OFFLINE Another Quicky (run 2 & 3)
sn_cli 0.39.1
safe_network 0.51.6
run 1 1vcpu-1gb-amd
run 2 1vcpu-2gb-amd
run 3 2vcpu-4gb
run 4 live 2vcpu-8gb
rm -rf $HOME/.safe
curl -so- https://install-safe.s3.eu-west-2.amazonaws.com/install.sh | bash
safe networks add comnet https://sn-comnet.s3.eu-west-2.amazonaws.com/node_connection_info.config
safe networks switch comnet
Add a node
RUST_LOG=safe_network=info,qp2p=info ~/.safe/node/sn_node --skip-auto-port-forwarding
test file
safe cat safe://hygoynyybh5bc3afb8i811wj8dnrpqkfx4mog9m3s1owokcz4763x5rhj9fko > spiral.gif
This didn’t work out of the box:
sascha@sascha-Librem-15-v3:~$ RUST_LOG=safe_network=info,qp2p=info ~/.safe/node/sn_node --skip-auto-port-forwarding
bash: /home/sascha/.safe/node/sn_node: No such file or directory
But the following worked:
sascha@sascha-Librem-15-v3:~$ safe cat safe://hygoynyybh5bc3afb8i811wj8dnrpqkfx4mog9m3s1owokcz4763x5rhj9fko > spiral.gif
try
chown <your username> $HOME/.safe/node/sn_node
and
chmod +x $HOME/.safe/node/sn_node
here is the test cockerel for you :slight_smile:
safe cat safe://hygoygyyb1aq95ugj4kyp98gz87px3d9becszpo1hbxmxwrgjfsg778rz88go >cockrel.jpg
BBS mp3
safe cat safe://hygyy1yybp9edeorgb1wyu9yyoofd9nuz3czc9339kx7gdcumq9fx8r6sj9ey >BegBlagSteal.mp3
does not install sn_node
I meant to mention that last night - sorry
Need to grab the version for your CPU from https://github.com/maidsafe/safe_network/releases/tag/safe_network-v0.51.6
Which I am just about to do…
meanwhile I safe cat and :slight_smile:
yes for node install to work you can build safe_network with cargo build --release --features=self-update or just get it from github as you said.
try safe cat "safe://hyryyryynsj55yaumfnqqsbs3dfsp88pk6unky5puybayiz7ko1gibu7ynnboeuy?v=hdj9pfye7ybnz9cu7yornsqoahkuwrtztuetneiymmzxa5gh36zxo"
Damn. It’s fast. I got the BegBlagSteal and the spiral :smirk:
Thanks for the info guys, I should be able to upload as well now.
Edit : And the mazda as well :grin:
Go for it but please keep it under 100Mb
Cos Ah um the HAMMERLORD!!! and if anyone breaks it will be me!!!
It would help to imagine some very bombastic crap power rock in the background at tis point and the sound of crunching wood and bone. PS - this is optional Do not feel obligated.
Meanwhile- this seems much faster than last night
willie@gagarin:~/projects/maidsafe/comnet$ time safe files put ~/5MB.zip
FilesContainer created at: "safe://hyryyryynxqu9mst1euxs6zqqgwxmdjmwepehoepwhfqokagcsg56cyqi46qyeuy?v=h7973w35ta6pf3gayf98snywykaixbyire4jwkrcshe69rtgedkco"
+  /home/willie/5MB.zip  safe://hyfenryybcj4nmrrycotxo9jyjkqb563rorqteq9945iuibj5e9xzbicpe5ky
real	0m47.287s
user	0m2.612s
sys	0m0.679s
BTW Dont try to unzip that 5Mb.zip its just a random file of exactly 5MB for testing - your download
was not corrupted
i used safe files get cause you didnt specify the output of the file :stuck_out_tongue:
I have two nodes online now
  1. at home ubuntu running in virtual box
    2 an arm based oracle node as discoverd by @happybeing
for any one who trying to run a node on a x86 machine with ubuntu
cd ~/.safe/node/
wget https://github.com/maidsafe/safe_network/releases/download/safe_network-v0.51.6/sn_node-0.51.6-x86_64-unknown-linux-musl.tar.gz
tar xf *.tar.gz
chmod +x sn_node
chown <your username> sn_node
if it still fails do a manual port forward in your router to the port mentioned in the start up message
also i had to allow the mentioned port in ufw
getting timeouts now …
 ➤ during sending, received error Connection(TimedOut)
 WARN 2021-12-19T14:59:12.992122Z [sn/src/routing/core/comm.rs:L280]:
	 ➤ send {recipients=[Peer { name: b5a57b(10110101).., addr: 64.227.46.119:12000, connection: Some(Connection { id: 93824998344528, remote_address: 64.227.46.119:12000, .. }) }] delivery_group_size=1 wire_msg=WireMsg { header: WireMsgHeader { version: 1, msg_envelope: MsgEnvelope { msg_id: MessageId(66b0..86d0), msg_kind: NodeAuthMsg(NodeAuth { section_pk: PublicKey(0e5c..02fd), public_key: PublicKey(1fa4..9530), signature: Signature(e686..2407) }), dst_location: Node { name: b5a57b(10110101).., section_pk: PublicKey(0e5c..02fd) } } } }}
 WARN 2021-12-19T14:59:33.513164Z [sn/src/routing/core/comm.rs:L280]:
	 ➤ send {recipients=[Peer { name: 0d1b38(00001101).., addr: 64.227.46.173:12000, connection: Some(Connection { id: 93824998692144, remote_address: 64.227.46.173:12000, .. }) }] delivery_group_size=1 wire_msg=WireMsg { header: WireMsgHeader { version: 1, msg_envelope: MsgEnvelope { msg_id: MessageId(439d..91ee), msg_kind: NodeAuthMsg(NodeAuth { section_pk: PublicKey(0e5c..02fd), public_key: PublicKey(1fa4..9530), signature: Signature(d7c0..7300) }), dst_location: Node { name: 0d1b38(00001101).., section_pk: PublicKey(0e5c..02fd) } } } }}
 WARN 2021-12-19T14:59:45.084178Z [sn/src/routing/core/comm.rs:L280]:
	 ➤ send {recipients=[Peer { name: 34468c(00110100).., addr: 64.227.46.105:12000, connection: Some(Connection { id: 93824997560464, remote_address: 64.227.46.105:12000, .. }) }] delivery_group_size=1 wire_msg=WireMsg { header: WireMsgHeader { version: 1, msg_envelope: MsgEnvelope { msg_id: MessageId(735e..9f17), msg_kind: NodeAuthMsg(NodeAuth { section_pk: PublicKey(0e5c..02fd), public_key: PublicKey(1fa4..9530), signature: Signature(7469..b50d) }), dst_location: Node { name: 34468c(00110100).., section_pk: PublicKey(0e5c..02fd) } } } }}
I put this but can’t cat it now
willie@gagarin:~/projects/maidsafe/comnet$ safe files put "/home/willie/duncan/Duncan's music/Talking Heads -  Psycho Killer.mp3"
FilesContainer created at: "safe://hyryyryyncpb1sfdjioichbdyp4gxfj8tohdtgzhmcmw1j9zurg3xjpp6q66oeuy?v=hx4o64htiwg5hfbdcphbwy6kyb7zq5phxka87i4azbqorowoa1cho"
+  /home/willie/duncan/Duncan's music/Talking Heads -  Psycho Killer.mp3  safe://hygyy1yybz96twx6s877b44t6mk3t15e98c3wfya6pzdn5hadzuh5wwmyno4o
me too, couldn’t join it says timeout and wait 3 minutes to retry
Did I break something ? :sweat_smile:
/Users/ myusername /.safe/node/sn_node --skip-auto-port-forwarding
Starting logging to stdout
INFO 2021-12-19T15:01:14.393995Z [sn/src/bin/sn_node.rs:L160]:
Running safe_network v0.51.6
Unfortunately we are unable to establish a connection to your machine (93.9.80.102:55590) either through a public IP address, or via IGD on your router. Please ensure that IGD is enabled on your router - if it is and you are still unable to add your node to the testnet, then skip adding a node for this testnet iteration. You can still use the testnet as a client, uploading and downloading content, etc. https://forum.autonomi.community/
ERROR 2021-12-19T15:02:15.470882Z [sn/src/bin/sn_node.rs:L208]:
➤ Unfortunately we are unable to establish a connection to your machine (93.9.80.102:55590) either through a public IP address, or via IGD on your router. Please ensure that IGD is enabled on your router - if it is and you are still unable to add your node to the testnet, then skip adding a node for this testnet iteration. You can still use the testnet as a client, uploading and downloading content, etc. https://forum.autonomi.community/
Some nodes have been lost and memory has maxed out on some of the remaining instances again.
I am going to restart with higher capacity now.
Did you go to 2Gb nodes?
yes.
last night 1vcpu-1gb, this was 1vcpu-2gb and we will do 2vcpu-4gb now.
Cool - standing by with an upload just for @Sascha
It is back dbl with 2vcpu-4gb instances.
I am going to ride roller coasters now so this will hopefully stay up for a little while. :roller_coaster:
Can anyone connect?
I’m just hanging here…
willie@gagarin:~/.safe/node$ RUST_LOG=safe_network=info,qp2p=info ~/.safe/node/sn_node --skip-auto-port-forwarding
 INFO 2021-12-19T15:24:06.190391Z [sn/src/routing/routing_api/mod.rs:L152]:
	 ➤ 29b18c.. Bootstrapping a new node.
