OFFLINE Another Quicky (run 2 & 3)
I thought only cat put and get worked now?
ok dog works
dog has worked for me
check downloaded and playing safe cat safe://hy8ayqyybz7n1jt3g4ry57xugi35n1i44zmu8hgbfqokixf96kjy7xju1uhxo > The_Bamboos_Present_Kylie_Auldist_-_No_Use.mp4
It’s superfast - is that cos you upgraded the VMs @anon26713768?
chicken talk doesnt work for me its says corrupted in windows 10 groove player
lemme try vlc
no vlc also not working
I get an error trying to join a node:
sascha@sascha-Librem-15-v3:~/.safe/node$ RUST_LOG=safe_network=info,qp2p=info ~/.safe/node/sn_node --skip-auto-port-forwarding
Starting logging to stdout
INFO 2021-12-19T16:39:09.753877Z [sn/src/routing/routing_api/mod.rs:L152]:
➤ 5fef48… Bootstrapping a new node.
➤ send_join_requests {join_request=JoinRequest { section_key: PublicKey(0373…7551), resource_proof_response: None, aggregated: None } recipients=[Peer { name: 0d5374(00001101)…, addr: 167.172.57.225:12000, connection: None }, Peer { name: 340a7b(00110100)…, addr: 167.172.53.54:12000, connection: None }, Peer { name: 767610(01110110)…, addr: 167.172.49.98:12000, connection: None }, Peer { name: 76c2d6(01110110)…, addr: 167.71.131.135:12000, connection: None }, Peer { name: 8df9d1(10001101)…, addr: 167.172.62.117:12000, connection: None }, Peer { name: b4f7f5(10110100)…, addr: 167.172.61.82:12000, connection: None }, Peer { name: f431a3(11110100)…, addr: 167.172.53.134:12000, connection: None }] section_key=PublicKey(0373…7551) should_backoff=true}
➤ Sending JoinRequest { section_key: PublicKey(0373…7551), resource_proof_response: None, aggregated: None } to [Peer { name: 0d5374(00001101)…, addr: 167.172.57.225:12000, connection: None }, Peer { name: 340a7b(00110100)…, addr: 167.172.53.54:12000, connection: None }, Peer { name: 767610(01110110)…, addr: 167.172.49.98:12000, connection: None }, Peer { name: 76c2d6(01110110)…, addr: 167.71.131.135:12000, connection: None }, Peer { name: 8df9d1(10001101)…, addr: 167.172.62.117:12000, connection: None }, Peer { name: b4f7f5(10110100)…, addr: 167.172.61.82:12000, connection: None }, Peer { name: f431a3(11110100)…, addr: 167.172.53.134:12000, connection: None }]
ERROR 2021-12-19T17:16:11.837725Z [sn/src/routing/core/bootstrap/join.rs:L164]:
➤ join {network_genesis_key=PublicKey(03a4…e396) target_section_key=PublicKey(03a4…e396) recipients=[Peer { name: fa91b8(11111010)…, addr: 167.71.134.100:12000, connection: Some(Connection { id: 93825010197648, remote_address: 167.71.134.100:12000, … }) }]}
➤ Node cannot join the network since it is not externally reachable: 138.199.55.46:14016
Unfortunately we are unable to establish a connection to your machine (138.199.55.46:14016) either through a public IP address, or via IGD on your router. Please ensure that IGD is enabled on your router - if it is and you are still unable to add your node to the testnet, then skip adding a node for this testnet iteration. You can still use the testnet as a client, uploading and downloading content, etc. https://forum.autonomi.community/
It should look like this… ''Chicken Talk'' By Richie Kavanagh. - YouTube
I feel they have all been super fast until they seemingly ran out of resources (the mem spikes could also perhaps be a symptom not a cause)
But sure does seem like the upgraded droplets have helped.
I am a node! finally managed!
here is a very sort funny recording of chorchil
safe cat safe://hy8ayqyybznmatq95on4ttwgp65uj6ez7b16iuowou6qa3r5hnac1r4ijoa4y > Winston_Churchill_once_said.mp4
I see in the logs that the max capacity is over 2GB and we have used till now 48MB
57MB now
Following official protests from the Southside Household Gamer community my somewhat arbitary port-forwarding rules have had to be rolled back… My riposte that if they didnt like it they should pay for the bleedin internet themselves fell on deaf ears however…
Soooo…
I solved it by opening my router port forwarding dialog, then running the node join command and looking for the port I was assigned see blue circled bit
then add that port as UDP to your local desktop IP
There was very little funny about the alcoholic peadophile Churchill.
you sure thats not joe biden :rofl:
usage 200MB max 2GB
is this number only for my node all whole network?
If I do that I have to restart my router, and then the port seems to change.
Yes you need to be quick before it times out. THis is a long way from a satisfactory solution.
Im about to try the same kind of thing with an AWS node. Will I be able to get the security group configured before it times out?
some phonk songs to stress test the comnet
safe files get "safe://hyryyryynruxz7dbgejeozr7rjfepfpt785hdzujm4xnkkpze87ix7zg53h1yeuy?v=hqhh61i5eue5bf96nn9917gzhu4wjnbxnnms6ggu7phws9bjeexyy"
74 MB all together
wierd, it put two songs into subfolders where the subfolder is the first part up to a whitespace and then the rest as the song filename
Got it aaaaall. So fast. Amazing.
did it put two songs into a subfolder for you too?
