OFFLINE Will it be a Quicky? (run 4)
sn_cli 0.39.1
safe_network 0.51.7
run 1 1vcpu-1gb-amd
run 2 1vcpu-2gb-amd
run 3 2vcpu-4gb
run 4 2vcpu-8gb
rm -rf $HOME/.safe
curl -so- https://install-safe.s3.eu-west-2.amazonaws.com/install.sh | bash
safe networks add comnet https://sn-comnet.s3.eu-west-2.amazonaws.com/node_connection_info.config
safe networks switch comnet
Add a node
RUST_LOG=safe_network=info,qp2p=info ~/.safe/node/sn_node --skip-auto-port-forwarding
test file
safe cat safe://hygoynyybh5bc3afb8i811wj8dnrpqkfx4mog9m3s1owokcz4763x5rhj9fko > spiral.gif
BBS.mp3
safe cat safe://hygyy1yybp9edeorgb1wyu9yyoofd9nuz3czc9339kx7gdcumq9fx8r6sj9ey > BegBlagandSteal.mp3
starting off uploading 1.5 Gb of pictures to give it a test
safe cat safe://hy8ayqyybtd67ug3q4fahx3p8ik7iir895f1zry7161fymkrxingukqsg95zo > pexels.mp4
still going?
first batch of 500 mb is up successfully now on second batch of around 1gb
mem-use has gone up a fair bit, interesting to see if it drops once you are done.
If you get an error about the H.264 codec , try
sudo apt install gstreamer1.0-libav
Looks cool in terminal…
So far so good.
Got a node up and running and got me a few chunks
Got BegBlagandSteal + Pexels
Now for some uploading
No luck in trying to join from Oracle instance, though:
 RUST_LOG=safe_network=info,qp2p=info ~/.safe/node/sn_node --skip-auto-port-forwarding -r /volume1/node1 --log-dir /volume1/node1log
Starting logging to file: "/volume1/node1log"
Unfortunately we are unable to establish a connection to your machine (150.230.8.204:51500) either through a public IP address, or via IGD on your router. Please ensure that IGD is enabled on your router - if it is and you are still unable to add your node to the testnet, then skip adding a node for this testnet iteration. You can still use the testnet as a client, uploading and downloading content, etc. https://forum.autonomi.community/
Strange, a router shouldn’t be a problem with a cloud vm
Do we have any clues about this “NotEnoughChunks” error?
willie@gagarin:~$ time safe files put ~/100MBtest
FilesContainer created at: "safe://hyryyryynuy5xo3a3gpap8mn1rd8nyy7kp57kqn53gin9aks3zo8oda9f391yeuy?v=hgip1akd6y1eg5cnzxjfqayrb7yyyobuttozu3uwcoggpcnoq1aho"
E  /home/willie/100MBtest  <ClientError(NotEnoughChunks(100, 80))>
real	0m7.805s
user	0m1.540s
sys	0m0.450s
A treat for your ears at
“safe://hyryyryynq7mt6snkhh54sk861qzk865c8ncybdyqgo8z71uawrnjyn9kiokyeuy?v=hcb44wcjqb9uw675gyousg54fei156kbxs4cuzgpf19gts9qapn3o”
No chickens, promise.
I’ll do the chicken files later
It’s when it timed out trying to fetch all chunks of the file before it can self-decrypt it. Wirthwhile trying with longer timeout setting env var SN_CLI_QUERY_TIMEOUT to something larger than 120 secs which is the default.
I am able to download the pexels.mp4 in ~3min40s.
I got the same
FilesContainer created at: "safe://hyryyryynedtm7zdadcto6b9azhy17umchfmubm9zgbmzpemkzatxzf9bt5moeuy?v=hgip1akd6y1eg5cnzxjfqayrb7yyyobuttozu3uwcoggpcnoq1aho"
E  9780008404390_003.mp3  <ClientError(NotEnoughChunks(52, 38))>
Thats slow, I was much faster than that. This mostly seems very quick so far compared to earlier attempts.
Yeah…it’s usually slow for me for some weird reason, same with my cellphone connection.
14 seconds for me!
I just realised you are seeing that error when uploading a large file not when fetching it…I’m not sure what that is, I’ll have to take a look at it, I’ll do it tomorrow if nobody else does it by then
