🔗 Connected to the Network "The Crow (1994).mkv" will be made public and linkable
Starting to chunk "The Crow (1994).mkv" now.
Chunking 1 files...
Uploading 1733 chunks
Error:
0: Failed to upload chunk batch: Transfer Error Failed to send tokens due to Wallet has pre-unconfirmed tx, resent them and try later..
sn_cli/src/subcommands/files/mod.rs:330
Have you cleaned out your old ~/.local/share/safe/client ?
I had similar earlier. Interestingly when I went to the faucet first time around, my wallet was incremented by 100 and the balance shown from the previous testnet + 100.
But when I tried to upload, I got a similar error to yours.
Blowing the old ~/.local/share/safe/client away and a quick fill-up from the faucet did the trick.
upload of -rw-rw-r-- 1 safe safe 38378760128 Jan 4 18:27 mixtral-8x7b-instruct-v0.1.Q6_K.gguf has commenced.
Lets see how long chunking of 38Gb takes this time.
And then we’ll worry about the upload.
Ooops
Skipping file “/home/safe/mixtral-8x7b-instruct-v0.1.Q6_K.gguf”/PathXorName(“186593626bd3eb91e672a76e3950c8465edccb9d69c024963bb77707407f68ff”) as it could not be chunked: Chunks(SelfEncryption(Io(Os { code: 28, kind: StorageFull, message: “No space left on device” })))
Error:
0: The provided path does not contain any file. Please check your path!
Exiting…
I could have sworn I managed this all in an 80Gb volume previously.
There will be a short delay while I attach a bigger volume…
My old version of this is just under 36gb, and took just over 10 minutes to chunk, which is not a big problem given the time to upload at the moment! Currently chugging along at a not-too-rapid 21 chunks per minute.
0: Failed to upload chunk batch: Transfer Error Failed to send tokens due to Wallet has pre-unconfirmed tx, resent them and try later…
I wondered if I hadn’t cleared out client data sufficiently, so cleared everything again from \AppData\Roaming\safe\client\ but unfortunately hit the same error again.
Yep - just noticed mine has failed with the same error
Error:
I’ll move the logs somewhere safe and restart. Wonder how many chunks it will say it has to upload?
I suppose it would be a smart idea to check with @DavidMc0 and any other potential uploaders just exactly what filename this is saved as and what the checksum is
I renamed the download just for neatness mv mixtral-8x7b-instruct-v0.1.Q6_K.gguf\?download\=true mixtral-8x7b-instruct-v0.1.Q6_K.gguf
Haven’t tried to run a node yet and would like to do it for the first time. However I still see the warning that nodes from home might not be running yet.
What’s the status here? Can I already avoid the cloud?
My main OS is GNU/Linux and I know how to handle port forwarding in the router if that’s needed. In case of positive answer, I might give it a try.
nodes from home are working with port forwarding here is my script for starting and stoping nodes you can have a look at that and see if its of some help
#!/usr/bin/env bash
CLIENT=0.86.90
NODE=0.100.36
FAUCET=134.209.21.136:8000
NODE_PORT_FIRST=4700
NUMBER_NODES=40
NUMBER_COINS=1
NODE_START_DELAY=0
export NEWT_COLORS='
window=,white
border=black,white
textbox=black,white
button=black,white
############################################## select test net action
SELECTION=$(whiptail --title "Safe Network Testnet" --radiolist \
"Testnet Actions " 20 70 10 \
"1" "Upgrade Client & Node to Latest" OFF \
"2" "Upgrade Client to Latest" ON \
"3" "Stop Nodes" OFF \
"4" "Get Test Coins" OFF \
"5" "Start Vdash" OFF \
"6" "Update all and Restart" OFF \
"7" "Josh comnet" OFF 3>&1 1>&2 2>&3)
if [[ $? -eq 255 ]]; then
exit 0
fi
################################################################################################################ Upgrade Client & Node to Latest
if [[ "$SELECTION" == "1" ]]; then
NUMBER_NODES=$(whiptail --title "Number of Nodes to start" --inputbox "\nEnter number of nodes" 8 40 $NUMBER_NODES 3>&1 1>&2 2>&3)
exit 0
fi
############################## count nodes directories and close fire wall
PORTS_TO_CLOSE=$(ls $HOME/.local/share/safe/node | wc -l)
sudo ufw delete allow $NODE_PORT_FIRST:$(($NODE_PORT_FIRST+$PORTS_TO_CLOSE-1))/tcp comment 'safe nodes'
############################## Stop Nodes and delete safe folder
pkill -e safenode
rm -rf $HOME/.local/share/safe
rm -rf $HOME/ip_cache.txt
rm -rf $HOME/node_registry.conf
rm -rf $HOME/resources_*.log
rm $HOME/ntracking/*.log
rm -rf $HOME/ntracking/logs
sudo rm /var/www/ntracking/index.html
sleep 2
############################## install client node and vdash
safeup client --version "$CLIENT"
safeup node --version "$NODE"
cargo install vdash
############################## open ports
sudo ufw allow $NODE_PORT_FIRST:$(($NODE_PORT_FIRST+$NUMBER_NODES-1))/tcp comment 'safe nodes'
sleep 2
############################## start nodes
for (( c=$NODE_PORT_FIRST; c<=$(($NODE_PORT_FIRST+$NUMBER_NODES-1)); c++ ))
do
sleep $NODE_START_DELAY && safenode --port $c --max_log_files 10 --max_archived_log_files 0 2>&1 > /dev/null & disown
echo "starting node on port $c with $NODE_START_DELAY second delay"
NODE_START_DELAY=$(($NODE_START_DELAY+1))
done
sleep 2
############################# get 200 test coins
for (( c=1; c<=2; c++ ))
do
safe wallet get-faucet "$FAUCET"
sleep 1
done
############################# exit to Vdash
#vdash --glob-path "$HOME/.local/share/safe/node/*/logs/safenode.log"
######################################################################################################################## Upgrade Client to Latest
elif [[ "$SELECTION" == "2" ]]; then
############################## Stop client and delete safe folder
rm -rf $HOME/.local/share/safe/client
# upgrade client and get some Coins
safeup client
sleep 2
######################################################################################################################## Stop Nodes
elif [[ "$SELECTION" == "3" ]]; then
pkill -e safenode
######################################################################################################################## Get Test Coins
elif [[ "$SELECTION" == "4" ]]; then
NUMBER_COINS=$(whiptail --title "Number of Coins" --inputbox "\nEnter number of deposits 100 each" 8 40 $NUMBER_COINS 3>&1 1>&2 2>&3)
exit 0
fi
for (( c=1; c<=$NUMBER_COINS; c++ ))
do
sleep 1
done
######################################################################################################################### Start Vdash
elif [[ "$SELECTION" == "5" ]]; then
######################################################################################################################### update and restart
elif [[ "$SELECTION" == "6" ]]; then
rustup update
sudo apt update -y && sudo apt upgrade -y
sudo reboot
############################################################################################################################################# comnet
elif [[ "$SELECTION" == "7" ]]; then
exit 0
fi
pkill -e safenode
rm -rf $HOME/ntracking/*.log
sleep 2
############################## install client node and vdash and set up comnet make sure and change download and unzip instructions and peer
cd
mkdir comnet
cd comnet
wget https://comnet-sn.s3.eu-west-2.amazonaws.com/maidsafe/main/safe-beta-x86_64-unknown-linux-musl.tar.gz
wget https://comnet-sn.s3.eu-west-2.amazonaws.com/maidsafe/main/safenode-beta-x86_64-unknown-linux-musl.tar.gz
sleep 1
tar -xvzf safe-beta-x86_64-unknown-linux-musl.tar.gz
tar -xvzf safenode-beta-x86_64-unknown-linux-musl.tar.gz
sleep 1
rm *.gz
cargo install vdash
sleep 2
do
sleep $NODE_START_DELAY && /home/ubuntu/comnet/safenode --peer /ip4/46.101.5.184/tcp/36301/p2p/12D3KooWBVHdavXJqggn396jQQevJvXtjTN1pwb8YqS65wyitTrx --port $c --max_log_files 2 --max_archived_log_files 1 2>&1 > /dev/null & disown
NODE_START_DELAY=$(($NODE_START_DELAY+30))
done
sleep 2
fi
