer { name: b4f7f5(10110100)…, addr: 167.172.61.82:12000, connection: None }, Peer { name: f431a3(11110100)…, addr: 167.172.53.134:12000, connection: None }] section_key=PublicKey(0373…7551) should_backoff=true}
➤ Sending JoinRequest { section_key: PublicKey(0373…7551), resource_proof_response: None, aggregated: None } to [Peer { name: 0d5374(00001101)…, addr: 167.172.57.225:12000, connection: None }, Peer { name: 340a7b(00110100)…, addr: 167.172.53.54:12000, connection: None }, Peer { name: 767610(01110110)…, addr: 167.172.49.98:12000, connection: None }, Peer { name: 76c2d6(01110110)…, addr: 167.71.131.135:12000, connection: Some(Connection { id: 93825005165360, remote_address: 167.71.131.135:12000, … }) }, Peer { name: 8df9d1(10001101)…, addr: 167.172.62.117:12000, connection: None }, Peer { name: b4f7f5(10110100)…, addr: 167.172.61.82:12000, connection: None }, Peer { name: f431a3(11110100)…, addr: 167.172.53.134:12000, connection: None }]
WARN 2021-12-19T18:49:42.425811Z [sn/src/routing/core/comm.rs:L280]:
➤ send {recipients=[Peer { name: 0d5374(00001101)…, addr: 167.172.57.225:12000, connection: None }, Peer { name: 340a7b(00110100)…, addr: 167.172.53.54:12000, connection: None }, Peer { name: 767610(01110110)…, addr: 167.172.49.98:12000, connection: None }, Peer { name: 76c2d6(01110110)…, addr: 167.71.131.135:12000, connection: Some(Connection { id: 93825005165360, remote_address: 167.71.131.135:12000, … }) }, Peer { name: 8df9d1(10001101)…, addr: 167.172.62.117:12000, connection: None }, Peer { name: b4f7f5(10110100)…, addr: 167.172.61.82:12000, connection: None }, Peer { name: f431a3(11110100)…, addr: 167.172.53.134:12000, connection: None }] delivery_group_size=7 wire_msg=WireMsg { header: WireMsgHeader { version: 1, msg_envelope: MsgEnvelope { msg_id: MessageId(af78…373c), msg_kind: NodeAuthMsg(NodeAuth { section_pk: PublicKey(0373…7551), public_key: PublicKey(ae52…2c2a), signature: Signature(b81d…2d09) }), dst_location: Section { name: ae522e(10101110)…, section_pk: PublicKey(0373…7551) } } } }}
➤ during sending, received error Connection(TimedOut)
WARN 2021-12-19T18:49:42.427027Z [sn/src/routing/core/comm.rs:L280]:
WARN 2021-12-19T18:49:42.429188Z [sn/src/routing/core/comm.rs:L280]:
ERROR 2021-12-19T18:49:42.429212Z [sn/src/routing/core/bootstrap/join.rs:L589]:
➤ Failed to send message WireMsg { header: WireMsgHeader { version: 1, msg_envelope: MsgEnvelope { msg_id: MessageId(af78…373c), msg_kind: NodeAuthMsg(NodeAuth { section_pk: PublicKey(0373…7551), public_key: PublicKey(ae52…2c2a), signature: Signature(b81d…2d09) }), dst_location: Section { name: ae522e(10101110)…, section_pk: PublicKey(0373…7551) } } } } to [Peer { name: 8df9d1(10001101)…, addr: 167.172.62.117:12000, connection: None }, Peer { name: b4f7f5(10110100)…, addr: 167.172.61.82:12000, connection: None }, Peer { name: f431a3(11110100)…, addr: 167.172.53.134:12000, connection: None }]
Encountered a timeout while trying to join the network. Retrying after 3 minutes.
double check the port and ip address its forwarding too
Thanks ! I tried, but I don’t know anything about port forwarding or even TCP/IP so I just ended up crashing my router for a while
UPnP seems activated by default thought ![]()
my node showed error connection time out I guess the network is dying?
the node is still online as I see now
I’m pretty sure I input the stuff correctly, but my router setup is a bit weird too. I’m using a separate router as a bridge (or whatever it’s called). I feel I’m a bit out of my league. Anyway, the woman wants us to watch a series now.
I may try again later.
EDIT: Nope. The port seems to have changed again. Anyway, see you later.
same here on that one
administrator@Test-Node:~/Desktop/del$ safe files get "safe://hyryyryynruxz7dbgejeozr7rjfepfpt785hdzujm4xnkkpze87ix7zg53h1yeuy?v=hqhh61i5eue5bf96nn9917gzhu4wjnbxnnms6ggu7phws9bjeexyy"
Error:
Backtrace omitted.
just tried another put and got the following:
Error:
0: ClientError: Failed to obtain any response
1: Failed to obtain any response
/rustc/f1edd0429582dd29cccacaf50fd134b05593bd9c\library\core\src\result.rs:1914
Backtrace omitted.
im starting to see time out errors on one of my nodes ![]()
me too, but it seems to continue working
I see 1GB usage with 2GB max capacity
Joined the party a little late, only once the 4GB droplets were up!
Spun up 2 LXCs with 8GB ram each on different hosts.
18:28:00 UTC - sn_node join network initiated
18:39:00 UTC - Safe cli put operation initiated
safe-cli-113:~/uploads# ls -latr
total 1572876
drwx------ 4 root root 4096 Dec 19 18:37 ..
-rw-r--r-- 1 root root 536870896 Dec 19 18:37 sample2.txt
-rw-r--r-- 1 root root 536870896 Dec 19 18:37 sample1.txt
drwxr-xr-x 2 root root 4096 Dec 19 18:37 .
-rw-r--r-- 1 root root 536870896 Dec 19 18:37 sample3.txt
safe-cli-113:~/uploads# cd ..
safe-cli-113:~# date
Sun Dec 19 18:39:00 UTC 2021
safe-cli-113:~# safe files put -r ./uploads/
The safe put command was trying for 25+ mins then finally error’ed out:
Error:
Safe-109: container hosting the sn_node
Safe-cli-113: container hosting the safe cli
very very slowly I seem to be getting the phonk tracks to my original node
willie@gagarin:~$ safe files get "safe://hyryyryynruxz7dbgejeozr7rjfepfpt785hdzujm4xnkkpze87ix7zg53h1yeuy?v=hqhh61i5eue5bf96nn9917gzhu4wjnbxnnms6ggu7phws9bjeexyy"
/phonk/ANTICXLTXRE, OBLXKQ - EXTRA REASON (OUT ON ALL PLATFORMS).mp3 - files: 1 of 16 (6%). transfer: 0 of 77777904 (0%), file: 0 of 1999211 (0%)
/phonk/ANTICXLTXRE, OBLXKQ - EXTRA REASON (OUT ON ALL PLATFORMS).mp3 - files: 1 of 16 (6%). transfer: 1999211 of 77777904 (3%), file: 1999211 of 1999211 (100%)
/phonk/ARCANE VOL. 3 (HALLOWEEN SPECIAL).mp3 - files: 2 of 16 (12%). transfer: 1999211 of 77777904 (3%), file: 0 of 17685601 (0%)
/phonk/DEVTHMACHINE.mp3 - files: 3 of 16 (19%). transfer: 1999211 of 77777904 (3%), file: 0 of 2217341 (0%)
/phonk/DEVTHMACHINE.mp3 - files: 3 of 16 (19%). transfer: 4216552 of 77777904 (5%), file: 2217341 of 2217341 (100%)
/phonk/DVRST - THINKIN OF A DRIVE BY.mp3 - files: 4 of 16 (25%). transfer: 4216552 of 77777904 (5%), file: 0 of 2382324 (0%)
/phonk/FAR AWAY.mp3 - files: 5 of 16 (31%). transfer: 4216552 of 77777904 (5%), file: 0 of 2970499 (0%)
/phonk/Fly.mp3 - files: 6 of 16 (38%). transfer: 4216552 of 77777904 (5%), file: 0 of 1943987 (0%)
/phonk/I NEED A YESTERDAY.mp3 - files: 7 of 16 (44%). transfer: 4216552 of 77777904 (5%), file: 0 of 2338578 (0%)
/phonk/IZANAGI feat 1ODUM DEFECT.mp3 - files: 8 of 16 (50%). transfer: 4216552 of 77777904 (5%), file: 0 of 2894866 (0%)
/phonk/Juice WLRD - RUN (CRYSTXLMXNE Remix).mp3 - files: 9 of 16 (56%). transfer: 4216552 of 77777904 (5%), file: 0 of 2991833 (0%)
/phonk/LIGHT$ OUT.mp3 - files: 10 of 16 (62%). transfer: 4216552 of 77777904 (5%), file: 0 of 3169450 (0%)
/phonk/Night Car Music • Gangster Rap Trap Bass Cruising.mp3 - files: 11 of 16 (69%). transfer: 4216552 of 77777904 (5%), file: 0 of 24874476 (0%)
/phonk/Night Rider drift /phonk beat (prod.suave lee).mp3 - files: 12 of 16 (75%). transfer: 4216552 of 77777904 (5%), file: 0 of 2853928 (0%)
/phonk/OBLIVION.mp3 - files: 13 of 16 (81%). transfer: 4216552 of 77777904 (5%), file: 0 of 2864756 (0%)
/phonk/SLIDE THRU [FORTHCOMING TAPE].mp3 - files: 14 of 16 (88%). transfer: 4216552 of 77777904 (5%), file: 0 of 2151735 (0%)
/phonk/bbno /phonk.mp3 - files: 15 of 16 (94%). transfer: 4216552 of 77777904 (5%), file: 0 of 2033874 (0%)
Yes its into 2 directories
Error:
0: NetDataError: Failed to GET Blob: NoResponse
Yeah when I actually look at the downloaded files in ~/phonk it’s not such a pretty picture
willie@gagarin:~/phonk$ ls -al
total 4172
drwxrwxr-x 4 willie willie 4096 Dec 19 19:17 .
drwxrwxr-x 323 willie willie 36864 Dec 19 18:43 ..
-rw-rw-r-- 1 willie willie 1999211 Dec 19 18:43 'ANTICXLTXRE, OBLXKQ - EXTRA REASON (OUT ON ALL PLATFORMS).mp3'
-rw-rw-r-- 1 willie willie 0 Dec 19 18:43 'ARCANE VOL. 3 (HALLOWEEN SPECIAL).mp3'
drwxrwxr-x 2 willie willie 4096 Dec 19 19:15 'bbno '
-rw-rw-r-- 1 willie willie 2217341 Dec 19 18:48 DEVTHMACHINE.mp3
-rw-rw-r-- 1 willie willie 0 Dec 19 18:48 'DVRST - THINKIN OF A DRIVE BY.mp3'
-rw-rw-r-- 1 willie willie 0 Dec 19 18:51 'FAR AWAY.mp3'
-rw-rw-r-- 1 willie willie 0 Dec 19 18:53 Fly.mp3
-rw-rw-r-- 1 willie willie 0 Dec 19 19:17 'if i never find myself..mp3'
-rw-rw-r-- 1 willie willie 0 Dec 19 18:56 'I NEED A YESTERDAY.mp3'
-rw-rw-r-- 1 willie willie 0 Dec 19 18:58 'IZANAGI feat 1ODUM DEFECT.mp3'
-rw-rw-r-- 1 willie willie 0 Dec 19 19:00 'Juice WLRD - RUN (CRYSTXLMXNE Remix).mp3'
-rw-rw-r-- 1 willie willie 0 Dec 19 19:03 'LIGHT$ OUT.mp3'
-rw-rw-r-- 1 willie willie 0 Dec 19 19:05 'Night Car Music • Gangster Rap Trap Bass Cruising.mp3'
drwxrwxr-x 2 willie willie 4096 Dec 19 19:07 'Night Rider drift '
-rw-rw-r-- 1 willie willie 0 Dec 19 19:10 OBLIVION.mp3
-rw-rw-r-- 1 willie willie 0 Dec 19 19:12 'SLIDE THRU [FORTHCOMING TAPE].mp3'
It’s phonked
